Triple glazing
[Closed] Triple glazing
28 Users
Currently live in a 1930's property that has 15-20yr old upvc double glazed windows which appear to be fairly rubbish (lots of condensation issues)
so been thinking of replacing our current windows, have a general dislike for upvc windows so was thinking timber frames and triple glazed panes, does this seem sensible or am i going to cause more issues? do i need trickle vents?
look forward to any comments / suggestions
Posted : 04/01/2015 6:38 pm
I don't see the point of triple glazing in the UK climate, let alone an older house. Having had serious condensation/mould issues in a 1930s house (with double glazing and cavity wall insulation) for years, I put a positive pressure/input ventilation unit in about a month ago and all the problems are gone. Bloody miracle and only cost £200!
Posted : 04/01/2015 6:44 pm
interesting, what system have you installed as a quick look into these seems that its going to cost more than £200?
Posted : 04/01/2015 6:55 pm
If the condensation problems are in the windows, then the sealed units are no longer sealed. If the condensation problems are in the rest of the house, then replacement windows won't solve those problems.
Unless I had a lot of glazed area and were chasing a particular level of certification or I had soundproofing needs I'd probably not bother with triple glazing. The price increase over double glazing does not give you an incremental improvement. It's diminishing returns.
Posted : 04/01/2015 7:09 pm
One of these: http://shop.dryhomes.net/products/drimaster-standard
Just requires cutting a hole in the ceiling and wiring to the live/neutral of the loft lighting circuit.
I think I'm actually more thrilled with it than my Banshee Spitfire that I'm always raving about...
Posted : 04/01/2015 7:13 pm
Yes, if it's 'blown' panes in the glazing then that's another issue entirely.
Posted : 04/01/2015 7:16 pm
thanks for that chief!
existing double glazed units are fine, think we've got a general ventilation issue
Posted : 04/01/2015 8:01 pm
The insulation (u) value between the best 2g and 3G isn't that great. A bigger impact is likely to be the frame and the quality of the fitting. The Main advantage or 3G is the increase in the temperature of the inner pane means you can sit closer to the glass without feeling cool so you effectively gain interior space.
At least that's the theory. I'll let you know hoe it goes in a year.
Posted : 04/01/2015 8:54 pm
The difference between some double glazed windows we had installed last year and the existing double glazed windows that are ~15 years old is massive. The old units are fine, but I guess the general efficiency and quality of the newer units is much better to the point that I'm tempted to get the older ones replaced even though they are technically fine...
Posted : 04/01/2015 9:04 pm
 myti
Chief next time I see you please talk to me about the positive pressure thing. We have a condensation problem in one room. Upstairs bedroom wall runs with water when it's cold out. Incidentally we just had new triple glazing put in. It's great and wasn't much more expensive than double. Our old windows used to get steamed up but now they are so well insulated I think the moist air is finding the coldest place to condense which is the wall.
Posted : 04/01/2015 9:33 pm
If you are getting new windows then I would suggest getting trickle vents anyway. Gives you the option of leaving the vents open to get some air through. Especially handy in bathrooms etc. Our old 1970's bungalow had no trickle vents. We constantly had mould around the house. We couldn't fit trickle vents to those windows as because of the frame shape.
Fortunately our new house has trickle vents. No mould problems and nice and toasty warm.
Wooden frames will make far more difference than triple over double glazing. UPVC is rubbish as heat insulation
Posted : 04/01/2015 9:40 pm
Ventilation is good thing especially if it includes heat recovery.
Having had triple glazing for a couple of years I wouldn't go back to double even on south-facing walls. Arguments such as the loss of solar gain being greater than heat saved just don't stack up in December and January. As Simon hopes, there really are no cold spots in the room and a chair Madame avoided is now her favourite.
Another advantage is that triple glazed frames are usually 2cm deeper which allows insulating right up to the frame if you are insulating the walls on the inside too. We used to get more condensation on the wall around the frames of the double gazed windows where there was a thermal bridge than on the glass. Not any more.
Posted : 04/01/2015 9:54 pm
Is that right? Doesn't the air gap in the extrusion act as an insulator?
would like to know if that's right as it might influence what type of windows I get.
