Holy cock, JANET's changed a bit since my day.
I remember managing to up the speed on my terminal from 4800bps to 9600bps and thinking my god, the raw power! Kids of today, etc.
[URL= http://www.speedtest.net/result/1556116726.pn g" target="_blank">http://www.speedtest.net/result/1556116726.pn g"/> [/IMG][/URL]
Hmmm... bit of a contrast there
[URL= http://www.speedtest.net/result/1556141427.pn g" target="_blank">http://www.speedtest.net/result/1556141427.pn g"/> [/IMG][/URL]
Quoted as being 30 mbps so happy with that. Still doesn't seem fast enough at times.
Yeah but we is on the cloud innit. Can't watch films or anything because the Igel terminals are so pants.
So far I have the slowest internets on STW! 😮
Must be some people still using dial up somewhere?
On the upside, based on that figure, I'll wager you have the highest shite-per-second rate on STW.
[URL= http://www.speedtest.net/result/1556169242.pn g" target="_blank">http://www.speedtest.net/result/1556169242.pn g"/> [/IMG][/URL]
Paying for up to 20, and my router says I'm getting 17. Speedtest says I'm getting 7.
[URL= http://www.speedtest.net/result/1556170043.pn g" target="_blank">http://www.speedtest.net/result/1556170043.pn g"/> [/IMG][/URL]
Something else on your network using up bandwidth?
No, that'll be you. Oh look you just did it again! More shite!
[URL= http://www.speedtest.net/result/1556305450.pn g" target="_blank">http://www.speedtest.net/result/1556305450.pn g"/> [/IMG][/URL]
Elf - I thought everything was brilliant in London! Why have they supplied you with two tin cans and a piece of string instead of broadband like the rest of us?
In fact, I get a better result from the other side of the world 😆
[URL= http://www.speedtest.net/result/1556316427.pn g" target="_blank">http://www.speedtest.net/result/1556316427.pn g"/> [/IMG][/URL]
Because British Telecom what owns the hardware and the exchanges (what were built using taxpayers money originally) chose not to invest their profits in more hardware and instead provide a crappy residential service whilst offering a far better quality service to Canary Wharf, which runs off the same exchange. This area has the highest line contention rates in the UK, way beyond the 'industry recommended guidelines'.
BT was privatised with the illusion of 'increased competition' and other such guff. This is a fallacy, as they have the monopoly on hardware, still.
Guess who's to blame? 😉
Bloody hellfire Creamegg! 🙁
[URL= http://www.speedtest.net/result/1556344359.pn g" target="_blank">http://www.speedtest.net/result/1556344359.pn g"/> [/IMG][/URL]
adequate
i should point out im in Camp Bastion so all things considered its not too bad.
There are no LLU providers at your exchange then?
Are you using RFC 1149?
??? erm, dunno. whats that?
Blam!
Well done, you have the second fastest ping rate!
(seriously, WTF are you, an ISP?)
IPoAC.
oh right, yes thats it 😉
[URL= http://www.speedtest.net/result/1556444709.pn g" target="_blank">http://www.speedtest.net/result/1556444709.pn g"/> [/IMG][/URL]
I got 85Mb on the second run once the Riverbeds kicked in (I think).
Not showing the linky as we are our own ISP.
Uni of WOE must be P0rn Central
TD your Kung Fu is powerful!
Anyone with >100Mb will struggle to get a speedtest server that can handle the test properly.My PC has a gigabit conenction, which eventually becomes a 10Gb to the internet. It's nice!
if this is a dick waving contest then my download speed would roughly translate to mine equalling the size of a vagina...
Yeah. Ultimately you're only as fast as the slowest component. Usually that's your connection to the ISP (ADSL or whatever), but with sufficiently fast connections your limit is going to be your home WiFi, your router, the rate a server can serve, speeds of various routers along the way, etc.
I'm also good with photoshop 😉
trickydisco - Member
Blam!
Is the speedtest server on your LAN? 8)
[URL= http://www.speedtest.net/result/1556739247.pn g" target="_blank">http://www.speedtest.net/result/1556739247.pn g"/> [/IMG][/URL]
17:30 is probably not the best time to do a "fastest" test?
You Cheat! You used Tonylem's, as the date and time are exactly the same. You should have changed that.
I was waiting for someone to pick up on it 🙂
[URL= http://www.speedtest.net/result/1556768545.pn g" target="_blank">http://www.speedtest.net/result/1556768545.pn g"/> [/IMG][/URL]
Tresco, Isles of Scilly. This connection is shared between 3 people!
Waiting for that one person who has (Slower than 99% of GB) 🙂
Mine's an F, slower than 90% of GB
[URL= http://www.speedtest.net/result/1557206652.pn g" target="_blank">http://www.speedtest.net/result/1557206652.pn g"/> [/IMG][/URL]
Read-em and weep boys....jealous?
<EDIT> Bugger, just seen Alex's.....must downgrade service immediately!
Here's mine.
[URL= http://www.speedtest.net/result/1557213004.pn g" target="_blank">http://www.speedtest.net/result/1557213004.pn g"/> [/IMG][/URL]
Ping's usually a lot lower than that. Hm.
[URL= http://www.speedtest.net/result/1557223624.pn g" target="_blank">http://www.speedtest.net/result/1557223624.pn g"/> [/IMG][/URL]
Girlfriend just switched off her machine so thought mine would run faster!
Nope even slower??
[URL= http://www.speedtest.net/result/1557362307.pn g" target="_blank">http://www.speedtest.net/result/1557362307.pn g"/> [/IMG][/URL]
That's better! Quick reset of the router helped too
[URL= http://www.speedtest.net/result/1557369455.pn g" target="_blank">http://www.speedtest.net/result/1557369455.pn g"/> [/IMG][/URL]
I just wish the upload speed was anything like the download speed. It's taking ages to upload videos to fb, photobucket and pinkbike 🙁
[URL= http://www.speedtest.net/result/1557455254.pn g" target="_blank">http://www.speedtest.net/result/1557455254.pn g"/> [/IMG][/URL]
Not bad. BT promised greater than 19kb and seem to have managed it.
[URL= http://www.speedtest.net/result/1558653241.pn g" target="_blank">http://www.speedtest.net/result/1558653241.pn g"/> [/IMG][/URL]
Rural Lancashire
