As the title – what’s the best setup?
I currently run On one fat wheels (70mm) with on one floater 4″ tyre
I self drilled the wheels to save weight
I have tried bodging tubeless in many ways and haven’t got it to work at sufficiently low pressures (sub 5PSI ).
The bead interface is the problem – its just not designed for tubeless – It has a sloping profile and lacks the wide horizontal area and tight tolerances you get with for example a Stans rim.
When I tried not taping over the bead seat the tyre burped all of the time at low pressures. when I taped over the bead seat to create a tighter fit I snapped the tyre bead (that was a scary moment!)
Obvious choice is Stans Hugo – but they are just too narrow for me – I don’t want to loose volume or tyre shape.
I have looked at many tubeless wheels but all of them are vague on tubeless suitability and don’t tend to give a close up view of the tyre profile.
Any experience of what works best?
I’m not bothered by cut out rims – this hasn’t been my problem
I’m not interested in ghetto techniques – I want a proper tubeless setup
