but the actual equation should be (50-50)/100 = 0% effective
Meant (50-50)/50 = 0%
I’ve just listened to the BioNTech boss on news night – the 90% efficacy means 90% reduction in symptoms.
I have it in my head the Ox/Az 70% is actually reduction in infection rather than Symptoms. They also have had no serious cases.
Didn’t they routinely screen the Oxford subjects irrespective of symptoms but only tested people who had symptoms for the biontech vaccine, so asymptomatic cases in the mRNA trial would be missed, so the Oxford vaccine might actually have a similar efficacy when that is factored in.
Yes, that was what I was trying to get at!!
Yes I know and that is what I stated – 50/50 is zero effect
Sorry Mudmuncher - I misunderstood your point. I think I'm probably conditioned to answering super-basic questions from elderly relatives!
@mudmuncher: no
Two key points:
1. The unblinding criterion. They roughly said "we'll stop and take a look when we get 100 infections detected". It's true that if the vaccine does nothing then when you look then you'd expect close to 50-50, but really what you're saying in that scenario is "in <however long it takes to get 50 infections in unvaccinated people> we got 50 infections in vaccinated people". However, imagine if the vaccine were perfect, then your first 100 detected infections would all be in unvaccinated people, and it would have taken twice as long to get there. Those unvaccinated people weren't affected by how good the vaccine is, so the effectiveness of the vaccine has a big effect (up to 2x) on the time at which you stop and look at the data!
2. Because of 1, your denominator is wrong. Easy way to think if it is "when we stopped and took a look, 70 unvaccinated people had been infected. If the vaccine did nothing then we'd have expected 70 vaccinated people to have been infected by then too". (It doesn't matter that if it *did* do nothing then you'd have got to the magic 100 sooner.) The sum then becomes "out of 70 people in that group who we'd expect to be infected if the vaccine did nothing, we actually only got 30 infections. So 40/70 were protected by the vaccine."
Del
Bit unfair chaps. Consider his position.
Appreciated but a bit of banter is all good. (Appt with consultant today I'm very optimistic about)
It looks like i’m getting it in the next couple of weeks so will report back if I grow scaly green skin
See what I'm saying is this government has a history of making political appointments and where it can't creating a kwango.
The effect of that is a reluctance to feed non ideal news upwards.
You tell your boss who has to tell their boss .. until ultimately someone has to tell Boris and as it goes through the levels managers are increasingly "politically aware" so a culture develops.
There is a great study in the CAIB (Columbia space shuttle accident investigation board)
The whole report is rather long but here is a summary of this part by one of the board.
The other side is the very low public confidence in the government actually telling the truth, even by its supporters.
They were numbers for illustration, not the reported numbers. Pfizer had a split of 8/162 for 170 infections which is 0.049. Moderna was 11/185 or 0.059. These are remarkable results for symptomatic infection.
AZ did not give the absolute numbers in their press release, only the combined result - probably under pressure to make the number as “big as possible”. It’s most likely 3/30 for the low dose and 27/71. Previously I think they stated 60%, but it now states 62% so these are the numbers.
27/71, the true efficacy, is not 8/162 or 11/185. Not even close. Whether it matters for hospitalisations (none in era has trial) is the question.
Sorry for the confusion.
@stevextc - I agree that organisations rot from the head - see Kingspan / Celotex at Grenfell. If you're the 22 year old being told what to do by the MD you do it.
In this case though I trust the integrity of the middle layer. They've all got families and will be directly affected and will do the right thing.
On a different note, eldest daughter got a message from a close school friend this morning who has tested positive. We kept her off the school bus and prepared for 2 weeks self isolation, informing school absence line. School phoned back to say that they'd assessed her contact and Department of Education guidelines said she didn't count as a contact. She's now back in school.
Weird thing is I've read the Guidance for Contacts and other than not being contacted by Track and Trace I read it as she needs to self isolate. It we do that though, the school will count it as unauthorised absence.
Is it just me or is the system a bit screwed up?
Murrey
I agree that organisations rot from the head – see Kingspan / Celotex at Grenfell. If you’re the 22 year old being told what to do by the MD you do it.
I could tell some other stories but yep, that's the point.
The implicit threat doesn't even need to be that real... just a case of "can't you reword that to make it sound better or less bad we don't want to upset the next layer up who don't understand the technical details"
In this case though I trust the integrity of the middle layer. They’ve all got families and will be directly affected and will do the right thing.
