Ok,
Seeing as they're no longer any more eco friendly than petrol (ok you get more mpg, but when you include the CO2 released making diesel it works out pretty much even)
Servicing costs more
Is it still worth paying more for a diesel?
Ones done 80,000 miles more, is 2 years older, yet worth only £100 less?
Vs
I'd say if you plan doing less than 15K a year and aren't bothered about a torquey engine for the hills go for the petrol with only 10% (ish) of the mileage the diesel has.
The TDi will be a lot more relaxing to drive due to the extra torque and will use less fuel than the petrol in everyday driving, the 1.4 will feel a bit gutless. Not sure how many miles you do a year but that diesel has done nearly 30000 a year from new, might be worth having a real good luck over the service history and check for cambelt change etc. They are both fairly cheap for what was a £12k+ car new.
Diesel used to be more reliable but that's not necessarily the case as I can testify after 4 new injectors on a 3.5yr old diesel. (Plus all the manufacturers use the same injectors so all pretty poor)
Good points is the amount of torque, good acceleration now to match a petrol, fuel consumption, starts every time from cold instantly.
Bad points: no more reliable than petrols and errr that's about it.
On paying the extra I'd say it's only woth it if you're going to do a whole load of miles every year, not just for average mileage.
So pretty much in agreement with Carlosg then......
wasn't planning on either, just half heartedly looking for something cheep'n'crap to supplement the MG midget..
mpg doesn't relay bother me, I can get to my parents and back in the midget for £40, and that's filling it with Shell jungle juice 🙂
Love the look of these wee Skodas 8)
I personally would go for the petrol regardless of the milage you do as your getting a low miler for not alot of cash also its a very simple engine with not much to go wrong unlike high milage(for age) diesel
I only have a diesel because I do 20k miles a year, but even then it was a bit marginal cost-wise - for the Civic it's down to a 1.8 petrol or 2.2 diesel, both making the same power, but the diesel feels more powerful more of the time because you don't need to rev it everywhere. Lots of people seem to be buying diesels these days just for that reason.
Diesels tend to be slightly lower on CO2 (so fall in a lower tax bracket) and can be cheaper to insure too. Against that, servicing tends to be more and there's usually lots of expensive bits - turbos, injectors, dual-mass flywheels and the like - which tend to fail at some point once out of warranty. Oh, and in the winter they take an age to warm up enough for the heater to work.
Those two cars are a bit of an extreme example, but the 1.9PD will be a load quicker than the figures suggest, and it's a trim level up which gets a load of other niceties too.
Turbo Diesels are good on the motorway and grunty. They're often a bit frustrating for 'spirited' driving though and NOT actually as fast as people think they are. An equivalently grunty petrol will be thirsty.
The cost benefit isn't that great unless you do a lot of mileage and if the fuel pump, turbo, injectors etc. pack in then the benefit will be instantly lost.
I have a diesel but may go back to a non-turbo petrol the next time I buy a car.
Definitely needs to be 15K+ miles a year to be worth it.
If like me you do more like 30K a year, then it's miles cheaper in the long run.
i don't care about the cost savings/increases, i prefer diesel because of the way they drive, more relaxed.
I used to drive 75,000 year, all in Diesels, I now only do 24,000, splite between the van and car, both Diesels,one with 113,000 on the clock, one with 95,000 on the clock, neither burn any oil and run sweet as a nut, if you service them regular, dont thrash the NUTS of them they will look after you well, I changed to Diesels over 25 years ago and would NEVER go back to a petrol.
The question is, how much of a man will you feel in a 1.4 skoda?
Very good article on this in the Parker guide online.
Compares equivalent Diesel and Petrol models - it's an interesting read as some diesel models will NEVER be financially viable (i.e will never break even!).
That's the reason we went for a petrol engine - cheaper to buy, and we simply don't do the miles needed to justify it.
DrP
How much of a 'man' would you feel in a 1.4 anything? Unless it's a TSi, or a Boka Negra.
We tow a caravan & a diesel engine is loads better for that. If we didn't tow we'd have petrol as nice & quiet.
