Window update issue
[Closed] Window update issue
6 Users
For some reason my pc is trying to install the same 5 updates every time I close it down. I've tried manually updating and running a tool from the MS website. Any idea how to make it forget these updates?
Posted : 28/01/2015 9:00 pm
WindowsUpdateDiagnostic.diagcab
Posted : 28/01/2015 9:29 pm
Likely one of them is failing and it will roll back all the updates then do it again on next reboot.
Go into Control Panel and Windows Updates and try them one at a time. Takes a while and is a pain but chances are they'll install fine individually.
I wouldn't be trying to ignore them, there are some critical security fixes at present, as there usually are. Flash player fixes in particular is important as the scammers are using the vulnerabilities for ransomware, and there have been several security flaws recently.
Posted : 29/01/2015 1:12 am
A) what os?
B) malware scan.
Posted : 29/01/2015 1:51 am
Mine did this, no amount of MS diagnostic tools sorted out. Eventually wiped and re installed Windows, together with fitting a new fan it runs like new at 5 years old.
Posted : 29/01/2015 7:37 am
you can "hide" updates so they're not run.
Posted : 29/01/2015 7:56 am
To answer the questions above:
Windows 7.
Malware check has been done, nothing found.
Most of the updates relate to .NET 4.5
Trying to install them separately and the main .NET 4.5 fails with error code 643.
I'm now trying the MS tools for repairing the update then it's a case of uninstall .NET 4.5 and reinstall.
Posted : 29/01/2015 11:11 am
Not so critical with .NET 4.5 then. Some programs will be using it, but just uninstall and reinstall if you like or leave it uninstalled and see if things still work. If the programs installed aren't using the latest features in 4.5 then they can work with earlier versions if they're still installed. Sometimes they just ship with the latest regardless.
Posted : 29/01/2015 11:28 am
The MS Fix It didn't work nor did their NETfixer. Couldn't uninstall it or repair it with the tool either. Hiding the updates relating to .NET 4.5 seems to allowing the other updates to install.
Posted : 29/01/2015 12:35 pm
Try deleting C:\Windows\SoftwareDistribution\Download and then re-running WU.
Posted : 29/01/2015 4:10 pm
Failing again. I'll leave them hidden.
Posted : 29/01/2015 4:29 pm
