Dissembled?
Remember the van has a bulkhead unlike car version so cant lay the long bits over the front passenger seat.
Will it work?
Pervert.
I goggled for you
Now you need to find out how big a single bed is
Engine size (Litres): 1.4-1.6
Power (HP): 75-90
Wheelbase (mm): 3000
Overall lenth (mm): 4137
Overall width (mm): 1724
Overall height (mm): 1819
[b]Load lenth (mm): 1700
Load width max (mm): 1600[/b]
Load height (mm):1245
Rear door height (mm): 1270
Rear door width (mm)1155
Gross Payload (Kg): 600-800
Gross vehicle weight (Kg): 1930
I think you'd struggle.
But then, you generally do.
Fold the matress in half.
Aye junky 6ft3 long do it'd need to be diagnoly with header/footer AND mattress though. Hence the question..
Transit hire it is (shed/garden/tip trips as well)
You goggled for him? Filthy boy
you'll find commercial vehicles are frowned upon at the tip and there'll be height barriers to keep you. Costs me a £140/ton ( or min charge £99 if its less than a ton) to take a van into the tip here.
