Having thought about and spec’ing bearings, a little misalignment won’t hurt, with these bearings we’re running way below the rated capacity in normal running. Maybe your jumps and landings will pit the race. But anyhow it’s likely the sealing and jetwashing that will destroy them.
SKF specs (does link work?)
That said, my new frame I’ll have threads chased and shell faced. Might as well if it’s going to the shop to have headset cups swapped over.
HTH
/edit as more replied have been added
I’ll add that I’m only doing this without much thought is that the local shop now recognise me and said it’s a 15 minute job to do it all, fiver for the facing and fiver to swap cups over. Last bike I had it done to, a the shop I bought that bike from cost me £20 inc. fitting the BB.
for “20 for the facing I’d leave it as the BB shell on the frame looks pretty neat and if the alignment looked ok as I fitted the cups.