Using my earlier example I doubt the NASA engineers really wanted to kill people. It's more a case of following instructions and passing the responsibility.
I've been in similar positions (though at least not life and death) and it's very stressful unless you pass the responsibility upwards. Understanding managers who say "yes but I have to tell such and such and they won't even understand the technical reasons"
I don't think/hope/believe in this case it will be anything dreadful but this cultural/management style seems overly familiar.
Weird thing is I’ve read the Guidance for Contacts and other than not being contacted by Track and Trace I read it as she needs to self isolate. It we do that though, the school will count it as unauthorised absence.
See my earlier post ... Jnr is back today.
I hear on the news today, that we’re first to approve the new vaccine but that Europe claim their checks are safer than ours.
That's political posturing - the MHRA are better than the French and German equivalents.
The FDA, by contrast, is a slick professional organisation of full-time employees.
+1 the people who stress me out the most are FDA inspectors. I've always found that their approach is that you are a criminal and you are guilty until proven innocent.
Just like the CAA for aviation
Speaking diplomatically about the CAA, that means nothing.
I wouldn't be at all surprised if political pressure was applied to the MHRA in a Trumpian attempt to be first to release, but I'd be astonished if it influenced their decision.
Wouldn't have the slightest objection if I was offered the vaccine. Can't deny however that I'm quietly pleased that ~30,000,000 will be testing it first though.
MHRA are in here auditing as we speak, it ain't a pleasant experience I can assure you.
Well this is my day job and I’m one of those in the middle. I can tell you that the rigour with which data is collected, produced, analysed and debated is staggering. It’s also routinely inspected. I have colleagues who’ve had to stand up in US courts to defend just these points under aggressive cross examination.
More likely, things go wrong with over-interpretation or absence of information. A new drug will typically be approved for a chronic common indication with about 1000 patient-years of exposure. More for some areas (cardiovascular) less (sometimes much less) for rare or terminal conditions like oncology. Vaccines have more patient-years of data, and for these vaccines, assume a median of four months, giving about 7000 patient-years of exposure. That’s typical for other vaccine submissions. You don’t wait long after unblinding a trial for submission. Nothing has been skipped - the agreed (with FDA and EMA) endpoint for registration was infections at 28 days post last dose, not 280 days. The sample size is defined by the power to detect the difference of interest and the rates of events (infections). The collation and analysis of data will have been expedited by throwing people at it, not cutting corners.
If rare events occur, they may not reveal themselves in Phase 3 trials. Anything rarer than about 1/10000 is challenging. Once used widely, post-marketing monitors safety on an ongoing and never ending basis. Vaccines are no different in this regard.
Sometimes disaster happens unwittingly not due to malice. Thalidomide is the textbook example. It passed ALL required safety tests and clinical studies of the time. It was only after release that it showed the devastating teratogenic effects in the first trimester when used for morning sickness. The US did not approve thalidomide NOT due to these effects. It was because the Phase 3 study showed a signal for increased peripheral neuropathy. Right decision for the wrong reason and basically luck. The outcome was increased scrutiny and additional animal teratogenic tests. Thalidomide when used for the right patients is an amazing drug.
[tl:dr] there is always a limit to what can be seen in Phase 3 trials. Rare events are rare and will be monitored in wide use very carefully. Never ascribe to malice what can be explained by absence of knowledge.
I was talking about independence not competence - I’m familiar with the CAA too but thats another story 😉
I've experienced audits from CAA, FAA, EASA, and many other aviation authorities (Chinese Aviation Authority are off the scale bonkers) but MHRA and FDA are another level.
nobeerinthefridge
How do you end up on the receiving end of inspections from both the FAA/CAA and the MHRA?
I'm in Engineering, bailed out of aviation 6 years ago into Pharma. Different business, but Engineering is Engineering.
Do we expect the discussed issues with the Ox/AZ trial to affect MHRA certification?
We have audits in clinical from the individual patient clinic visits (where we employ site monitors), through to data entry, right up to generation of the submission pdf documents. It’s a continuous chain and when the agencies come, they expect to see every part of that chain. All of it in our systems - which they have access to. We also of course submit all the source data and analysis codes for that data to regenerate all analyses. The FDA routinely run their own analyses on the data (and everyone else’s too!).