Posted : 04/01/2015 10:02 pm
What sort of price are you looking at for a triple glazed? All ours are shot too.
Mostly small cottage windows 1m sq
That is incorrect. The UPVC frames are honeycomb/labyrinth structures with more air than UPVC and beat any wooden or aluminum frames available when I was doing my research. You need to look at the uW figure, that's the value for the whole window and frame. You'll find the best figures are for UPVC frames and triple glazed glass with various heat reflecting treatments.
Trickle vents are just ventilation with no heat recovery. It's more energy efficient to have no vents in the windows or walls but an efficient ventilation system with heat recovery.
Posted : 04/01/2015 10:09 pm
 mj27
Considered triple glazing for our new bay window and porch extension, bought all the windows direct from the manufacturer. I asked him for the pros and cons, he said don't bother for the heat loss side but do for sound. He only has double on his house. New double glazing is much better than that of 10/15 years ago and the fitting is important, a lot of heat is lost in those areas that the installers cover with the plastic trims. I fitted my own and it has made a massive difference.
Posted : 04/01/2015 10:11 pm
I went for triple glazed when I put bi-folds into my kitchen. I was concerned about heat-loss because we spend most of our time in the kitchen & the Aga has always kept it nicely warm. I'm really glad I did, even in the current freezing weather we're perfectly fine around the table sitting just a few inches away from the glass. The triple glazing only cost 5% extra.
As others have said, the frames make a big difference, not much point paying for 3G unless the frames are properly insulated. I bored everyone to death researching the options before spending the cash- not all manufacturers are keen to publish the u-values of the frames, they just concentrate on the glass.
Posted : 04/01/2015 10:17 pm
I've heard someone say this before, and started wondering what's behind the trims on our windows... what's the difference between a "properly installed" window and a shonky one in this regard?
Posted : 04/01/2015 10:28 pm
Go ahead and bore me to death with some manufacturers as without reccomendations it's down to picking from numerous search results from googling ’double glazing'
Posted : 04/01/2015 11:06 pm
 mos
I would be genuinely amazed if triple glazing from any manufacturer only costs 5% extra!
Posted : 05/01/2015 7:36 am
So why are trickle vents so good then? We have 15 year old UPVC DG windows, all of them left permanently open on the latch at the bottom, permanent condensation and mould issues regardless. (1970s flimsy build)
Posted : 05/01/2015 7:51 am
DG units don't fail suddenly; it's an inevitable process that takes a few years to happen. There has to be an in/out flow of air in order to accommodate changes in atmospheric pressure. Pressure increases and air comes in in tiny volumes and brings moisture. The units are built with a moisture absorber which, after some years, becomes saturated and unable to absorb any more moisture. The moisture level builds up inside the unit until it begins to condense.
AFAIK the best way to deal with condensation on an exterior wall is to dry line it. We dry-lined a cold bedroom in an extension and the effect was miraculous.
Posted : 05/01/2015 8:30 am
"AFAIK the best way to deal with condensation on an exterior wall is to dry line it. We dry-lined a cold bedroom in an extension and the effect was miraculous. "
Its also a very good way to hide the condensation where the eye cant see it.
Posted : 05/01/2015 8:50 am
I need to look at our windows. I think they a) have poorly insulated frames, as they feel cold, and b) have been poorly installed. Some of the doors have evidence of damp having come in somewhere but there's never any wetness inside the house. I suspect that there are gaps somewhere behind the dry lining/cosmetic bits and pieces on the inside.
Posted : 05/01/2015 8:52 am
I stripped off some wall insulation to get at electrics and there was absolutely no sign of damp or condensation, either in or behind it, trail rat.
Posted : 05/01/2015 9:03 am
woodlikesbeer - Member
I had trickle vents and would recommend against them unless you know they are quality items.
Reasons are firstly that mine didn't seal perfectly when closed, so there was a constant draft when it was windy, and secondly the trickle vents themselves would regularly need to be taken apart because they got covered with mould. The windows themselves still got condensation and mould growing on them.
Quite possible mine were absolutely rubbish quality as it was in a new build flat. But personally I'd avoid them.
