What wood moisture ...
[Closed] What wood moisture meter?
12 Users
Looking to get myself a wood moisture meter. Any recommendations on which one? Was just going to pick up a Stihl one. Don't mind spending out on a good one but nothing too expensive!
Oh and happy new year to everyone.
Regards,
Gareth
Posted : 31/12/2015 1:10 pm
I bought a meter off eBay that looks identical to the Stihl one. One of the pins has pushed in and doesn't register anymore. Crap.
If you're wanting it for wood you burn I wouldn't bother. You know if the wood is dry enough with the weight when you pick it up.
Not much help I know.
Happy New Year pal. 🙂
Posted : 31/12/2015 1:34 pm
Stack wood this year, burn it next year.
Unless you just want a new gadget, that's completely understandable!
Posted : 31/12/2015 1:38 pm
You can just by looking at wood if it's dry or not....
Posted : 31/12/2015 1:40 pm
or you could try passing a current through the log and then measuring the resistivity. higher moisture = lower resistivity.
hope this helps 😉
Posted : 31/12/2015 4:42 pm
I got a cheap stihl-a-like either ebay or amazon, it actually seems to work reasonably well (I have checked by weighing bits of wood over several weeks/months, mass loss is consistent with moisture reduction).
Having said that, I don't really use it now, it's usually obvious enough by feel how dry the wood is. And only measures the outside anyway unless you split a piece each time. But having the meter did help to learn the feel of wet/dry wood.
Posted : 31/12/2015 5:09 pm
 joat
Knock two logs together, you should get a nice note, rather than a dull thud, though I'm not sure whether it's a D Or C flat.
Posted : 31/12/2015 5:17 pm
Got one that came with the stove, not even opened it and put the batteries in it. For burning, I don't think a cheap one will tell you anything that your senses can't.
If you are looking for furniture making, you probably want something more expensive or a better timber supplier.
Posted : 31/12/2015 5:34 pm
I've got one of [url= https://www.westfalia.net/shops/electronics/measuring_and_testing/measuring_and_testing_equipment/moisture_meters/206642-moisture_gauge_0_60.htm ]these[/url]. It works fine but if you leave the batteries in they go flat
Posted : 31/12/2015 7:38 pm
Thanks all. I've been producing firewood for almost twenty years so am pretty competent at seasoning wood. I just thought that I might get one as, like most things, one take it to another level and can become quite a geek!
Happy new year folks,
Gareth
Posted : 31/12/2015 9:20 pm
Gareth, ignore the grumpy knowitalls!
They are handy things to have around. My cheap £10 eBay one has been fine. I use it several times a year to test different seasoning techniques. They're rarely calibrated but for relative analysis they're fine.
Posted : 31/12/2015 9:26 pm
Curiosity got the better of me after I dismantled a holzhausen to see how well it had dried the wood. I bought a Stihl one, they are much smaller than they appear in pics, about the size of a credit card. I've been randomly checking the drying rate of of other holzhausens to decide on their optimum shape.
Posted : 31/12/2015 9:37 pm
Thanks Stoner and mcmoonter. Like I've said I've been producing firewood for quite a while but since reading that Lars Mytting book I fancy going a bit more in depth with the whole seasoning process and experimenting with different methods of stacking etc. Slightly spurned on too by recently treating myself to a lovely Wetterlings splitting maul as a leaving present to myself.
G.
Posted : 01/01/2016 2:25 am
I had a cheap one off eBay that was fine until it stopped working for unknown reasons - no idea how accurate it was but as Stoner says, they're good for relative comparisons.
Sister has just bought a Stihl one which seems very good.
I'm now working at least 12 months in advance of when I need the wood so not bothered with a meter as I know the wood is going to be dry by the time I actually use it.
BTW, MM thanks for the heads up on the Laars Mytting book - got it for crimbo, excellent reading.
Posted : 01/01/2016 1:02 pm
