Will a stove fan wo...
[Closed] Will a stove fan work on a radiator?
4 Users
I can't see why not.
We have an open plan kitchen / diner area with a vaulted ceiling which leads up to the landing, the only radiator in that area is a powerful one at the bottom of the stairs. Obviously most of the heat rises to the landing, I was wondering if a stove fan would help push the heat out into the kitchen / diner area opposite the radiator.
A ceiling fan at the top of the stairs is not wanted or practicable.
Our plan B could be a plinth rad under the kitchen units at the far end of the kitchen.
Ta.
Posted : 01/11/2012 7:38 am
Stove fans need a higher temperature than you can get from a radiator. You can probably buy a clip on convector if you want
Posted : 01/11/2012 7:47 am
How hot does it get?
The stove fans I've seen (and I'm also making one) use a peltier device to generate the electricity for the fan. The hotter the surface they rest on, the more power you get (that's a massive simplification).
My stove gets to about 160 deg c which is pretty hot, but typical for a stove. I don't think (I hope) a radiator will get anywhere near that.
So no, I don't think it will work. If it does, it will run much slower.
Posted : 01/11/2012 7:49 am
I dont think so, heres why
1: the fans aren't that powerfully what they do is help setup a powerfully convection current, you have a vaulted ceiling so the heat will rise there
2: the fans work from 65°C – 345°C and at the lover end aren't that powerfull
I think plan B would be best
Posted : 01/11/2012 7:50 am
