Zwift, my journey, ...
Zwift, my journey, my weight and my fitness.
And in other news, Graylish brings home the
Silver in Cat C for Team STW. Get in!
nice. If you put "STW" in the team field on the zwiftpower settings page it displays in a blue box next to your name on the results page for that pro look 🙂
The KISS TT results from last night are still messed up, hopefully they're sorted later!
mostly they seem OK but it's showing you as not completing the course, which is odd as you were on there properly immediately after the race! Clearly something went wrong after ZP grabbed your Strava data. I think you can email the ZP guys if it bothers you & they can sort in manually.
Posted : 19/01/2017 10:27 am
I haven't ever looked at the race results, mainly as I get bored and rarely finish an event.
It's a training tool for me rather than racing - save my racing for the fun stuff IRL.
The Gladiator race yesterday was pretty good however, that one nearly entertained me enough to finish - ended up using the last lap for a cool down.
Seems like the racing bit with results is more hassle than it's worth.
Posted : 19/01/2017 10:31 am
Well, I can't find the enthusiasm to do the FTP test workout thing, especially after a few on here reckoned it wasn't really worth bothering with - I can see your point.
Yesterday I decided to do the mountain route, which I really enjoyed. Great exercise for a Fenland flat lander like me!!
I got into a bit of a tussle with an American bloke on the last drag right to the top and then my warm-down descent turned into a charging race of who could get down the mountain quicker! It was great.
Only problem I had was at the start of my ride; all my devices connected fine on the opening page, but then when I started riding there was no resistance at all from the Flow Smart and no data feed at all, including HR.
Restarting Zwift sorted it, but Zwift takes so long to load it lost me about 6-7 mins due to faff.....
Posted : 19/01/2017 10:57 am
I've not had an issue with Zwift not picking up the data from my various ANT+ devices but a couple of times I have found that the turbo trainer resistance hasn't adapted to the changes in incline. Not really an issue as the power readings still seemed ok, but it did seem like something in the Zwift startup process wasn't working right.
Posted : 19/01/2017 11:09 am
@zilog - it's my own fault. I probably confused the hell out of it when I rejoined Zwift behind Weeksy, after finishing the race and exiting, to see how he was getting on.
But the race is only showing 7 people as finishing.
I think I finished 13-15th, which I'm happy with as I got an epic stitch 10 mins in.
Posted : 19/01/2017 11:11 am
mine did that in the GCN race. i was getting power readings but no resistance on the gradients. after the race I repaired it as a controllable trainer in the menu and it worked fine without exiting zwift.
Posted : 19/01/2017 11:15 am
Right, who's on the KISS race this morning?
Posted : 19/01/2017 11:17 am
epicsteve - Member
It was weird that it all connected in the start up screen & seemed to be working, but then when I started the ride it all just disconnected - I went into the setting screen and there was a banner across each sensor saying something like 'not paired'
jam bo - Member
I didn't think of just trying to re-pair them in the menu settings. I just chose the brute force close & re-start option. I'll try to remember to do that next time.
Posted : 19/01/2017 11:19 am
Just done the TBR LONDON ride and finished 3rd only 4 seconds behind the winner and got the KOM jersey for box hill, did it in 6:39. Lets see if ZP picks up my result.
Posted : 19/01/2017 11:30 am
Wow... we've got some proper racers on STW.
Posted : 19/01/2017 12:12 pm
As well as the likes of me...
Posted : 19/01/2017 12:30 pm
Ok i have been playing about on zwift after my race to try and find a set up that is more like my actual ability. I can say with extreme confidence that i am not a Cat A rider but i have been running in these events so i can be competitive and not dq'd all the time. I think i have the right set up now which reflects more like real world cycling which will hopefully help my fitness better than what i am doing now, so farewell to cat A and B and i look forward to the embrace of cat C riders (gotta earn my cat c stripes first)
Posted : 19/01/2017 12:33 pm
Lol what had you done wrong blader?
Dropping from A to C is quite large!?
Posted : 19/01/2017 12:45 pm
Yeah I assume you're talking about not having your trainer configured properly in Zwift so it's over-estimating your zPower? Otherwise that's some serious sandbagging!!
Posted : 19/01/2017 12:46 pm
Have you got an Ant+ washing machine or something?
Posted : 19/01/2017 12:49 pm
zPower is utter b***ocks, could easily increase/decrease it by 50% on the same trainer just from setup and that's before any zwift settings.
Posted : 19/01/2017 12:51 pm
By choosing a different/wrong trainer or are there other options (hidden away?) in Zwift?
Posted : 19/01/2017 12:59 pm
Obviously you can pick a wrong trainer in zwift, but there's other stuff you can do to.
1) Inflate tyre right up to (and beyond if you feel like some risk taking) its max pressure, rather than a normal riding pressure. You are on a perfectly smooth roller, so no drawbacks from more pressure.
2) Reduce clamping force - doesn't matter if wheel slips a bit since your speed sensor is on the wheel - wheel spinning with less resistance = more zPower.
3) Most fluid trainers have substantially different curves when warmed up - use them in a cold room with a fan blowing on the fluid unit and they'll never warm up = 5-6W/KG FTP no worries. Assume similar abuse can be made with resistance dial for mag trainers.
4) If you really wanted you could run a smaller (650c) wheel and zwift would happily assume its a 700c.
Not that i'm advocating doing any of these, or accusing anyone. Just pointing out the zPower is so easily abused both on purpose and by accident its bordering on worthless
Posted : 19/01/2017 1:13 pm
Hmmmm, seems like the "warm up" lap on the KISS race is very much still a max effort with a sprint start then!
