Community
brake advice for di...
[Closed] brake advice for disabled trike
Bike, power bits and me are heavy. Was running 2 pot xt, though good hoped 4 pot would be better. Trike has two wheels upfront so hose is split by t piece meaning one lever powers all pistons so 8 with saints. Xt lever doesn't quite have the master cylinder capacity. if filled with pistons half out it just works though over long throw which will hit bar with wear.tried hope duo, it's not right for this application, any uneven l/r means unpredictable fish tailing. so I need lever with biggest Master, mineral compatibility. all shimano equal size, biggest available I've seen is mt7. Anyone any thoughts on what's next to try? I could revert to xt but don't want to be beaten!
Posted : 01/05/2022 11:23 am
I recently built up a Lasher ATH-FS for my mate Neil that came with just what you need! Not sure if it's available as just a lever but these things are super powerful and haveย  the biggest lever reservoir I've seen.
They have a parking brake as well which while the lever for it feels a little flimsy is a nice feature.
http://www.tektro.com/mobile/products.php?p=281
Posted : 01/05/2022 3:15 pm
Motorcycle lever with larger reservoir and find fittings to reduce (presumably... Have no experience of motorbikes) the diameter down to mtb caliper?
Posted : 01/05/2022 3:23 pm
 igm
Left field idea.
Hope V-Twin, both brakes on the front, and a mechanical splitter on the cable?
Posted : 01/05/2022 6:20 pm
What about those hope brakes that are designed to operate two calipers one hand
Linky
Posted : 01/05/2022 6:31 pm
I was thinking similar but with trp Hy/Rd.ย  I'm not sure that will solve the fishtailing problem though as you won't be able to guarantee the pressure is shared evenly across the cylinders in the same was you do just using a splitter
Posted : 01/05/2022 6:58 pm
