Whats the bst way t...
Whats the bst way to reduce a bolt head diameter
I need to reduce the heads of atleast three bolts* to fit a counter bored hole.
What is the most accurate and least faffy may to get something relatively accurate. I have drills and a bench grinder which feels like a quick way to do something silly.
Ideally i would ise a lathe, and indeed... I do actually have lathe... Slight flaw is these are the bolts that hold the chuck together after i lost the originals. Three minimum to hold it together to then turn 6 goodies.
They need to be fairly accurate as the os hee haw lip to work with.
Posted : 16/08/2024 2:01 pm
fruitbat and fruitbat reacted
What size do you need? I could turn them up in my lathe and pop them in the post to you. Otherwise, electric drill and bench grinder but it won't be very accurate.
Posted : 16/08/2024 2:03 pm
Yeah I would stick them in your drill and make a rest so you can lay the drill on something solid while you spin against the direction of rotation and approach the grinder.
I'm always making dowels like that, though on a sander and in wood.
With a more elaborate rest, you could probably rig up something to give you repeatable diameters (near enough)
Posted : 16/08/2024 2:04 pm
That would be ace!
I need M5x0.8. 6.5mm dia head. 25mm thread length.
Posted : 16/08/2024 2:09 pm
What head is it now, hex , socket, pozi etc ?
Posted : 16/08/2024 2:56 pm
Well there are no bolts at he moment historically they were imperial slot, cap heads from memory, however with judicious use of an m5 tap i am half way to being in action!
Posted : 16/08/2024 3:12 pm
Ignore
Posted : 16/08/2024 4:01 pm
Could you use the drill/grinder method to make some which are ok as a short term bodge, just good enough to hold the lathe together whilst you use it to make some proper decent ones?
Posted : 16/08/2024 4:13 pm
Are you sure they're M5? That's very small, my mini lathe's chuck is held on by M8 bolts and looking online they're usually M6 or M8. Or is it a watchmakers type lathe?
Posted : 16/08/2024 5:00 pm
Its the actual bolts that hold the chuck shell together.
The lathe is um... A bit niche.
One of theseย  https://www.mig-welding.co.uk/forum/threads/drummond-round-bed-lathe-no-1.82954/
With the same treadle motor. The particular chuck is a 3inch chuck, its the only one that currently has a backplate so once i get this one back in action i can bootstrap it.
Posted : 16/08/2024 5:07 pm
Cool looking lathe - I've messaged you, I can put them in the post tonight
Posted : 16/08/2024 5:15 pm
I've replied ๐Ÿ™‚ cheers!
Posted : 16/08/2024 5:39 pm
I would think of something like a large grub screw. Due to no head on it, something like an M5 would use an M3 hex or allen key
https://www.ebay.co.uk/itm/221524116308?itmmeta=01J5E0JQ0J7YD9SATHV9F8GWPM&hash=item3393ddc354:g:mXwAAOSwGvhT7fYn
Different sizes and lengths available
Posted : 16/08/2024 6:34 pm
A home based lathe - nothing better in the world for turning perfectly good bits of steel into useless swarf!!!!! ย (Speaking from experience)
Posted : 16/08/2024 6:59 pm
