What happens if you...
[Closed] What happens if you try to freeze water if it can't expand?
30 Users
Say you fill a strong water proof safe with water then take it to well below freezing - does the water stay liquid as long as the safe doesn't break?
Posted : 12/01/2010 9:49 am
Is it on a conveyor belt?
Posted : 12/01/2010 9:52 am
 Bez
Yes, if it truly can't expand it'll remain liquid. But don't underestimate the forces created by the water, they're huge. You'd need one hell of a safe to withstand it.
Posted : 12/01/2010 9:53 am
it possibly wouldn't be an issue unless you removed all the trapped gases from the water first and completely filled the safe. Otherwise it wouldn't cause a problem. Are safe doors watertight too?
Posted : 12/01/2010 9:55 am
is it expensive water?
Posted : 12/01/2010 9:56 am
Does a variation on Boyle's law apply?
Posted : 12/01/2010 9:59 am
So with a hypothetically unbreakable container completely filled with pure water, devoid of dissolved gases, etc. and taken to below freezing, the water would remain liquid, right...?
Wow.
If the increase in volume on freezing is prevented, an increased pressure of up to 25 MPa may be generated in water pipes; easily capable of bursting them in Winterb. An interesting question concerns what would happen to water cooled below 0°C within a vessel that cannot change its volume (isochoric cooling). Clearly if ice forms, its increased volume causes an increase in pressure which would lower the freezing point at least until the lowest melting point (-21.985°C) is reached at 209.9 MPa.e A recent thermodynamic analysis concludes that ice nucleation cannot arise above -109°C during isochoric cooling [1053], which is close to the upper bound of the realm of deeply supercooled water (-113°C), so it is unclear if ice would ever freeze in such a (unreal) system.
from [url= http://www1.lsbu.ac.uk/water/explan2.html#Pmelt ]here[/url]
Posted : 12/01/2010 10:00 am
If it cannot expand and the container is totally rigid (this is a totally hypothetical container as nothing is totally rigid) then the water would eventually freeze solid with the solid being compressed to the volume of the container. At exactly what temperature, and by implication pressure, this would happen I couldn't say as I don't have access to compressibility data for water.
Posted : 12/01/2010 10:02 am
209.9 MPa
Over 30,000 psi.
what tyres for 30 000 psi?
Posted : 12/01/2010 10:04 am
 Bez
[i]what tyres for 30 000 psi? [/i]
Ice tyres, natch.
No that's for gases and I'd say the university report quoted by mrmichaelwright is far more likely to be correct than I am as I was extrapolating from my limited knowledge of the thermodynamic properties of water.
Posted : 12/01/2010 10:07 am
 Olly
it would remain a liquid.
interestingly, this can be observed in a somewhat risky phenomenon, by putting bottles of beer in a freezer, and forgetting about them, most of them will freeze, and/or crack the glass.
but occasionally, one will not freeze, and upon opening, instantly freeze and shatter the glass.
i think the bottle has to be 100% free of dust inside for it to work?
can work at the other end too, if you microwave pure water (distilled) in a clean mug, until its past boiling point but not boiling, and then throw a pinch of salt at it, it can explode as the salt hits it.
Posted : 12/01/2010 10:09 am
from my limited understanding of the above i think it would only remain liquid until -21.985°C
Posted : 12/01/2010 10:10 am
I'm not clear why you mention dissolved gasses - how are they relevant, apart from lowering the melting point very slightly as all dissolved substances do ? Pressure lowers the melting point of water - that's why ice is slippery
Posted : 12/01/2010 10:12 am
that was my understanding as well but the article i posted states that even ice skating does not alter the melting point enough to melt the ice through pressure so that may not be strictly true sfb.
Of course the article may be complete tosh.
Posted : 12/01/2010 10:15 am
I remember seeing photographs of an demonstration where ice within a thick steel ball was frozen. Bits of steel were found in the wall!
Posted : 12/01/2010 10:22 am
That'll be 'water' was frozen rather than 'ice' before the STW pedants arrive 🙂
Posted : 12/01/2010 10:25 am
I'm pretty sure that SFB is correct. When you ski and snowboard you are actually riding on liquid water, not snow. This layer of water is probably no more than a few hundred molecules thick but it is liquid none the less. It's the reason that when it's really cold (-30/-40C) that snow become sticky as the pressure that it applied by you isn't enough melt the extremely cold snow.