The last time I had a diesel (Xantia 1.9TD), it was a company car 'forced' on me due to the miles I did - colleagues who did less could have petrols...
Do the sums, work out the costs.
Where d'you get that from?
As for spirited driving.. new common rail VAG engine pulls like hell up to the red line, in fact increases in power as you get up there just like a petrol. But unlike a petrol, it also works at 1200 rpm too. So win/win.
I drive a 1.5 midget, I'm used to driving slowly everywhere :p
OK - so what about in France where the Diesel is about 30% cheaper than petrol..
what should I buy? doing about 10,000 miles / year...
I design oil refineries for a living
There isn't enough diesel in the world to supply demand, so you pass the heavy oils through a hydro cracker which is a huge great big reactor the size of a medium sized office block, stuffed full of a very expensive catalyst at very very very high temperatures and pressure.
Even the pure diesel streams from crude oil need hydro treating under much harsher conditions than petrol.
It's worth noting that diesel and petrol both come from the same source ie crude oil, which is refined to produce loads of different things. So you could argue that the energy cost of producing diesel is nil if you are going to produce all the other things anyway..... you can't produce diesel on its own.
It was a geniune question not a bolshy stw I think you're wrong statement. Really, I'd like to read about it.
As for replacing injectors - petrols have them too. Also they have spark plugs, HT ignition systems etc. Plus a petrol engine's turned over 50% more in its life so 50% more piston strokes and whatnot.
Plus if you care about CO2 emissions you can put biodiesel in your diesel 🙂
To get over the inherent problems with emissions and 'refinement', diesel injection systems work at extremely high pressures which can be harsh on pumps and injectors.
Turbos (on whatever type of engine) wear out, quickly if not looked after.
For want of a better phrase, a modern high-output TD engine is basically in a 'higher state of tune' than a similarly-sized petrol.
Have you driven either of those cars?
I would hazard a guess that the 1.4 will be choresomely slow, but you are paying a whole lot more for a car with many more miles on the clock if you take the diesel option.
For what it's worth, the 1.9TDi in my Ibiza (almost same engine, but with more poke) has been fine for the 90k miles I have done in it over the last 3 yrs 4 months. Only engine related thing i have had replaced was an intercooler pipe.
The 1.9TDi is clattery on start-up, but fine once warm. It does take a while to warm up & might not be the best choice if you are doing lots of short journies.
As for servicing costs, my Ibiza has cost me no more to service than my old MkIII 1.4 8v Fiesta, even though it has 55bhp more & 3x the torque (although it gets through tyres quicker). Even the cambelt isn't that expensive to get changed (60k mile service with cambelt changge totalled £270).
I've certainly not experience this 'diesels cost more to service' thing that people talk about.
In fairness, the 1.9TDI is actually a good engine and more 'robust' than more modern, common-rail engines.
Diesels are worse for air quality if that concerns you at all. Driving them does keep my research in business though....
i agree with the diesels more relaxing to drive statement above
i had a 1.8 diesel fiesta when i passed my test - it was ace i sold it for 100 quid with 200k on the clock and rusty as buggery- arrived with 90k ....
moved onto petrol 90bhp 1.6 engine - lasted from 60k to 80k before headgasket went
then a 120bhp hyundai lantra - hand me down from parents it lasted 3 weeks befor electrics died. but it could shift if you "drove it"
back into a diesel 1.9 pug van and it cant overtake for shit so i drive more sensibly - leave earlier and use less fuel for this reason alone - i know i cant just floor it and accelerate quicker and use more fuel im restricted to 16 seconds minimum 0-60
im also changing gears alot less - hills - pah i laugh at hills.
insurance is a git though
So how come all the ultra-mileage cars are diesels? Mine's still a baby at 136k (would be a lot more if I'd carried on doing the ~18k average mileage I was when I got it - yesterday I filled up for the first time this year!)
couldn't pull up an article on it, just something someone at work mentioned and I've no real reason not to believe it, refining diesel is much more energy intensive than refining petrol, here's the pocess simplified
Petrol:
Crude->[atmospheric distillation]->naphtha->[hydrotreater]->[splitter](just another distillation column)
heavy naphtha and light naphtha are then treated by isomerisation and platforming and blended to make the various grades of petrol.
