google has not been my friend
any appliance peep's or knowledgeable cheapskates around?
Stoves double oven - want to replace one of the controllers - found the part ok - but to remove the front panel (removed fascia ok) need to remove the doors (no just blow them off jokes) there are no visible clips on the doors themselves by the hinges but large black plastic knob type things on side casing level with hinges - if i turn these and pull the doors will the hinge just slide out? and more importantly back in?
and yes i do get some enjoyment out of fixing things and the power will be off and the relay flipped just in case
Usually the hinges have a clasp type arrangement that you have to lift and then the door comes up and away? Not dealt with a stoves one though.
thanks curly68 - seen that type but these are just a flat plate that disappears into the door with no obvious fixing on the door side