Posted : 12/01/2010 10:26 am
mmw - take an icecube and crush it in your teeth carefully and controlled - you can melt the ice away far faster than if you just hold it in your teeth with no pressure. While not conclusive, I'd expect I create as much pressure with my skates as I could with my teeth.
midgebait - sounds about right, a car engine typically compresses to about 700psi, one can only imagine what 30,000psi would do 🙂
Posted : 12/01/2010 10:29 am
coffeeking/fishin, one atmosphere of pressure relates to an increase in freezing point of 0.007 degrees C, not sure what the pressure under skis is but i doubt it is significant enough to cause regelation. Skating perhaps though at the very point of the blade enough pressure is applied
again, this is based purely on 'internet knowledge' (tm)
if the pressure under skis is enough to melt snow then wouldn't you just sink if you stood still 😆
Posted : 12/01/2010 10:35 am
That is how it works. It's the reason why skis/boards don't (or shouldn't) have a smooth base. The texture on the base helps the water flow out from beneath the board/ski. Remember very little of the available area of skis/boards is actually in contact the snow.
Posted : 12/01/2010 10:40 am
hmm, i see what you say
An average contact spot size of 110 ?m, and a relative real contact area of 0.4% [between ski and snow] has been found.
that is a quote from the abstract of a paper on the subject.
interesting stuff, i like learning smarts.
Posted : 12/01/2010 10:45 am
correct 🙂
uh, increasing the pressure [b]lowers[/b] the freezing point of water...
Posted : 12/01/2010 10:51 am
yeah my bad, i actually typed 'decreases the' but changed it. in my defence i haven't had my full quota of coffee yet and am still in my dressing gown 🙂
and i'm just as inclined to have faith in complete tosh from other parts of the internet as i am in some of the tosh you talk on here 😉
Posted : 12/01/2010 10:53 am
it boils, trust me, I've just done it!
Posted : 12/01/2010 11:01 am
it's seems your scepticism is justified according to wiki:
"Until recently, it was widely believed that ice was slippery because the pressure of an object in contact with it caused a thin layer to melt. For example, the blade of an ice skate, exerting pressure on the ice, melted a thin layer, providing lubrication between the ice and the blade. This explanation is no longer accepted. There is still debate about why ice is slippery"
Posted : 12/01/2010 11:58 am
actually, I wonder if wiki is right on this...
Posted : 12/01/2010 12:08 pm
hmmm
the plot thickens
Posted : 12/01/2010 12:10 pm
 br
Not sure now, but they use to pressure test alloy cylinders with water as it would just crack, as opposed to explode.
Posted : 12/01/2010 12:13 pm
for gods sake buy some sensodyne first though
Posted : 12/01/2010 12:15 pm
The phase diagram below ([url= http://www1.lsbu.ac.uk/water/phase.html ]from here[/url]) shows what this is all about. This shows the phases or physical states of Water at different temperatures (in kelvins 273 is zero centigrade) and pressures.
I'm not going to repeat what it says on the website above, but the answers to all your questions are there. I used to know this, but my physics masters was about 13 years ago, but just recently I was called on to examine some freeze thaw failures and had to learn all this again, water is very strange stuff..
Posted : 12/01/2010 12:20 pm
Is there a point to the question this thread presents?
Posted : 12/01/2010 12:24 pm
thats a great graph toys.
I think I almost understand it, but why does it seem to imply that H20 sublimates at low pressures?
Posted : 12/01/2010 12:41 pm
Umm no implication, it does sublime. I'm not sure that there are ever atmopheric conditioons on earth where this would happen - for example the pressure on Everest is approx 30Kpa (sea level its 101kPa) which is above the sublimation pressure shown on the phase diagram.
Edit - there are very low pressures at higher altitudes down to 1 Kpa so in theory it could happen in the earths atmosphere - but this is a bit outside my sphere of knowledge so i cant really comment - what happens at high altitude is influence by other stuff as well. I'm not a climatologist..
Posted : 12/01/2010 12:47 pm
wow I didnt know that.
Is that to do with partial pressures n stuff?
EDIT: BTW what do the states 7, 8, 11 and 10 represent?
