What axle width? 110, 135, 142 or 150?
Depends what youre making the axle out of? Whats wrong with a U clamp as per pic?
Bit to mount axle tapers inwards so not square to axle.
What's wrong with the usual way, as shown in that pic, of using U brackets underneath?
I think op means the handles taper to the wheel so the u brackets won't be square on.
Surely you just mount the square to the wheel?
In Stw style, can you not fit a set of fox 32 QR15's that you have spare, axle and mount sorted (with spare old hope hub of course)
*smiley wink*
Mount the U brackets square to the wheel, use end caps on the U brackets to stop the axle wandering left or right.
couple of 20mm pillow block bearings
[url= http://www.ebay.co.uk/itm/UCP-NP-Metric-Pillow-Block-Bearings-/320887516146?pt=LH_DefaultDomain_3&var=&hash=item4ab662ebf2 ]link[/url]
use an old front wheel hub, remove sploes and rim, then make wooden wheel in two parts, then fix over wheen hub, fix a steel ring over the top of wheel to prevent damage.
Eventually finished
Good work there!