Posted : 05/01/2015 9:19 am
Hey i aint saying it dont work , its a great idea if executed correctly....
Just throwing some drylining at the wall isnt doing it right.
Posted : 05/01/2015 9:24 am
I failed to get trickle vents when I replaced all the windows 2 yrs ago. I had damp/mould problems. I then found I could lock the window when it was very partially open. This combined with a bit more regular heating seems to have solved the problem. I even bought a 10 quid fan heater off Amazon to blast the area vulnerable to mould but it hasn't been necessary.
Incidentally I dealt with Quantum Windows of Corby and they were amazing for providing well-priced but hi-tech windows and ace customer service e.g. we both screwed up on the measurements for one window, I offered to pay for the replacement, they insisted on paying. I couldn't recommend them more highly and no, I am not on commission.
Posted : 05/01/2015 9:56 am
We had our windows replaced about this time last year.
I asked about trickle vents and every one who quoted didn't recommend them. They all said that there's no point having new double glazing with A+ (or whatever they are) rated frames and windows, then cutting holes in them to stick a vent in.
We went without and we do get condensation on the windows in the rooms that are slept in, but I am not sure whether trickle vents would have solved this problem or not.
It was one of those cases of not knowing what would be best and sticking with the advice of the 'experts'.
With regards to the triple glazing, we were told that it would add a lot of cost to the windows (can't remember how much - something like 20% rings a bell, but could be talking rubbish) and wouldn't be worth the extra expense.
Reading up on it, I'm sure that I read somewhere that the temperature difference (inside to outside) for an average UK winter wasn't enough to warrant it; it was only in countries that see a much lower temperature for longer periods of winter where it made sense.
That drimaster positive ventilation thing looks interesting - something else to consider for keeping the condensation down!
I installed one about 2 months ago off the back of recommendation here and the effect has been significant.
Posted : 05/01/2015 10:08 am
What are the running costs like?
Posted : 05/01/2015 10:09 am
not sure, but its drier and there is less mould in my house so I'm not too bothered.
according to the specs, the main fan doesn't draw too much and i've only got on setting 2/5. I've got the heated version that warms the incoming air if its less than 10deg so that will draw a bit more but I live in the balmy SW so it won't run that often.
Posted : 05/01/2015 10:26 am
jam bo - Member
My concern would be that it pulls in cold air and creates a draught or just increases the amount of time the heating has run for....how have you found it in that regard?
I take it, it is more of a puff of air coming in rather than a blast?
nemesis - Member
I was looking at Vent Axia ones last night and the website reckoned on something like 2.5 & 13W power consumption depending on fan speed.
The Xpelair one runs at 4-17W depending on fan speed.
Posted : 05/01/2015 10:27 am
you can notice a cooler area on the landing below where it is, but then I don't really spend a great deal of time there.
dry air is easier to heat than wet air.
average humidity levels have dropped from 75-85% to 55-65%
Posted : 05/01/2015 10:34 am
those figures are pretty much negligible then though add in the heated versions and I expect they're much higher.
Posted : 05/01/2015 10:48 am
For damp issues, we bought a good dehumidifier recently, and like the ventilation things, it has massively reduced damp and condensation.
You can see in the morning the lack of condensation on windows, you can feel the better humidity in the house.
The heating has been turned down by a good chunk as the house keeps warmer.
Clothes dry so quickly in the laundry - pop them on drier, dehumidifier in, and an hour later they are dry. Far cheaper than the tumble drier, and saves damp clothes all round the house.
FWIW, the overall performance of frames, glazing and fitting details (cold bridges around the windows) should be your overall concern, not that triple glazing must be better or that one material is better etc. For such an old house, you also need to remember diminishing returns - we have two newer windows in our house and they are the two rooms where condensation is on the (colder than the windows) walls instead of the window unit and glass...
Posted : 05/01/2015 10:58 am
Honest! I bought from John Knight Glass, they quoted £226 extra for a 3G over 2G in a 4 panel (3600mm x 2100mm) bi-fold.
I liked Schuco and Centor (C1) bi-folds. I went with alu frames. John Knight were very competitive on pricing for both (I have no links to them, just a happy customer).