Posted : 19/01/2017 1:23 pm
You'll find that's the same with all races that have a "warm up". I think they're just there because the route happens to include an initial section that takes you to where the laps start.
Posted : 19/01/2017 1:26 pm
I think a combination of a poor turbo which wasnt set up quite right and ridiculous stats generated by zwift. I have also realised my turbo was set to resistance 2 when it should have been 3. I also discovered a very slow puncture which i think was affecting the resistance on the roller after a couple of days.
I could happily stay as i am as its still hard work keeping up but it feels like a training session for long sprints and i would prefer something that will benefit distance and climbing as i live in hilly Yorkshire.
Posted : 19/01/2017 2:11 pm
Amazon have just dropped the price of the Neo again to £864, although delivery is currently listed at 1-3 months..
https://www.amazon.co.uk/gp/offer-listing/B0112VE4NO
(NB I'm referring to the sale from Amazon themselves. There's a couple of cheaper sellers but they look dodgy to me)
Posted : 19/01/2017 3:25 pm
That is pretty quick 🙂
Speaking of which, a lot of rapid Koreans round London this morning. They the Zwift equivalent of old GDR? 😉
Recommended, really like mine. And unless you find somewhere with stock it's likely to be a long wait as I hear they have a long list of people waiting for stock.
Edit... oh and after a fair bit of deliberation, Zwift rides now on my strava and I'm in the STW group 8)
Posted : 19/01/2017 3:28 pm
Lol! I was going to make all my non-Zwift rides private otherwise 😀
Posted : 19/01/2017 5:28 pm
I've taken a tip from here. Make them private initially then public after a day or two.
Posted : 19/01/2017 5:40 pm
Can't decide whether to to the 8pm KISS race - found it boring last time - or to go and ride up box hill for the first time
Posted : 19/01/2017 8:06 pm
Boring why?
Posted : 19/01/2017 8:28 pm
too flat, there's enough flat where i live in the real world
Posted : 19/01/2017 8:38 pm
Let me know, I've got a 9.45 in me if that's where I start and end my ride. If you get below 9.30 thought you can have it
Managed to break 10 minutes tonight and have set you a 9:57 to aim at. Wasn't a lot left in the tank at that but I did stop briefly with what might have been some kind of ANT+ dropout so might be able to improve that by a few seconds without actually killing myself.
Posted : 19/01/2017 9:06 pm
Does anyone other than me have a drivo?
I have a "noise" question
Posted : 19/01/2017 9:20 pm
Ooooh. Hopefully I'll get a chance in the morning as I think it switches on us time. So if I get on early I may be able to have a crack at it.
Well done BTW.
Posted : 19/01/2017 9:31 pm
Cheers. Looked like I backed off a bit early though as I was 15 seconds behind your PB for the London Loop Forward full lap!
Posted : 19/01/2017 9:34 pm
how do I search for segments on strava that are zwift ones? To compare times / etc.?
I know they're there, as others have linked to them but I can't find how to search for them myself!!
[ok, think I sussed it out]
Posted : 19/01/2017 9:39 pm
Zwifted tonight for the first time, lap round boxhill. There was a STWer behind me for a bit-how so I join the Stw club ?
Initial impressions are good, certainly livens up an hour in the garage while on parenting duties.
Posted : 19/01/2017 9:41 pm
I was on earlier riding with a mate, gave a fellow stw'er a ride on.
Was aiming to set a new PB up box hill but my rear wheel kept slipping...and trying to save my legs for the weekend 😆
Posted : 19/01/2017 10:20 pm
It's been a bit icy out
Posted : 19/01/2017 10:21 pm
I binned the KISS race halfway because my screen kept freezing dropping me 5s back from the group I was in. Went up box hill for the first time instead, fairly consistent 280w all the way up, unfortunately I weight 94kg though.
Was my second outing using the Tacx Flow, it's really creaky which was doing my head in. Time to get the silicone spray out. I also struggled with the resistance which seems too much on little rises, with no considerations for the momentum. Resistance was fine on box hill.
Posted : 19/01/2017 10:59 pm
STW Box Hill comp is hotting up I see! Managed to knock a minute or so off my PR tonight, not quite troubling the top 10 yet though (probably need to lose at least 5kg for that!)
Posted : 20/01/2017 12:53 am
What Strava segment for box hill are we using? it doesn't correlate with the Swift kom
Posted : 20/01/2017 12:55 am
Bollocks! I've not been paying attention and dropped about 8 spots!
(And I'm pretty sure I've peaked already)
Posted : 20/01/2017 6:13 am
[url= https://www.strava.com/segments/12744502?filter=overall ]This one[/url]
Posted : 20/01/2017 7:38 am
Oo I did set a new personal best last night 🙄
I think it's much easier to set a new PB in a race - you can hang on to someone else's wheel then haha.
Posted : 20/01/2017 8:13 am
Thanks, 37th, 1 place in front of weeksy 😉
Posted : 20/01/2017 8:26 am
Oh FFS, i was going to ride outside again ! Now i've got to do the Box Hill climb today haven't I .... !
Althoguh, i have to admit, i'm not actually convinced i CAN beat it !
Posted : 20/01/2017 8:29 am
I think there's enough potential, globally, for tit-for-tat hostilities even without a battle of box hill
(so give it a day to sink in ... and THEN smash* him !)
((*see my classifieds ad for ebike))
Posted : 20/01/2017 8:40 am
Page 51 / 343