All in all its mainly low pressures and temperatures, nothing too extreme.
Diesel, some of it comes out the atmospheric column, but no where near enough, so you take the heavy fractions and 'crack' them to make lighter stuff, depending on the market this usually means diesel (in America they use FCC reactors which produce more petrol). This involves seriously high temperatures and pressures and lots of energy.
Obviously the carbon footprint of your diesel depends on the oil used in the refinery, the refinery configuration, and the market demands.
The internet disagrees with me on this one, maybe he was talking bollocks, although most of the internet evidence is ranting at taxation and claims that petrol is easier to refine which just runs counter to what I would say.
The other problem with Diesels is the NOx output in the exhaust. As greenhouse gasses go, they're the daddy.
But still, as the owner of a 13 year old 1.9 diesel polo with not a shred of electronics in the engine, I choose to ignore that.
48-55mpg and it would happily run on warmed up butter.
NOx is not a greenhouse gas per se but it contributes to tropospheric ozone and also can go to N2O, both of which are. NOx can also reduce greenhouse gases by going to OH which shortens the lifetime of greenhouse gases like CH4 so its swings and roundabouts.
Yep. It's only a pollutant if you put it in the wrong place. Unfortunately my car doesn't have a 10 mile high exhaust pipe!
Hmm, I didn't know about this. It's true though that the carbon footprint of diesel would depend on the amount of extraction and of what type of crude for diesel and other purposes.
I had a look at the VW site last night comparing petrol and diesel on the basis that they probably have some of the most efficient petrol engines. In Passats the petrol compares reasonably favourably with diesel, but not at all in Golfs.
The energy cost of producing diesel is another argument in favour of petrol hybrids, is it not?
The 1.4 Skoda will be slightly slower than the 1.9 diesel in terms of out and out power.
That said, I don't like the way diesels drive (if I want relaxed, I'll get a car with a V8, LPG and an autobox), and I don't like the complication and weight of them. Dual mass flywheels, extremely high pressure injection systems and a grand's worth of emissions kit do not make for the kind of reliability people talk about. It's always been something of a myth that diesels are more long lived than petrols - maybe in the pre fuel injection days when petrol cars suffered from over rich mixtures and lots of bore wash, but not now.
So my view is that I'd go for petrol every time. If I were buying new, and doing 30k a year, it might work out for me to buy a diesel. Buying second hand and doing sane mileage, you might save a quid or two a week on fuel, but you can be landed with a £500 bill at any time if the DMF, fuel pumps or DPF pack up.
There's a bloke quoted in this article on the amount of CO2 produced by refining diesel:
http://www.telegraph.co.uk/motoring/green-motoring/7166444/Is-diesel-dead.html
as others depends om the milage or towing so do some sums
As for those questioning whow much of a man you would feel in a 1.4 I am so sorry for you that your masculinity is so fragile that if you dont have a large powerful car it somehow feels threatened..the answer for me would clearly be more of a man than you would as my sense of being a man is not linked to the cc of the car I drive.
For those people saying that Diesel has a higher fuel pressure than petrol isn't strictly true. New lean burn tech (stratified charge) where direct injection of the fuel into the commbustion chamber is utilised run similar fuel pressure's to that of diesel of about 120 bar. So the diesel/petrol argument there is kinda taken out of the equation.
Sure Normal indirect multipoint this could be taken into consideration
I think that Common Rail diesel pressure is of the order of [b]1000-2000 [/b]bar.
Quite right. In order to prove your manhood you simply have to have kiddy seats in the back and a "baby on board" sticker.
0-60 maybe, but the 1.4 will feel way way slower - as I can testify. In a 1.4 you'll be forever having to wedge it in 3rd to get anything at all to happen. In the D you'll be able to squeeze the pedal and get pushed forwards whatever gear you are in.
