Home Forums Chat Forum Any builders – help, how to remove brick car port?
Viewing 29 posts - 1 through 29 (of 29 total)
  • Any builders – help, how to remove brick car port?
  • glasgowdan
    Has anyone got any idea how this car port is going to be attached to the garage, and how to remove it?
    nickjb
    That’s a Bungalow, not a car port… IGMC
    bongohoohaa
    Lintel/steel from pillar to pillar?
    Hard to tell with only half a pic taken several miles away.
    Edit: Weird. Half my post never posted. Bit missing was more or less what Nick said.
    nickjb
    To remove I’d chip off some render to see what kind of lintel there is. Then support the opening on some acrows or a timber stack and maybe run a large disc cutter part way through, finish off with a big hammer. You could do it a little more delicately if you don’t want to damage the garage at all. Start from the top and knock it down brick by brick. I’d still run then disk cutter part way through to minimise transfer to the garage.
    duffle
    Stihl and a wobbly ladder tis the only way…….please set up camera! 😉
    crikey
    Big hammer.
    glasgowdan
    Reckon I’ll try and chip away as much brick/render as I can first then. Bolster and mallet? I guess the lintel would be sitting on a brick pillar on the right hand side… so I wouldn’t want to chip away anything on the pillar until the lintel’s dealt with right?
    martinhutch
    Hold a prayer meeting in it?
    avdave2
    I’d do it from above rather than below if that helps 🙂
    bails
    glasgowdan
    Bombs would be great
    piedidiformaggio
    apparently he was OK
    bongohoohaa
    If he was ok, he was very very lucky.
    Edit: From the comments:
    i nearly lost my leg it was that badly broken, all of the ligaments and tendons in my left knee were severed and the bone was smashed, so was the cartiledge in my knee. pretty horrific really!?
    pjm84
    Top down not like the other guy who is lucky to be alive.
    avdave2
    You’ll be wanting a shaped charge rather than just an ordinary bomb.
    andyl
    put a sign up “Free parking for xxxx*” and I’m sure someone will eventually knock it down for you.
    *choose your own subset of the motoring population here
    avdave2
    Free parking for mountain bikers with roof racks
    stuey
    Cut brake hoses?
    Toddboy
    Tie a strong chain to the top of the car port and the other end to the back of your car. Drive as fast as possible away from the car port.
    What could possibly go wrong?
    br
    Yep. My old man went around to his mates once to help him knock down the old air raid shelter that was in his back garden – found him knocking the bricks out, from the inside (while the foot thick concrete roof was still on)…
    ghostlymachine
    Similar tale from one of our local characters. Went to knock an old two storey building down. It’d been the original farmhouse on the property and been in a fire in the 70s or 80s.
    They reckon he’d been under the wreckage for 12 hours before the services were called. Took another couple of hours to dig him out. Mild concussion and dust inhalation issues. Other than that he was fine.
    Dropped a car on himself last autumn. Not such a good outcome.
    badllama
    If its brick under that render just use one of these
    Drill
    Better still
    Breaker
    Or similar, shocking how quick you can take walls down with one 😀
    glasgowdan
    And as promised, took about 5hrs and I’ve still to go back and deal with the untold amount of base material plus the remnants of the pillar. Dust mask and goggles clagged up so I ended up making do without…glad this is a one off! Sliced the whole thing up with the 9″ disc. Pics on the way
    glasgowdan
    cyclistm
    That’s impressively neat demolition.
    funkmasterp
    Good job. I’d have hired a JCB and hit it with the shovel bit. That’s why I work in an office!
    cyclistm
    Me too. Which is why I work in an office and would be writing this from hospital
    andyl
    Aldi had a big ass breaker in store last week. Might be useful for getting shot of the base but on the other hand it might just be easier to get a mini digger in.
    glasgowdan
    I’ve spent most of the day on the base with a mattock. Borrowed the roofers breaker for the post remnants. I hadn’t banked on the base being much higher than the driveway so there has been a load of slabs, bricks, soil and rubble to load into the skip. The body’s tired.
The topic ‘Any builders – help, how to remove brick car port?’ is closed to new replies.
