Un-earthed garage l...
[Closed] Un-earthed garage light. Will I die?
I've just bought a cheapy fluorescent batten for the garage but there's no earth in the wiring. It's a garage 'en-bloc' (as estate agents love to say) with a plastic conduit coming through the wall from the garage next door. There's no earth wire in the switch either so would imagine there's none in the whole block. A quick search suggests cheap, cheerful and double-insulated are not commonly found together, if at all, not to mention the £15 I've just spent. Any suggestions?
Posted : 10/06/2013 1:40 pm
Presumeably no meter either?
Invest heavily in hydroponics and set up a hash factory?
No other useful suggestions available.
Posted : 10/06/2013 1:58 pm
How are you planning to turn the electricity off when you put a new light in?
Posted : 10/06/2013 2:05 pm
 murf
Replace is with either a normal hanging pendant or a batten lamp holder, depending on ceiling height.
Fire in the brightest BC lamp you can get, 22watt low energy would be perfect.
Shouldn't be more than £7 all in and will not require an earth.
Happy days 🙂
Posted : 10/06/2013 2:08 pm
Murf, that is what's already there and it's not bright enough for fettling, plus it's low down and keeps getting battered.
[i]How are you planning to turn the electricity off when you put a new light in?[/i]
Switch off, rubber gloves and wellies 😉 I was actually planning to find out from the maintenance guys where the breakers are, I just know they're not in my stairwell.
Posted : 10/06/2013 2:39 pm
Why does it need an earth? Are you planning on spending a lot of time on the ceiling?
Posted : 10/06/2013 2:47 pm
[i] Are you planning on spending a lot of time on the ceiling? [/i]
marvinpines = Lionel Ritchie?
Posted : 10/06/2013 2:50 pm
In my garage some of the chain fixing points are quite close to the lights so I think it's always best to be safe. And I prefer to work on my guests with DC.
Posted : 10/06/2013 2:51 pm
Oh, I so wish I'd thought of that.
Posted : 10/06/2013 2:52 pm
Depends if Lionel Richie's layin' it down.
The fitting has a steel chassis and says "This appliance must be earthed". I'm not 100% convinced it's necessary so thought I'd open a can of worms on here...
Posted : 10/06/2013 2:55 pm
Damn my slow typing!
Posted : 10/06/2013 2:56 pm
Hmm.. wire falls out, touches casing, light goes out.
Marvinpines: Oh look the light's gone, let me just replace it
Ohm's law: The casing of this appliance is now live, have some current. Boom!
Posted : 10/06/2013 3:03 pm
Can you not just run a seperate earth into it..
And wire the thing through an inline RCD...
Posted : 10/06/2013 4:00 pm
Lights quite often don't have an earth connection if they are double insulated and have no surface / exposed metal parts.....
EDIT: and yes, you will die; but unlikely this light will have anything to do with it.
Posted : 10/06/2013 4:09 pm