Posted : 12/01/2010 12:49 pm
i looked that up earlier after talk of 'ice 5 etc'
wiki - http://en.wikipedia.org/wiki/Ice#Phases
Posted : 12/01/2010 12:53 pm
Yes "partial pressures n stuff" is related. States 7.8.10 and 11 are explained in the link above. It all to do with the molecules of water finding favourable energy configurations in the way they pack as the temp reduces and/or pressure increases.
Posted : 12/01/2010 12:54 pm
Partial pressures really only applicable to gas mixtures. e.g. The partial pressure of Oxygen in the air is around 21.3kPa and the partial pressure of Nitrogen is around 80kPa.
It's probably something to do with hydrogen bonding. That always seemed to be the reason that water does strange things. The other regions are probably some sort of esoteric states of matter that have little relevance in the real world although I have little experience in dealing with them so don't take what I say as gospel.
Posted : 12/01/2010 12:56 pm
except the almost vertical line doesn't give enough detail on the variation of freezing point with pressure 🙁
Posted : 12/01/2010 12:58 pm
Joe Satriani did a great song called Ice 9...
Posted : 12/01/2010 12:59 pm
I'll see if I can find the detail about the freezing point with pressure, I've got a text book around here somewhere with all this in..
Don't worry a real physicist will be along in a minute, I'm just a lowly materials engineer with a cursory grasp of what is going on..
Posted : 12/01/2010 1:02 pm
yes, water is a paradoxical substance, and many of its characteristics are highly unusual.
I'm not sure that there are ever atmopheric conditions on earth where this would happen - for example the pressure on Everest is approx 30Kpa (sea level its 101kPa) which is above the sublimation pressure shown on the phase diagram.
It does all the time. If you fill an ice tray and leave it in the freezer for months, the cubes will get smaller. Meat gets "freezer burnt" after a few months, because the H2O molecules leave the meat, drying it out. It didn't pass through the liquid phaseon the way.
And depth hoar in a snowpack is formed by recrystalisation of sublimated water vapour.
Edit: toys, Just realised that we're not quite taking about the same thing: The graph shows that at certain pressures and temperatures, changes in one will provoke a change in state of all the material from solid straight to gas, and I think I was talking about common or garden entropy, in the form of sublimation.
I think.
Posted : 12/01/2010 1:05 pm
nedrapier - I think I can explain this as there may be local convection currents so any flow across a surface will create very low pressure on that surface.
At low pressures the concept of Solid/liquid/gas is a bit difficult to define as the state is dependant on having other molecules nearby to interact with. If you have a very low pressure (like near or total vacuum) and introduce a single molecule of water at the sublimation temperature then is it a solid or gas? It's a bit of semantics, in reality the words we use to define solid/liquid/gas are generalisations...
Posted : 12/01/2010 1:14 pm
nedrapier just seen your edit. Common or garden entropy is, I think, driven by local variations, at least this is what I remember...
I think we are on dodgy ground anyway as this is difficult to prove because you cannot observe exactly what happens at the surface without changing what happens (uncertainty principle).
Posted : 12/01/2010 1:19 pm
just ask hainey
Posted : 12/01/2010 1:23 pm
Simon Barnes.
Scroll down on that link, the next graph has what you are looking for.
Posted : 12/01/2010 1:24 pm
ok we've done this now
can you explain the Mpemba effect now please 🙂
Posted : 12/01/2010 1:27 pm
local variations was how I understood "natural" sublimation and evaporation works. water vapour leaves the surface of water all the time, the mloecules are jiggling about and every now and then the engery from combined jiggles is anough to overcome the surface tension (molecular attraction). The more energy there is in the water, the hotter it gets and the more often molecules are pinged out of the surface tension.
This happes too in ice, just less often, as there is less energy and less movement of molecules.
Posted : 12/01/2010 1:29 pm
edit. just being silly.
Posted : 12/01/2010 1:30 pm
i'll take that as a no 😆
Posted : 12/01/2010 1:31 pm
[i]yes, water is a paradoxical substance, and many of its characteristics are highly unusual...[/i]
It always makes me s**** when people say things like that - surely the characteristics of water are only unusual for something that isn't water.
The only paradox (about it) is that people think that 'our' theories of how matter behaves are little more than approximations based on idealised systems.......
Posted : 12/01/2010 1:32 pm
gonefishin - Member
NO
I did my dissertation on this, we concluded that yes there is a thin layer of water, but this is due to friction not pressure, as a by product of this we could make dry slopes feel like fresh powder!
