I didn't know it was tree hunting season.
Never mind tree hunting season, that's a dinosaur leg surely..?
Drill hole, insert dynamite?
How big is the saw bar?
You're gonna need a bigger gun.
you gonna burn it or live in it ?
Open season on trees - theyve all bred.
Guide bars only 20", i was thinking cut a slot across the top 20" deep and split that section off, then move along and repeat?
I always wanted to try splitting a trunk with wedges, not one that big though.
I cut a slightly smaller log in a similar fashion to the way you've described in your post. It produced some lovely square lumps which, of course, fitted my stove precisely. Also produced some lovely tinder when I rip-cut, too - picture wafer-thin, curly strips of wood.
You could always go retro and use a two-man cross cut saw...
Edit : Some nice two-man saws [url= http://www.flinn-garlick-saws.co.uk/acatalog/Specialised_Products.html ]HERE[/url]
Woodman-Just ring it up and split it like any other log! ๐
Might give it a whirl this week - shall report back
Your chainsaw may not cut well as the chain is designed for crosscut across the grain, and you will be ripping with the grain. They do make special chains for ripping; that's usually what those chainsaw type lumber mills use.
V8 chainsaw?
There were some blokes demonstrating cutting horizontal planks from a trunk like that at Treefest, Westonbirt, a couple of weeks ago, fascinating to watch, with this chainsaw arrangement on a frame. You're going to have fun with that!
Have you tried this?
That looks like it been lying for a while, it'll be either so dried out that it will cut quite easy and with careful application of a few wedges and a large maul may split along the grain or it will be like concrete and destroy your chainsaw teeth in minutes.
Should get a good winters worth of fuel out of it though - crack on..... ๐
Man up, ring it up and get busy with the maul ๐
If it was me I would cut it partly into a thin slice, say 3-6 inches as much as your bar can do, then go at it like rabbits and batter it into tiny chunks with your axe, then rest and repeat
On the other hand you could always use it as a starting core for Nov. 5th ๐
Btw we were giving the green light last year on a camping trip to burn a old oak trunk which was a good 5 foot across and had been in a field for 20 years
It burnt for three days, bliss, fond camping memories.....
Have you actually thought about this & looked around for more 'managable' bits of wood?
Na, thought not.
Manageable. Course i have. Last year cleared out manageable..
20" bar means you can do 20" this side and from the other and from the top. What's the diameter? Saw what you can to the length of the blocks you want. Wedges in and finish.
I'm guessing it's 4' high. But obv I can cut across the bottom. Top and 2 sides.
