New netbook won't boot as this file is corrupt:
\windows\system32\config\system
Advice is to repair using original Setup CD
1. Don't think I have this CD
2. Netbook has no CD drive
Any ideas please?
make a bootable USB stick. You will need a copy of XP though...
Can I do that from another XP machine or will I still need install discs?
you still need the disks - the boot compiler copies the install files over to the USB stick.
Got it - thanks Stoner
Get a cheap CD reader to plug in to run the discs, think I had to make my own recovery copy on USB stick for my daughters netbook
In fact know I did because I had to buy an 8gb one, might be a good idea to do that when you get it going again
Serial number for the OS should be on a sticker underneath the machine
Think each machine is different, but I have the aforementioned recovery stick for a Toshiba netbook, but its Windows 7
If its new could you not take it back?
I had to do this for the mother inlaw last night. What Netbook is it?
I bought a usb cdrom drive to do it but you might not need it as it may have a partition for a restore.
You tried running a chkdsk? It [i]might[/i] sort it without having to resort to a reinstall
[url= http://www.ubuntu.com ]Ubuntu[/url]
Forget XP.
Download Ubuntu onto USB stick and install.
Only a recent convert. Impressed with ease of use etc.
She had exactly the same error message, when you restart is continue to press F2, you'll then get into the BIOS, then disable the fast boot option. Once you've doen that restart it again, then you'll get the option to restore the machine. If you do not disable the fast boot it does not boot up properly and cannot perform system restore.
Thanks all - it's an Acer Aspire One
Second Ubuntu. Can't beat free and better.
Exactly the same as I fixed, follow the instructions above.
Good grief. Right. Config\system isn't a file you can copy off the CD. It's part of your registry and unique to your PC.
It's worth a punt on Last Known good here. Start your PC, and hit F8 before you get the Windows splash screen (loading screen) - time it right and you'll get a menu giving you options including Last Known Good config.
If that doesn't work there's a good chance that a chkdsk will fix it. If you can get into a recovery console, you can run 'chkdsk /p' which will fix any corruption and -hopefully- resolve the issue. If you don't have a means of booting it, I can give you an ISO of the recovery console which you can get onto a USB key via [url= http://sourceforge.net/projects/unetbootin/ ]UNetBootIn[/url] or something similar.
If that doesn't work, Windows keeps a backup of these files. Hopefully you've got a recent System Restore set which can be used to recover it, and failing that there will be a copy which was created during install. This is more complicated so I'm not going to write it up here until you've exhausted the options above.
bfore ubuntuing, you still need to create the usb, boot disk, using XP, for example. Other than that go ubuntu
If that's a reply to me, I'm not suggesting installing Ubuntu (as I don't believe "format it and start again" is a valid solution to minor computer problems despite what the Linux evangelists would have you believe) - UNetBootIn creates a bootable USB key from an ISO image.
Woo! I said the same as the house [s]geek[/s] computer whizz!
Not really a reply to you Cougar, but XP is a lot to fit into an Aspire. I changed one of mine to ubuntu, and i won't go back. (I have no frigging idea how to!!)
In fact, do me a favour,
Can we all just stop suggesting "install Linux" every single sodding time time someone posts a simple Windows issue please? It's getting as bloody tedious as the iPhone onanism.
I like Linux, but a) it's not the correct solution for everyone and shouldn't be installed uninformed, and b) wiping a system is a last resort, not a first step.
Seriously guys, engage brain before telling people to format their computers. It's bad advice, and it's previously caused me hours and hours of work repairing the damage when people have followed well-meaning suggestions like this without really knowing what they're doing. If you absolutely [i]must [/i]recommend Linux because otherwise your head will burst, please point people in the direction of Live CDs.
Ooh, where'd this soapbox come from? *steps off*
Sam > Geek is fine, I'd consider that a compliment.
Charlie > that wasn't directed solely at you, just to be clear; it's been boiling for a while now. By all means try Ubuntu (the netbook remix is pretty funky), but run it from a USB key and try before you 'buy'.
Oh,
Sam > chkdsk is the most likely to work, you're right; I only suggested LKGC first because it's considerably easier to try. (And I wasn't clear, but if LKGC works you'll still need to do a chkdsk, but you can do it from within Windows then).
[i]Woo! I said the same as the house geek computer whizz![/i]
But I haven't said anything yet.
Geek fight!
Make a USB backup before it goes wrong for netbooks...dam too late.
I take it you have a spare pc etc - make a bootable USB with system repair or windows boot.
Thanks - yes I have an identical netbook which does boot! So will make a bootable USB or DVD (got an old external drive) and give that a try. What causes these corruptions?
I disagree with most of what cougar says on this thread. He is all over ever IT thread on this forum like a rash, dispensing one sided advice on how to resolve IT issues. Repairing Windows is just a sticky plaster on a festering rancid wound, installing Ubuntu is rejuvenation and the elixir of life, as well as a universal panacea.
Ubuntu all the way. Every time.
Waderider - dispensing one sided advice
Let's see... from this very thread:
Cougar - I like Linux
Waderider - Windows is ... a festering rancid wound
One sided?
Pardon me for trying to be helpful. The way I look at it is, I'm a total neophyte when it comes to bikes but at the risk of blowing my own trumpet I'm kinda pretty good at my job. By piping IT help and advice in, for free, I feel that I can ask stupid MTB questions and ultimately karma is balanced. I can stop doing it if you like?
Anything "every time" is patently wrong. Single speed every time. Full suss every time. Helmets every time.
(follow-up edit deleted, I can't be arsed)