Manufacturing of the drug product is even more heavily inspected! That’s noBeer’s day job.
As I said, it’s not malice or poor practice, it’s knowledge gaps.
I always love the idea that fda inspectors are actually allowed to carry guns as the are federal agents.
the thought that always amused me was the idea of someone running across a car park with paperwork being winged by one to stop them getting away.
On a serious note, all the gmp inspectors and agencies I have interacted with (Fda, mhra, cofepris, ema, and others) are all independent and take their roles incredibly seriously. The are nice people generally but they are incredibly thorough and will dig if there is something they don't like (annoying when it is their opinion though not in the regs).
As tired said, the vaccines are safe for use of authorised, but there is always a risk of rare events causing issues -this is the reason for the mhra yellow card system which is for reporting adverse events and also the reason pharma companies have pharmacovigilance groups that follow and monitor for any safety issues post approval. in addition the pfizer vaccine has been approved for temporary use so if anything comes up during use the chances are it will be pulled from further use immediately
Edit for context- I worked for 12years in gmp qc labs and now am a gcp auditor.
the levels of auditing required are substantial and by both internal local groups and internal independent groups. This is in addition to corporate audits and of course the regulatory inspections
I expect the guys at Cobra the manufacturer who filled the vials for one arm of the OX/AZ study are sweating. I would still expect approval of the standard two doses. Not the low dose until another trial.
Presumably they can refine the size of dose in a trial run parallel or at least concurrent with their phase 3? In which case if they get approval based on phase 3 two full dose they can expect quick approval on changing the volume of the first dose if that is demonstrated to be more effective?
Steve, I understand your concern and more broadly I've heard it voiced by plenty of others for various reasons, but in my view you're over-thinking. There are many reasons this is happening so quickly. The primary drivers in my view are that there really is no limit to the amount of money that can be thrown at this objective and neither is there a practical limit to test subjects.
What I find really notable about the guests on the r4 program, who are in positions where knowing your shit is not optional, when asked if they would take this vaccine not one has hesitated to say yes.
Also, for those in their 20s, 30s or 40s who don't feel they're at any great risk from the virus, and view getting the vaccine as more of a potential risk for little gain, it's worth pointing out that by the time it's available to them it will already be in the arms of those for whom the risk vs. reward calculation is quite different. The risks will be well known by the time it's their turn.
Probably best to avoid threads entitled "The Coronavirus Discussion Thread" then 🙂
You can hardly complain about that considering you clicked on it.
There are tons of other topics on here. Coronavirus has been limited to just a few threads
, I understand your concern and more broadly I’ve heard it voiced by plenty of others for various reasons, but in my view you’re over-thinking. There are many reasons this is happening so quickly.
I think batfink's post a few days back covered this very well, think he's involved in Australian drug licensing. It answered all the questions I had
If I read it correctly, we have half a million threads on the forum and someone came on this one to complain about Covid threads 🤔
This thread really is one of the best things on STW right now. It's fascinating.
Having seen other Coronavirus threads on other forums this one stands out as having real frontline insight from a group of people who are willing to share what can’t be learned from watching a YouTube video on how to be a pharma/vaccine expert.
There is also very little dick swinging just a willingness to educate and explain.
It’s priceless.
For anyone who doesn’t see the value in that they can piss off to Facebook.
Del
Steve, I understand your concern and more broadly I’ve heard it voiced by plenty of others for various reasons, but in my view you’re over-thinking. There are many reasons this is happening so quickly. The primary drivers in my view are that there really is no limit to the amount of money that can be thrown at this objective and neither is there a practical limit to test subjects.
Firstly good news from consultant ... that out of the way I don't personally have any ieeues with the vaccines, indeed just spoke to my octagenarian mother saying the same.
With her auto immune system and age risk of complications from SARSA-Cov19 >> possible risk from vaccine.
However my mother is a perfect example ... she has zero trust in anything this government tells her and its been lower every week since she voted for Brexit and believed that.
@mudmuncher: no
Two key points:......
@gray, thanks, I see where I was going wrong now.
If it’s 29/70 really need to think in terms of 140 infections rather than 99 which is what it would likely have been with an ineffective vaccine.
It’s 3/30 (90%) and 27/71 (62%), combined 30/101 (70.3%). I think they originally said 60% and 70% but this is now on the press release. They definitely saw 131 total infections. I'm running an analysis to compare the various vaccine arms.
