Why are the USB por...
[Closed] Why are the USB ports and SD card reader on my laptop becoming less reliable?
7 Users
Posted : 03/06/2014 11:29 am
If you use them a lot it could be wear and tear if they are plastic.
If it's just certain things not working how they used to when connected then check there are no firmware/driver updates available.
Posted : 03/06/2014 11:42 am
Mechanical systems are far more likely to fail than electronic ones. Wear.
Posted : 03/06/2014 11:45 am
Yep as above wear. The plating on the connectors is quite thin. They could also be dirty, lots of opportunity for dust/grime to get pushed in and compacted
Posted : 03/06/2014 11:49 am
They're bored of you ?
Posted : 03/06/2014 12:01 pm
Can they be cleaned?
Posted : 03/06/2014 12:02 pm
Hoover tu suck out large bits, then isopropyl alcohol on a cotton bud should do if it fits.
Posted : 03/06/2014 12:57 pm
You're a clumsy bugger?
Posted : 03/06/2014 12:59 pm
