Wiring in an invert...
[Closed] Wiring in an inverter, leisure battery for dummies
10 Users
Charged from Alternator when moving 240v when static..
I'm thinking 600w - 1000w pure sine inverter
100Ah leisure battery ( is this enough )
I don't have a clue on wire thicknesses, fuses, draw, compatible batteries to the one in my van,, etc..etc.
Any help appreciated..Tia folks
Posted : 19/06/2018 1:22 am
What do you want to run off said inverter?  Inverters are not a great way to power things unless no other option as there are a lot of losses in the system.
You'll need some sort of split charge relay  - I'd probably opt for a Durite type one for ease of installation.
Something like this below has all the components you already need packaged together, just add Battery.
https://www.ebay.co.uk/itm/Split-Charge-Durite-Relay-Kit-5mtr-Professional-12v-140amp-Voltage-Sensitive/201605897570?epid=1505127277&hash=item2ef0a5dd62:g:KOYAAOSwV25Zymu1
For a battery, you don't need to have a compatible one with the van, a battery is a battery.  Go for one that is intended as a leisure battery, not a starter battery, these handle repeat discharge/charge cycles much better.  100ah is a decent size, but depending what you want to run off it, might be no where near enough.  Also bare in mind, a VSR will take a long time to recharge a battery that has been very flat, so you might need a plug in charging option too.
W=VxA is the formula to work out your power usages. Watts, Volts and Amps.
So, for example, a 1000w load at 240v would draw 4.17a.  1000 = 240x4.17
at 12v though it changes to 83.3a, which is quite a big load and you can see would flatten a 100ah battery in no time at all as batteries won't take a full discharge,  you can expect approx 30 mins of run time I'd say.  Much better to run 12v appliances as far as possible, directly off the battery (via fused distribution).
In my case I only have a small inverter (350w) on the van for charging laptops etc and everything else is 12v direct, or use 240v appliances when hooked up to shore power.
Posted : 19/06/2018 5:48 am
Cooking or space heating is not going to happen from a basic battery/inverter setup, it cannot store enough power.  Smaller drains such as charging stuff is OK, but as above its considerably better to just buy 12v chargers for your stuff.  With modern tech all being 5v USB, the only real uses I can see for an inverter are toothbrush and shaver charging (although we broke several toothbrush chargers before realising they didn't play well with a modified sine wave)   I needed to use a jigsaw in the middle of a field once too...
Posted : 19/06/2018 6:28 am
What van and what age. Some newer vans don't play with split chargers.
+1 on run as much 12v as you can. Most laptops these days run 12v -19v with step down transformers -you can buy 12v versions these days.   We have never needed 240 on the road.
Remember and use multistrand flex and not house twin+earth
Posted : 19/06/2018 7:19 am
Laptops are often 10.8V or 14V or some such nonsense.  Inverters handy for them.
Posted : 19/06/2018 9:18 am
Ther is some useful info on 12voltplanet.co.uk
Posted : 19/06/2018 9:37 am
Yep, pretty key to know what the intended use is and why you need AC power.
I have an inverter in mine but I use it less and less. Admittedly that's partly because it's a quasi sine wave inverter and been responsible for knackering enough electronic goods that I know avoid it. USB sockets are my most commonly used now by a long stretch and I've bought 3rd party 12volt chargers for drone and DSLR batteries.
Posted : 19/06/2018 9:55 am
Converting 12V DC to 230V AC to immediately convert back to 10V DC is surely madness.
Posted : 19/06/2018 10:11 am
I bought an inverter and it's only been used once, we just plug in on site if there's power or use 12V stuff if there's not.  A decent size leisure battery means you can have (disco) lights on and bangin' choons when it gets dark 😀
Posted : 19/06/2018 10:16 am
Agreed. And even if your laptop is 19.5V etc it is more efficient to go 12-19.5V DC rather than via AC and an inverter. It can leave you with a hell of a lot of different bits of charger though instead of the AC solutions you already own.
For an engineer, yes, but for a human being just wanting a quick solution, it can work quite nicely.  Because inverters are cheap and widely available, you probably already have the 240V adapter for your equipment, and the total power drain is low anyway even if it's inefficient.
I put an inverter in our old van for this purpose, it was simple and it worked.  Finding laptop 12v power supplies is (or was, at the time) really quite difficult, especially as laptops need all sorts of different voltages and plugs.
Posted : 19/06/2018 10:27 am
2010 Lbw Sprinter. Heating and cooking not necessary .
Posted : 19/06/2018 1:23 pm
"Finding laptop 12v power supplies is (or was, at the time) really quite difficult"
these days there are whole websites dedicated to incar charging of laptops via 12v where you input model number and it spits out the charger you need.
as i said in the first post - work out what you want to run off 240. you might find its actually nothing that cant be overcome or bettered with 12v options - even in 18 months of use I've still never found anything want in the van that needs 240 , even the wife does without a hairdrier - not that i would see a 240v hairdrier lasting long on battery - even with 2 x 115ah batteries and 200watt solar on the roof.
ive im on site ill plug in to 240v if its included in a flat rate fee for campers (which it often is on small sites with limited space) but i just run the fridge off it to save on gas - with the solar on the roof batteries rarely need charging.
2010 sprinter should be fine with a VSR or split charge relay - no need for a b2b charger.
12voltplanet and simplysplitcharge both sell kits with everything you need to just add battery + circuit diagrams.
halfords do a 115ah leisure battery for 70 quid in their frequent sales , i went with them as they have an easy acccess no quibble swap over warrenty - places like tanya batteries are a night mare to return too....
Posted : 19/06/2018 2:14 pm
Also with an inverter I can charge power tools if needs be. Leisure battery for 12v lights inside, radio etc.
Posted : 19/06/2018 6:27 pm
travelvolts is a good site. Does kits to fit transporters, but if you call him has loads of advice and will if you are lucky make cables with connectors etc for some special cases. I managed to fit split charge, solar, and hookup in my van with absolutely no previous idea or clue whatsoever at all using one of his kits.
Posted : 19/06/2018 9:18 pm