As for reliability of diesels, it's not a myth, it may be a touch out of date though. In the old days a diesel benefited from being overbuilt, and running at low revs all their lives, but they didn't have to worry about a HT injection system. So no damp start problems, no mixture problems, no carburettor, no fuel quality issues, no spark plug issues, no HT leads etc etc etc.
PS can't believe the Honda 2.2 iCDTI isn't in the favourite diesel engine list on that telegraph article.
PPS I'd only drive petrol hybrid if I could tow with it.
Spark plugs tend to last at the very least 20k, and fairly often 50k these days, depending on what plug's specified. About the same as glow-plugs. EFI has done away with cold start issues etc. The only thing that a petrol has to go wrong that a diesel doesn't have an equivalent for is HT leads, and that's a fairly rare occurence (with the exception of Mondeos of a certain vintage).
On the other hand, diesels have bits that petrols don't, and seem to manage to lunch Dual Mass Flywheels at a massive rate compared to petrol cars. And the bits that pack up on diesels are expensive!
Strangely my glow plugs manage rather more than that (think I had to have them done at ~90k).
Such as?
I don't have a DMF flywheel either - them being unreliable is a whole separate issue.
Tron, I was talking about where the reliability thing came from ie 15 years ago. My petrol's got no HT leads, ignition coils are built into the spark plug.
But as has already been said, they have a turbo (Which needs expensive oil) and a stack of emissions kit to go wrong instead.
Whatever, when I did the sums, there's no way a diesel would have been cheaper to run, so we bought a petrol car. You've got to be doing 20k+ before it's worth it
And I simply don't like diesel engines in cars. I've driven a LOT of them as well, from most maufacturers, and recently I got to compare our petrol Focus with another Focus with the equivilent diesel engine in it.
The diesel car was like somebody had filled the front with lead and replaced the throttle cable with some old knicker elastic.
Whatever the NUMBERS say, to me a petrol engine feels crisper, keener, smoother. There's no turbo lag, no powerband: Dab the gas and get the power instantly, not wait for a second or two, get a huge rush of tourque and then have it die 1000rpm before the redline.
And the petrol Focus was notably better handling. It just felt lighter on the front and quicker and more accurate to turn in. More bite in the brakes too, and a slightly more supple ride. The heavier diesel engine really dulled the dynamics of the car.
It's the second back-to back test I've done like this, and the petrol car has won both times.......
You lot do realise that you have just totally ruined what was, for me at least, an easy choice at what I was going to get as a next car don't you?
I had it all lined up... part-ex my 4x4 for a five year old (max) Skoda Octavia estate diesel and drive off into the sunset smoking pipe and putting leather arm patches onto my tweed jacket.
I now find out that I might as well not both buying one because even the 56 mpg figures that parkers bandy around for the 1.9PD TDi version are going to cost me money because I do less than 15k a year.
So, you swines... What am I going to do now? Huh? It's taken me a year to think about selling my 4x4 and now it's gone totally out the window.
Turbos.. we are talking about old diesels here.. turbo just went in my old diesel that my neighbour now has.. after 185k miles. Can't really complain about that 🙂
I invite you to come and drive my Passat 2.0 TDi. It categorically does NOT do this. Seriously, it pulls more and more up to the red line.
There is turbo lag, unless you leave the tranny in S mode, when there's none. As for handling, yep, agree. Personally I don't like the way you have to downshift in a petrol car to get it to accelerate, and I also don't like the way I have to fill up 30% more often 🙂
Oh and willard - MTFU, sell the chelsea tractor, get the Octy and enjoy torquey effortless motoring 🙂
Get an Octavia Scout 4x4 tuned for 180 bhp and get the best of both worlds 😉
I tell you what i like the look of - the new VAG 1.4 turbo engines - 140BHP, low emissions. Sure - you'll have to get 'em spinning for decent power, but there's something satisfying about low displacement turbo engines!
