What physical shop ...
[Closed] What physical shop (now maplin is dead) can i get a 10m Modem/adsl cable from?
Ideally need one today so want a physical shop (chesterfield/sheffield) - is it an rj11?? on each end
Posted : 27/06/2018 1:06 pm
RJ11 at both ends generally, yes.
10m?  Move your router.
Posted : 27/06/2018 1:09 pm
Wilkinsons/Wilkos might have them (they seem to have shops in most towns).
Wilkos
Posted : 27/06/2018 1:10 pm
Currys if you want a gold plated super high performance oxygen free one that will boost your internet connection...
Posted : 27/06/2018 1:12 pm
And local computer repairs shop?
B&M or Home Bargains are another possibility
Posted : 27/06/2018 1:13 pm
cougar - erm thats what i'm doing......by10m!!
Posted : 27/06/2018 1:17 pm
Amazon prime
Posted : 27/06/2018 1:18 pm
cougar – erm thats what i’m doing……by10m!!
Oh, ok then.  Don't move your router.  What are you trying to achieve?
Posted : 27/06/2018 1:19 pm
i need a cable to be able to move the router further form the entry point in the house - hence asking for the longer cable? not sure what you think i'm asking?? router is in the kitchen currently as is the telephone/modem socket. I want it in the lounge.
currently run a cable for the phone into the lounge from kitchen and wish to do the same for the router
Posted : 27/06/2018 1:24 pm
Andy that is exactly what i want 🙂
Posted : 27/06/2018 1:26 pm
 Ewan
Argos...  http://www.argos.co.uk/search/phone-extension/
Posted : 27/06/2018 1:35 pm
 Ewan
Note, you may loose some speed by having such a long extension. Try to get the best quality one you can find.
Posted : 27/06/2018 1:36 pm
can't use a phone extesnion cable as the master plug in the kitchen is split - phone AND modem socketS
Posted : 27/06/2018 1:47 pm
i need a cable to be able to move the router further form the entry point in the house – hence asking for the longer cable? not sure what you think i’m asking?? router is in the kitchen currently as is the telephone/modem socket. I want it in the lounge.
Yes, but, that doesn't answer my question.  What are you trying to achieve - why do you want to move it?
This is where I'm going with this.  Extending the DSL cable in the manner you suggest could well have a severe detrimental effect on the line speed / quality.  Unless the reason you want to move it is aesthetic, there's probably a better solution to whatever it is you're trying to do.
Posted : 27/06/2018 1:48 pm
purely aesthetics and practicality of where it is situated. No internet connected devices in kitchen, tv in lounge and where we spend a lot of time.
Posted : 27/06/2018 1:57 pm
broadband is around 30mb so not super fast - not sure that the cable run (which is only about 8ft longer than the cable that is supplied) will have that much of a detrimental effect on performance and it means i can hardwire the tv as opposed to using wifi
Posted : 27/06/2018 1:59 pm
You'd be amazed how much a longer phone cable can add noise to the line and therefore may drastically reduce speeds.
If you are looking to hardwire the TV then you'd be better getting a Network switch and a 10m Cat5 cable and running that from the router to the living room.
General advice is to have the router/modem as close to the phone socket as possible and have as short a cable as possible.
Plus the switch will give you 5/8/16 sockets to plug stuff into.
Posted : 27/06/2018 2:03 pm
leave the router where it is, run ethernet to the other room.
Posted : 27/06/2018 3:44 pm
^^ What @H1ghland3r and @grumpysculler said.
Are you confusing feet and metres?
Posted : 27/06/2018 3:51 pm
If you do need a longer cable, worth getting something actually designed for ADSL, not just a phone cable. ie twisted pair, not a flat cable. It will be a lot better for avoiding interference etc.
Kenable are good, they have this one for £2, usually pretty quick delivery. https://www.kenable.co.uk/en/adsl-rj11-cables/7940-kenable-adsl-2-high-speed-broadband-modem-cable-rj11-to-rj11-10m-black-007940-5055383479405.html
Posted : 27/06/2018 4:47 pm
Not suggesting it's optimal but I've got a 25m run of that cheap + shitty flat white telephone cable between phone point and modem, including about 5m worth coiled up then knotted through a load of other wires.  Still get 50 odd meg through it, never loses sync either.
I know it's brain dead, f knows why I set it up like that, but it does work.
Posted : 27/06/2018 6:03 pm
Current cable supplied by ee is 3m long I need it to be 6m
Posted : 27/06/2018 7:35 pm
