Waterloo to Kings C...
[Closed] Waterloo to Kings Cross
Tomorrow am, have about an hour to do it it. best route, to avoid stairs where possible (like a **** I went for a run and now hip is screwed up!)?
Seems could do Northern to Leicester Sq and then Piccadilly line to KX
Or Northern to Warren St and then Victoria line
Or Northern to Euston and walk the last bit (walkings OK, stairs hurt)
Come on you Villagers, you know your tube stations better than me.
Posted : 31/10/2014 11:22 am
Warren St has stairs to get anywhere from the Northern line. I'd do Euston and walk, I think there are escalators all the way up at Euston but I'm not 100%. Choose KX entrance carefully for the bit you need to get to if you want to totally avoid stairs, there are a few flights of 5 or 6 if you go in the wrong door.
Posted : 31/10/2014 11:26 am
Boris bike it, about 3 miles ๐Ÿ™‚
Posted : 31/10/2014 11:27 am
allthepies - Member
Yep.
Posted : 31/10/2014 11:31 am
That thought just occurred to me too.
Tell me about it - never used one, not got an account, is docking out and in easy?
Posted : 31/10/2014 11:33 am
Exit Waterloo, go down the hill towards the river and there are loads of Boris bikes out there.
Put card in. Follow instructions.
Take code to bike. Enter code, pull bike out of stand. Ride.
Route? I'd go along Upper Ground, turn left over the Col du Blackfriars and then just head straight on up Farringon Street/Road. Easy peasy.
Get to dock, put bike in dock, and walk away. It's a doddle.
Posted : 31/10/2014 11:40 am
 edd
It's less than an hour to walk...
Posted : 31/10/2014 11:57 am
Jubilee line to Green Park change to Victoria Line to Kings Cross should be escalators. I did that journey in 15 minutes back in June.
Posted : 31/10/2014 12:12 pm
https://www.tfl.gov.uk/modes/cycling/barclays-cycle-hire?intcmp=2295
Another vote for Boris-biking it. Link above is all you need to know about how it works.
Posted : 31/10/2014 12:24 pm
I Boris Bike every day, great service. If you are going to do that download the app and check two things, firstly there are bikes at Waterloo - there are always tonms in the morning but as the day goes on they get taken and the racks don't fill up till the afternoon/evening, secondly there is somewhere to park it at Kings Cross, it's not all unusual to find the parking full. Also Waterloo to King Cross isn't the quietest road ride you'll ever do !
I am curious that you want to bike but not climb stairs ?
Anyway tube (Bakerloo/Victoria change at Oxford St or as above Jubilee/Victoria)
Or I would say if you don't want stairs / effort the number 1 tip from me is the 59 bus - you can pay by Oyster or contactless card
Posted : 31/10/2014 12:46 pm
Go on the bus. There will likely be direct one. That said I often walk when in London. The centre of London isn't that big and its quite interesting.
Posted : 31/10/2014 12:48 pm
Where are you coming in from? Most Waterloo trains stop at Vauxhall, so direct on the Victoria line from there.
If you do bike it, the racks are empty by 8.30ish unless it's raining so you either queue as they unload the trucks or walk further away.
Posted : 31/10/2014 12:53 pm
It's stepping down that causes the issue, even little steps jar a little bit and x that by potentially lots of steps.
Posted : 31/10/2014 12:57 pm
tomorrow, arrive 0713 and train out of KX at 0830
Posted : 31/10/2014 12:58 pm
Get the 59 bus then. Roads should be quite empty at 7:30 by the time you are on the bus. Your train ticket should cover the bus ride but check otherwise Oyster/Contactless.
Posted : 31/10/2014 1:17 pm
Easy - northern line and walk
Fun - Boris bike.
Did the latter this morning and am going for a quick spin now just for fun!
Posted : 31/10/2014 1:56 pm
It was a lovely morning so the Boris bike won out. Thanks all for the encouragement and ATP for the facebook wisdom!
What exactly is first gear for? You could climb the Eiger on that?
Posted : 04/11/2014 11:22 am
This - it's a cross platform change at Oxford Street, escalators both ends.
Or Boris bike.
Posted : 04/11/2014 11:24 am
Got to love the read the first message, skip the rest and miss the point-edness of your post!!
Posted : 04/11/2014 11:28 am
Conti Vert Pros!
Posted : 04/11/2014 11:30 am
You can fit the busy bit of Manchester (ancoats to the north/bridge water canal to south) inside Hyde park.
Just sayin like. ๐Ÿ˜€
Posted : 04/11/2014 11:34 am
Ah yes, actually I did (as I quoted what struck me as the sensible route, suggestions of Jubilee line etc were a little daft!), but somehow missed your post!
Posted : 04/11/2014 11:37 am
thecitymapper app is well worth having. gives you all the options, walk, train, various tube and bus routes, cycle, cab, how long they'll take, and cost.
the cycle bit has 2 options, the bike hire one links to the boris app, and gives you a route from the nearest dock with bikes to the nearest dock to your destination with spaces.
Posted : 04/11/2014 11:54 am
Anyone got any thoughts on running this? Good routes that avoid traffic, etc?
I'm travelling from Aberdeen to Dorset this weekend, but need to fit in a 5km run (I'm doing this Marcothon thing).
I've got an hour to get from Kings X to Waterloo on Friday lunchtime, then back again on Sunday.
Posted : 02/12/2014 4:19 pm
Up to Euston road to Judd street, hang a left, essentially keep going. (there are some squiggly bits fixed by doing the odd right then left) You can walk it quickly in much less than an hour.
Posted : 02/12/2014 4:30 pm
http://walkit.com/
usually gives pretty good routes
Posted : 02/12/2014 4:33 pm
