What glue to stick ...
[Closed] What glue to stick my mirror back on to the windscreen ?
13 Users
is this the stupidest idea car manufacturers ever came up with ?
Posted : 06/11/2012 8:55 am
If you go to halfords, you can get a kit with some special glue and mesh which bond the mirror back on. Worked for me and never had the problem again.
Posted : 06/11/2012 8:58 am
 teef
I used quick setting araldite once - supported it with some tape and my hand until set - it never came off again.
Posted : 06/11/2012 9:26 am
Drill and bolt it?
Posted : 06/11/2012 9:30 am
3M double sided auto foam.
Posted : 06/11/2012 9:45 am
Not superglue a friend did that once after his girlfriend kicked it off during some nightime car park entertainment. Ended up cracking the windscreen.
Posted : 06/11/2012 9:47 am
+1 double sided foam
Posted : 06/11/2012 9:49 am
Fiesta?
I used some plaster’s webbing that was knocking around, glued that on the glued the old mirror to the webbing. Worked fine.
Posted : 06/11/2012 9:50 am
Yes, definitely not superglue - a friends widescreen cracked while he was washing it (with a pressure washer) and it was traced to the previous owner sticking the mirror back on with superglue.
Get some proper windscreen adhesive - it's thick black stuff that is specially designed to bond windscreens in so you know it won't affect the glass. Not worth the risk using anything else IMO.
Posted : 06/11/2012 9:51 am
Double sided foam probably wont be strong enough. Works ok initially and then fails. [b]The Halfords kit does the job perfectly.[/b]
Superglue prob cracked the screen as its an exothermic reaction when its setting, so a localised heat spot would have developed, cracking the screen.
Posted : 06/11/2012 9:52 am
Epoxy (Araldite) is the same.
Use the proper kit, no point wrecking a windscreen for the sake of a couple of quid
Posted : 06/11/2012 10:02 am
Any car motor factors will have the small sticky patch and cleaning it to stick it back on with.
Posted : 06/11/2012 10:04 am
cheers folks, Im off to halfords
Posted : 06/11/2012 10:06 am
Its about a tenner for the kit IIRC
Posted : 06/11/2012 10:11 am
The Halfords kit may solve your problem
Posted : 06/11/2012 10:33 am
Pop into your local Autoglass/Windscreens R Us et al, do your best puppy dog lost impression and 9 times out of ten they'll do it for you buckshee.
Posted : 06/11/2012 11:42 am
