Seems a bit extreme to change brakes because the pads sit close to the disc. Surely there must be a way of setting them up so they don’t catch / run all the time?
If you do swap then it’s a vote for Sam Guides from me. I’ve got the Guide Rs and eye been faultless so far. Easy to bleed and have reach adjustment. If you feel flush then I think the guide rsc also has bite point adjustment (that actually works ). You can feel how much power you’ve got at all times and judge when lock up will occur. Always got enough power, and even banzai speeds at bpw haven’t made me think I need more brake (running 160mm discs at both ends).
I’ve not tried modern hopes, but find shimano brakes too grabby. I’ve tried some formulas on a mates bike which seemed OK, but haven’t been very reliable.
