Home Forums Chat Forum brake help please
Viewing 5 posts - 1 through 5 (of 5 total)
  • brake help please
  • swainey180
    ive got Shimano SLX M666 brakes and Avid HS1 rotors, thay were working fine but noe when i pull the front brake hard the forks and handlebars shudder any idea?
    HermanShake
    Everything done up tight? Anything spilled (contaminated) onto the pads/rotor?
    Cougar
    Loose headset? Brake loose on the stanchion?
    You’d probably get a better response from the Bike Forum to be fair. Over here you’re as likely to get Parkinsons? as a suggestion.
    Lifer
    Check caliper bolts are all tight.
    argoose
    Get you wheels balanced
The topic ‘brake help please’ is closed to new replies.
