USB wiring Q
[Closed] USB wiring Q
4 Users
Just shifted a motherboard and all the rest of the bits into a new pc case.
The front usb has a different plug connection to the one that was in, but the wires are (I think) the same colour, is it a safe bet that If I can get the pins out of the plug and switch them round that it will work?
More to the point, can it do any harm?
Posted : 28/01/2009 7:27 pm
I wouldn't risk it myself but yeah front USB tend to be the same, your better plugging it in as is though it should only go in one way.
Posted : 28/01/2009 7:30 pm
A couple of them must be the 5volt feed (?) - I'd guess you'd damage whatever you plugged in if you got them wrong
Posted : 28/01/2009 7:50 pm
Motherboard should either be labelled with what each pin is or it'll be in the manual, then you can plug into the correct pins (assuming each wire on a seperate plug)
Posted : 28/01/2009 8:12 pm
Nah, it's a multiplug type. I think the case has standard wiring, whereas the usb connection on the motherboard is specific to older packard bell machines.
Had a real nightmare wiring the on/off switch, leds and reset earlier on. I'm not even bothering with the front mic and headphone socket.
Cheers all
Posted : 28/01/2009 9:13 pm
