Wood Stove - typica...
[Closed] Wood Stove - typical cost to have one fitted?
 s
[#3361694]
I know a few of you on here have wood burning stoves, so hope you don't mind me asking a question about cost:
Planning to have a wood stove [b]fitted by a HETAS approved installer[/b].
Just trying to guage if the first quote I have had, is about right cost wise?
The Stove will cost £650 for a Defra aproved smoke free version.
Will need a stainless steel liner, stove pipe, & cowl & register plate fitting, fireboard internals to fireplace, new stone hearth & make good plasterwork, plus a CO detector, smoke test, certificate, etc.
Been quoted £2k, which includes the cost of the stove, all parts & labour.
Does that seem about right to you?
Posted : 17/11/2011 3:30 pm
That's cheap. I had a quote nearer £4k!
Posted : 17/11/2011 3:33 pm
my experience:
http://singletrackworld.com/forum/topic/log-burners-advice#post-2988935
Posted : 17/11/2011 3:34 pm
About 2.5K all in for ours for S/S liner, stove pipe, register plate, hearth and all fitting with a 1.2K-ish stove.
Posted : 17/11/2011 3:37 pm
 s
Thanks stoner & everyone else
Very helpful
Guess it a busy time for the firms now too 😉
Posted : 17/11/2011 3:45 pm
 nbt
Ours came in around 2k - stove, fitting, hearth rebuilt, chimney liner fitted and plastering to make good
Posted : 17/11/2011 3:48 pm
about £1400 including the stove at about £650
Posted : 17/11/2011 3:54 pm
Just to say you don't have to involve HETAS. I was quoted 2K just to line the chimney and fit the thing from two HETAS guys near me. It actually cost me £1500 including knocking out the chimney breast, plastering inside, new hearth, liner, stove etc.
I did this by doing my homework on the regs, then getting it fitted by a competent builder and signed off by the local authority. None of it is rocket science if you take the time to read Part J of the Building Regs and work out what you need - its all pretty straightforward stuff.
Posted : 17/11/2011 4:05 pm
 s
martinhutch - Member
Its a good and valid point martinhutch, I have not looked into the regs that much TBH, I am only going on what my home insurance company seem to want if I have one fitted.
But I think I might look it this a bit further, thanks for the tip.
Posted : 17/11/2011 4:13 pm
If you get it signed off under building regs, you'll have a building regs certificate for the work, which would surely be enough for an insurer?
Posted : 17/11/2011 4:46 pm
I've just been quoted £2k for a Charnwood C-four, fitting and putting a liner in etc. All in job the guy said.
Posted : 17/11/2011 5:01 pm
If you have a typical chimney, in good nick, built as part of the house, you probably won't need a liner either.
Posted : 17/11/2011 5:04 pm
Ditto, my nextdoor neighbour had done his so we did mine, hired a roof ladder bought flue liner and bits online & stove locally. Did it to regs and got it signed off, and it's as good as getting it HETAS installed. They are just qualified to sign there own work off.
Posted : 17/11/2011 5:27 pm