DrP
DrP, I often said to myself that someone should come up with a small turbo petrol engine - lo and behold VW did. Not bad for emissions but you've still got turbos to contend with which was one of the diesel disadvantages quoted above.
Yeah, I thought about the Scout, but given that most of my driving these days is on road and not on the farm (and it is _not_ a chelsea tractor by the way!) it seems pointless to have... Just another bit of transmission to haul around.
This really is no easier than it was six months ago. Maybe I should just buy another cheap Golf while I decide...
Having just got a used Golf GT TDi I have to say I love the torquey nature of a decent diesel. We do quite a lot of country lane stuff and the engine makes it so easy to go at a reasonable speed without having to rev the nuts off it - lovely for overtaking in short distances too.
I do a 7 mile round trip to school and back every morning and even over a short distance it averages 44mpg even when it's below freezing.
I've told myself I won't buy another petrol engined car 🙂
I've just gone from a petrol turbo Saab to a diesel turbo Saab and er.. er.. sorry I don't give shit! It's just a car!
Nor do I really... But I have a certain number of requirements that I have to meet.
1) Boot big enough for two spaniels, overall big enough to fit camping stuff, dogs and food in for a week. Bikes to be able to go in the back when dogs are not in there
2) Good fuel economy
3) Reliable
4) Comfortable on long drives
I'd like to add "exciting drive", "sporty", "off road ability" to that list, but let's be honest here... I don't care as long as it gets me to work daily, get's me back to Suffolk once in a while and down to Wiltshire once a month.
Ideas?
Personally I reper petrol, I had motorbikes before cars so the concept of changeing gear to accelerate doesn't bother me. Although I do miss being able to flick between gears without the clutch.
I'd love it if someone built engines designed for LPG, might not be very long lived, but 200bhp per liter would be fairly easily obtainable, although you'd have 2stroke sized power bands..
willard - no budget then! Must be a massive range, no wonder you're having trouble. 😉
Tinas, are you talking about increasing the compression ratio? Several companies are working on that for ethanol - with appropriate compression you can achieve high specific powers. I think Saab were looking at eccentric crankshaft bearings, kind of like an EBB for single speeds I suppose.. but then again if you have a turbo you can just up the boost which is what some older car enthusiasts have been doing, to get 300bhp from old Volvos I read somewhere.
Variable compression with atkinson miller cycle using solenoid valves.. very interesting.
Would that be the same 2.0Tdi engine sitting in the VW Eos sitting in our drive? The 140bhp one? (Belongs to the mother in law, we get to borrow it when she goes away)
Well, it's a gutless slug below about 1500rpm. (Our 1.6 Focus is more flexible) It's the engine I was thinking of when I wrote my last post. Horrible thing. The old 1.9Tdi she had before it was a far nicer engine, even though it didn't have the same headline power figures.
thisisnotaspoon I'd go for the 1.4 petrol personally.
I'd only buy the 1.9TDI if you were planning on owning it for its life. Sorry '90k just run in' doesnt count it for me. ALL engines are a lottery.
If you were keeping it 2-3yrs- 1.4 everytime.
Ah yes, budget... A sore point that. I'd like to say I could afford to go an spunk a wadge of cash on a second hand Cayenne diesel, but in reality I've got about 5k (maybe 6k with a following wind) to spend on something that should maybe last four years.
ditto molgrip's point on the 2.2 CDTi Honda engine. What a silly reviewer. I drive a different diesel car every week and my honda 2.2 beats them all hands down. It's the only one that feels like a petrol engine.
[i]There isn't enough diesel in the world to supply demand[/i]
You sound ever so slightly biased there because precisely the same point is true for petrol isn't it.
edit: oh sorry, would I reccommend a diesel engine? Every single time, whether it's for running around town or doing long motorway hauls. I'd never go back to petrol.
Would I buy a 90,000 1.9TDI Fabia for over 5k?
Would I ****.
would I buy a 90,000 1.9TDI VW Passat for 3.5k? Yes I would.
You've got to be crackers to spend that much on a high-miler Pope mobile. I drove one on holiday and hated it with a passion. The Panda they replaced it with was five-times better.