Unfortunately we couldn't get a manufacturer to incorperate it as they believed it was destined for the same fate as those swiming suits, everyone is 2% faster in the olympics one year, they'r banned the next.
Posted : 12/01/2010 1:35 pm
just reading about it now.
I like the opening story:
Origin
The effect is named for the Tanzanian high-school student Erasto B. Mpemba. Mpemba first encountered the phenomenon in 1963 in Form 3 of Magamba Secondary School, Tanzania when freezing hot ice cream mix in cookery classes and noticing that they froze before cold mixes. After passing his O-level examinations, he became a student at Mkwawa Secondary (formerly High) School, Iringa, Tanzania. The headmaster invited Dr. Denis G. Osborne from the University College in Dar Es Salaam to give a lecture on physics. After the lecture, Erasto Mpemba asked him the question "If you take two similar containers with equal volumes of water, one at 35 °C (95 °F) and the other at 100 °C (212 °F), and put them into a freezer, the one that started at 100 °C (212 °F) freezes first. Why?" only to be ridiculed by his classmates and teacher. After initial consternation, Dr. Osborne experimented on the issue back at his workplace and confirmed Erasto's finding. They published the results together in 1969.[2][3] As of 2002 Erasto Mpemba is retiring from being Principal Game Officer for the African Forestry and Wildlife Commission.[4]
yup, it's a great story
Posted : 12/01/2010 1:37 pm
[i]can you explain the Mpemba effect now please [/i]
isn't it a combination of solute precipitation and heat transfer being proportional to the temperature gradient ??
Didn't know [url= http://en.wikipedia.org/wiki/Mpemba_effect ]that[/url] was called the Mpemba effect but the wikipedia link alludes to that fact that it is unproven...
Was told by an A level physics teacher (called Streaky Bonehead) that hot water cooled faster than cold water due to increased potential.
Now since then I've done lots of thermodynamics and what I do know is that the rate of heat transfer is proportional to the difference in temperature. So water at 100C in a freezer has a very large difference in temp, compared with tap water at say 20c, so the hot water will lose heat much faster than the tap water. The only problem with this is that as the 100c water cools then its rate of heat transfer reduces, so at 20C the rate of heat transfer is the same as the water that started at 20c. And the water that started at 20 c will be much colder than 20 c by now...
There is another good article about it [url= http://www.picotech.com/experiments/mpemba_effect/results.html ]here.[/url]
Nedrapier - your explanation of local variations suits my world view exactly. 🙂
Posted : 12/01/2010 1:39 pm
So what tyres are needed for riding on Ice-5 then? ;o)
Posted : 12/01/2010 2:05 pm
You'll need to prove whether the moon is made of cheese first before anything else according to the wonder kids on here! 😉
Posted : 12/01/2010 2:50 pm
What would happen of course is that the pressure within the container
would increase by many powers of 10, but assume the container is strong
enough not to break. At first, if you kept the temperature at exactly 273.15 K (0 C.) the water would remain a liquid because the freezing point of icedecreases slightly with increasing pressure. However, when the pressure reached pressures of the order of 10^8 to 10^9 Pa., ice having a structure different than "normal" ice would form. Ice has at least seven different crystal structures depending upon the temperature and pressure.
Posted : 12/01/2010 3:00 pm
catch up tankslapper 🙄
Posted : 12/01/2010 3:01 pm
🙄 late developer..... 😆
Posted : 12/01/2010 3:02 pm
Ice-9. That's the substance created by the naive scientist in Kurt Vonnegut's book Cat's Cradle. The one that "freezes" the planet when it escapes from it's container. Very cool book.
Posted : 12/01/2010 3:24 pm
Is the OP actually an overcomplicated attempt at safe-breaking?
You'd be better off with a decent still saw and a blowtorch 😀
Posted : 12/01/2010 3:33 pm
WARNING CAT'S CRADLE BOOK SPOILER *
I recall that the motivation for ice-9 was a general who wanted a method of freezing mud to stop his tanks getting bogged down. To solve the problem, the naive scientist created a stable configuration of ice but at normal temperatures (ice-9). It turned water it made contacted with into more ice-9.
Utter disaster when someone tips it in the ocean and all the water on the planet becomes ice-9!
Posted : 12/01/2010 3:34 pm
