Washing waterproofs
[Closed] Washing waterproofs
Hey BadlyWiredDog
Yep, spray-on for for fabrics with a separate floating liner, wash-in for stuff that’s a single layer of fabric.
The spray stuff seems more effective too, my Sweet Protection Goretex Active was still wetting out after a TX-direct wash in treatment, the spray worked well. as others have written though the factory DWR (apparently quite toxic that stuff) is the only really effective stuff for wetting-out and its soon gone.
Bought some ShowersPass pants recently, seem pretty good if a little hot, they actually recommend Nikwax TX-Direct wash-in
anyhoo, thanks
I thought that was it.
I guess its obvious once you know, don't wash in waterproof anything that wicks moisture.
[which kinda makes me wonder how the DWR treated outer allows moisture out, plainly it does ;~} ]
neil
Posted : 31/01/2020 10:46 am
So to update the thread. I bought some Nikwax and Endura spray on re-proofer (jacket is Endura pro sl shell II)
Washed last night in Nikwax, and then sprayed with re-proofer while still wet/damp.
This morning it had all dried so I flicked water onto it to test and it beaded nicely. Came back to it a few minutes later and where the drops of water had beaded, it had now soaked into the fabric and there were little drop sized wet patches. Not sure if I have knackered the jacket or done something wrong.
Posted : 31/01/2020 10:51 am
That's what I found with washing jackets. Looks like a beads up nicely and jacket feels slightly waxy, but in any real rain it just gets wet!
Posted : 31/01/2020 12:22 pm
I have a TNF jacket which beads amazingly well. Hence I don't dare ever wash it, as it is by far the best DWR finish I have ever seen....
Posted : 31/01/2020 1:49 pm
I have a three year old Decathlon sailing jacket that still beads very well and doesn't wet out but I use it for walking so it doesn't get dirty often. I follow the Decathlon guide below but every now and then I brush Thompsons Water Seal on to the jacket, it looks like it just runs off but the jacket beads noticeably better after it is done.
HOW TO REACTIVE THE JACKET'S WATER REPELLENCY
step 1: before washing
Close all zips and flaps and remove any parts of the garment that cannot be washed. Also remember to loosen the straps and elastic parts and empty the pockets.
Then turn the garment inside out to wash it.
step 2: washing
You can wash your jacket on a synthetic cycle at 30° or 40°C with your usual detergent. Do not use fabric conditioner, which could damage the existing performance of the garment, or bleach.
Also take care not to bend your jacket too much when you place it in the washing machine and do not overload your machine.
Very important: select a thorough rinse or double rinse to completely remove all detergent residue.
step 3: drying
Drying is a crucial phase in reactivating the water repellent treatment.
We recommend that you lay your jacket flat on a clothes rack and leave it out to dry in the open. Caution: never dry your jacket directly on a radiator.
Then place it in the tumble dryer on a short synthetics cycle, i.e. 10 to 15 minutes, before turning it back the right way round. Caution: do not over-dry the garment.
Posted : 31/01/2020 2:13 pm
There's an ongoing debate about fluro-carbons in DWRs and whether it's more sustainable to use a potentially more harmful DWR during manufacture on the basis that it's more durable, so long term better, with less need for reproofing, or simply to use a less harmful treatment to start with.
Different fabrics hold DWR differently. As a generalisation, it's easier to apply an aftermarket treatment to a polyester face fabric than Nylon/polyamide, but polyesters tends to be less durable fabric.
I think one of the problems with aftermarket DWRs is that it's important to get the fabric super clean before application, but that's very hard to actually do. Grangers has washing machines that are only ever used with technical cleaners and their reproofing products, but that's not exactly feasible for normal people.
The standard advice is to run a boil wash through the machine first and clean out detergent dispensers thoroughly, but there's only so much you can do. When I replaced a broken drum on my old washing machine, the outer drum was literally caked with congealed detergent from previous use. I suspect that's the case with most washing machines, so you're always going to get some contamination which can impact on how well the re-treatment works.
Posted : 31/01/2020 2:32 pm
 cdoc
Outdry stuff is great! permanent beading, slightly less breathable than goretex shakedry, but way tougher .
Slightly odd cut on mine though. Will size down next time.
Posted : 31/01/2020 4:24 pm
Majority of waterproofs still have PFC DWR which will generally be reactivated by tumble drying on a warm setting. Nikwax and Grangers don’t require the heat activation but most jackets will benefit from it.
Posted : 31/01/2020 8:19 pm
Page 2 / 2
