VW/Skoda/Seat/Audi ...
[Closed] VW/Skoda/Seat/Audi BXE engine poll
9 Users
I'm sure plenty of you have these cars, and with this engine (code starting BXE in the logbook).
Some of you probably know the internet is full of reports of the engine dying when a conrod fails and punctures either the head or the block => economic writeoff of the car.
In the interests of balance who has a BXE engine that's still running well?
Please state plate on car (07/57/08/58 etc) and mileage 🙂
Posted : 09/12/2016 4:27 pm
I have never looked in the log book..if I do and find BXE my car WILL die. I'm lucky like that!
Posted : 09/12/2016 5:05 pm
I'm not sure you'll find many that have not died when the conrod has jumped out 🙁
Posted : 09/12/2016 5:52 pm
The hard thing is working out how many BXEs are out there compared to the number of complaints. I wonder if VAG would reveal this if you asked via FoI?
Apologies for the monday morning TLA overload
Posted : 12/12/2016 11:21 am
only public organisations have obligations under the FOI act.
Posted : 12/12/2016 11:22 am
BXE = 1.9tdi?
Posted : 12/12/2016 12:31 pm
1.9 TDI 105hp BXE engines were fitted to VW,Audi Seat and Skoda vehicles from Feb 2006 through to April 2010
Posted : 12/12/2016 12:35 pm
[s]I had one - Skoda Ocatvia 105bhp. January 2006. Was on 140000 miles when I sold it 2 years ago and, according to a quick MOT online checkup, it is still going strong.[/s]
oops - January is before February, isn't it 😳
Rachel
Posted : 12/12/2016 1:05 pm
57 plate Octy 105bhp BXE engine with 195k here. It's been very reliable too with less than £1000 spent on non-service items in the last 140k.
Posted : 12/12/2016 2:01 pm
@Matt24k that's a longer period than I thought. Does that mean all (or most) 1.9 TDI 105ps engines from 2006-2010 are BXE?
@mjrose - nice 🙂
Posted : 12/12/2016 4:34 pm
@sideshow there are loads of conflicting references regarding the BXE engine and how it can fail. The thing to bear in mind is that there are probably hundreds of thousands of these units in use with lots of variants and different types of failure. Various theories about under spec'd oil pumps, soft cams, substandard conrods and or shells. The list goes on as does the list of engines that have covered 150k miles with no problems.
The common belief is that the oil needs changing on a more regular basis that the long life schedule states.
Posted : 12/12/2016 4:55 pm
To add to the confusion. All long life services too, albeit with the correct spec oil and mapped since 60k too.
Posted : 12/12/2016 5:17 pm
@Matt I thought that bxe being an engine code means a single variant?
Where do you get your "hundreds of thousands" estimate from? If it's true then as you say bxes are probably fine. but how do we know most of the other related engines out there aren't under another code implying bxe are genuinely faulty?
Posted : 12/12/2016 11:36 pm
@sideshow you are correct that the BXE is a specific variant of the VW 1.9 R4 TDI PD 43-118kW engine.
The info below is from Wiki.
[i]Essentially, this ubiquitous engine has the same bottom end (cylinder block/crankcase, crankshaft) as the earlier 1.9 R4 TDI which uses a VP37 VerteilerPumpe distributor injection pump. However, a new cylinder head is fitted to this "PD" engine, to accommodate "Pumpe Düse" Unit Injectors.
identification
parts code prefix: 038, 03G[/i]
Here's the [url= https://en.wikipedia.org/wiki/List_of_Volkswagen_Group_diesel_engines#2.0_R4_16v_TDI_PD_103-125.C2.A0kW ]link[/url]
My hundreds of thousands is a very rough estimate.
Loads of interesting theories [url= http://uk-mkivs.net/topic/252492-19-tdi-golf-matches/ ]here[/url]
Posted : 14/12/2016 11:32 am
Someone out there will be driving my old Fabia with this engine then, clocked up 130k miles in 5 years without issue when I sold in 2013, good luck to them!
Posted : 14/12/2016 11:41 am
Good link to the other thread, I hadn't seen that.
Posted : 14/12/2016 12:21 pm