Pile of shit.
[i]Would I buy a 90,000 1.9TDI Fabia for over 5k?
Would I ****.
would I buy a 90,000 1.9TDI VW Passat for 3.5k? Yes I would[/i]
You realise they're *exactly* the same engine? Made in the same factory and everything....
Oh aye yeah. Everything else round it has been designed with different tolerances and for a different purpose.
Lets not forget one is a amalgamation of two different floor pans and is designed around smaller engines etc.
Why would anyone want a Roomster? Jez to the forum..... 😆
hora - MemberOh aye yeah. Everything else round it has been designed with different tolerances and for a different purpose.
you appear to post on anyhting to do with cars, but I get the impression that you know ****-all about them beyond reading What Car at the dentist and probably talking b*ll*cks about them with your recruitment colleagues.
Bloke at work has just suggested that I pretend I have kids already and buy a new Berlingo. FFS!! Me, buy a French car?
Besides, it looks fugly.
I guess there's something wrong with yours then, mine's fine. Maybe you just don't understand turbo lag?
I hired a petrol Mazda 2 at the weekend. It was incredibly slow, like back to the days of 1.0 Fiesta/Polos, and only got 43mpg. It was totally gutless below 1.5krpm AND above it. You could trundle along nice and smoothly in say 4th at 40mph - put your foot down, and nothing happened. At all. To get onto motorways and such you had to red line it in second.. relaxed capable driving I think not.
My Passat is about twice the size, far quicker, far more versatile and gets more MPG. So why do people like petrol again?
And costs much more to buy new than a base Mazda 2. What is the equivalent petrol Passat like?
Sure, MF - wasn't comparing value. I actually quite liked the Mazda. This is about the engine technology itself.
Here's a dynograph of a Passat 2.0 TDi
Here's one for a Focus 1.6 Petrol
TDi develops about 43kW at 1.5krpm, the petrol about 17kW. About two and a half times the power from the diesel at that speed. TDi develops about 280Nm of torque at the same speed, and the petrol about 105Nm. The TDi reaches pretty much max torque at about 1700rpm, and in normal driving engine speeds it's operating at max torque. Hence torquey driving. The petrol's torque curve is quite interstingly flat all through the rev range but the figures are very much lower than the diesel. Hence having to change down to get it to move much at any kind of speed.
Also note how the TDI's power increases all the way up to its red line.
My mum has a skoda fabia estate 1.9d, gives ugly a bad name but goes as fast as anyone needs a road car to go, handling is precise enough as long as your not driving like a **** and fuel economy seems good.
Going back a bit, me and the Mrs both had MK4 Golfs for a while!
She had 150bhp Gti version, did less miles than me and I had the 1.9tdi 150bhp version as a company car.
(both did not deserve the gti badge tbh).
But the diesel felt the quicker car on the road to drive in real everyday traffic scenarios.
Neither were great drivers cars tbh, but I guess its as close as you can get as a direct comparison to petrol/diesel debate.
Saying that, she was loaned a 180bhp Gti and that was closer, slightly quicker match for the tdi.
Oh I do. Totally, 100% understand it. And THAT is PRECISELY why I don't like diesels. LAG! **slaps forehead**
I don't care what the numbers and the graphs say, I just care what it feels like when I twitch my right foot. At the end of the day, a petrol engine is more responsive than a turbo diesel. Tweak the throttle, and you get instant action. No matter how much power you get in a diesel, no matter where you are in the rev range, you've gotta send forms in triplicate to the engine when you want power. 😉 There's always that pause as the turbo spools up and the heavy old pistons slowly wind their speed up against that mahoosive compression. That's why, to me, diesel engines don't belong in sporty cars like said Eos.
I know I'm in the minority with this, but that suits me fine. I did the maths when we bought our car, and it wasn't worth getting a(nother) diesel financially, so we didn't. And it's lovely to have a smooth, quiet revvy little petrol engine again! 🙂
Molgrips, that graph shows the TDI's power falling off sharply before the red-line not increasing all the way.