If you're rich you don't have to quarantine
Makes no logical sense. Lewis Hamilton despite being rich and in a tremendously well organised F1 bubble got COVID. Why would we allow random CEOs "whose work creates or preserves 50 jobs" skip the sensible rules to stop transmission?
What's this bit?
as of 15 December people will be able to pay for a private coronavirus test to reduce their isolation time to as little as five days, as long as they return a negative result.
Is this only for execvs and sport/celebs or is that for everyone.
Still no-one has explained to me why someone with 2 negatives tests a week apart is a bigger risk than someone who hasn't been tested.
I just watched the ITV report on Russia. Absolutely horrific. Body bags piled up against walls and in corridors, virtually empty cemeteries now full.
There is absolutely no doubt that countries with authoritarian, (excluding China) populist leaders have faired very poorly in their response to Covid.
Including the UK I'm ashamed to say.
To our resident experts - are we close to licensing antibody treatments for severe COVID and will any be available?
Only dexamethasone has been shown to be efficacious in doubleblind randomised clinical trials. The next on the list is a class of antibodies against a pro-inflammatory cytokine called GM-CSF. We will see. Then will come the antiviral antibodies, but these have failed in US studies not hospitalised patients. Antivirals should be given early for prevention. Other treatments for emergency use are the JAK inhibitor baricitinib that has emergency use. I collate a database of about 80 treatments undergoing testing. There are many assets but relatively few modes of action.
One could claim that prevention by vaccination is a good outcome. Reducing COVID-19 to a dry cough would be a very good outcome with sufficient vaccine coverage. That coverage will be 2H21 when the mainstream spike protein vaccines come to bulk up capacity.
Nothing approved on the immediate horizon I am afraid. GMCSF has four mAbs in trials.
I think batfink’s post a few days back covered this very well, think he’s involved in Australian drug licensing. It answered all the questions I had
Welcome. I'm based in Australia (previously the UK) - but I run global trials. Not involved in covid, other than figuring out how to keep my trials running through various states of lockdown. Currently trying to figure out how to run a lung cancer study in Bangladesh and Sri Lanka.
Fun fact - one of my trial patients in China (Wuhan!) had covid back in Oct 2019. We didn't know it was covid at the time - just a really nasty pneumonia that required ICU.
Is this how Liverpool managed to go from the worst in the country to being dropped to tier 2?🤔
2nd / Booster injection on the Novavax trial for me yesterday. No side effects etc.
Speaking to the consultant no body he has seen on either the active dose or placebo has mentioned any side effects..
Back in 2 weeks for a general check up.
The Pfizer vaccine was mentioned, basically that in the rare chance I’m offered a dose, to call them and the will “unblind” me so I can decide.
They are hoping to know the efficacy of the Novavax one by the 2nd week in January.
Let’s hope it’s another weapon hey!
My only dissapointment is that so far I haven’t been given a lollipop or a sticker saying I was a brave boy. It’s a bloody big needle! 😂
I imagine it must be hard to get patients to sign up for a trial that has a 50/50 chance of being offered a placebo, when they think they can have Dexamethasone instead?
Considering that even now it's Joe Public's best chance of being vaccinated ASAP I'd think not.
Sorry - a drug trial in hospital on potential new treatments.
That’s not quite how it works. Once a medicine has proven efficacy it becomes “standard of care”. Then the future tests will be against either the historic placebo patients or the active concurrent standard of care.
We don’t really like historic controls. Patients being treated in the NHS RECOVERY trial now are getting better management than they did in April - even before dex was approved. Mortality has called by 25%. Also because of this, the gap for improvement is smaller (incremental benefit) and smaller differences need more patients to show significant differences over chance.
Oncology is the classic case in point. Standard of care now looks nothing like it did ten years ago for many tumour types. Other diseases have placebo issues. It’s still just about ethical to use placebo in Rheumatoid Arthritis but not for too long. It’s not for Multiple Sclerosis trials. Instead active controls drugs are used that don’t work very well. Mild but chronic diseases and diseases with no approved treatments still use placebo, normally on top of standard of care.
Vaccines are not therapeutic, so pure placebo is an ethical option.
[th:dr] We say placebo-controlled, but normally it’s placebo plus standard of care because of ethical concerns.