Posted : 05/01/2015 1:04 pm
So what is "doing it right"? You live in an old house with solid walls and condensation running down, so you batten, line with Kingspan and cover with polystyrene-backed board then skim so as to seal the cold wall away from any moisture in the house. Our extension went from being miserable and cold to the warmest room in the house as well as the quietest. What's to lose?
These postive ventilation units... am I understanding this right? They draw in outside air, heat it a little and force it into the house. Isn't this the same as the venturi effect over a chimney sucking stale damp air up the flue?
Posted : 05/01/2015 2:18 pm
I take it then that trickle vents still aren't compulsary outside of Scotland?
Globalti - you not gonna put a moisure barrier on there?
Posted : 05/01/2015 2:26 pm
squirrelking - Member
I was told when I had mine done that if trickle vents had already been fitted previously (whether needed or not), then they had to be fitted when the windows are replaced - this is in England.
If they aren't fitted, then you don't have to have them. But you can if you want.
globalti - Member
Similar, I guess. They draw in air from the loft space, creating a slight +ve pressure in the house, which then forces the stale, damp air out of the house. I don't think that they all heat the air, although you can get ones that do.
Posted : 05/01/2015 2:33 pm
We just bought a condenser dryer and it takes just under 2kWh to dry 8kg worth of towels and duvet covers etc, whereas I'd have to leave the dehumidifier on for 8 hours + to dry the same load in the spare bedroom, so I reckon they're about equal in power consumption.
Posted : 05/01/2015 3:27 pm
You sure? I've recently bought a dehumidifier (to allow for clothes to dry in the conservatory and generally to stop it getting damp) and that's quoted at 300W at the low rating which is how I run it. At that setting it takes well under 8 hours to dry a whole load of washing plus it actually heats the room to some extent.
This one FWIW, highly recommended.
http://www.ecoair.org/DD122FW-MK5-Classic.html
Posted : 05/01/2015 3:36 pm
^ we have the same one.
Posted : 05/01/2015 3:53 pm
You sure?
Yep and I'd expect the condenser to be better.
They're both doing the same job, using the same method only the drier has a sealed volume to work on, so less losses. A dehumidifier in a room will be drying the room as well / plus air leakage as the room won't be air tight.
Posted : 05/01/2015 4:06 pm
The coatings they apply to glass these days are very good, I'd be surprised that 3G is necessary. The windows we have are so well insulated that on really cold days a fog forms on the outside of the glass. This is due to the outside pane being cold enough for moisture in the air to condense on the outside surface. If the glass was in any way warm then this won't form. This is despite the inside of the house being maintained at temperatures high enough to suit my cold blooded wife, so maybe a temp difference of 23 or so degrees, if it's a few degrees below outside.
Posted : 05/01/2015 4:08 pm
Quite a specialist bit of glass really. I'm not surprised that the cost difference was so low. For more 'normal' windows I'd expect quite a bit more difference.
Posted : 05/01/2015 4:17 pm
The outside pane cold enough to have condensation on the outside with a 23°C temperature difference, I doubt it. Some double-glazing is very good, uW 1.3 with PVC frames and coated glass, triple with the same specification will get you uW 1.1; better than the wall it's mounted in unless you have cavity-wall insulation, or insulation on the in/outside of the wall.
"Necessary". It depends what you're aiming at. In my case it was removing the central heating and being able to heat the whole house for the whole day by running the wood burner for a few hours in the evening. Triple glazing, wall insulation, under-floor insulation, double outside door. Of course it wasn't necessary, the alternative was cold spots in the house, condensation, a moaning wife, a 1000e gas bill and contributing to climatic change.
The way the uW values are calculated allows fair comparison of small windows, however, for big windows where losses through the frame are proportionally smaller the calculation flatters double glazing (or doesn't show how much better triple glazing is for big glass areas). For big windows it's better to look at the glass figures, typically uG 1.1 for double and uG for .7 for triple.
Posted : 05/01/2015 5:34 pm
 myti
We get condensation on the outside of our triple glazed window with 20 degrees inside but the wall is obviously badly insulated so really need to get that sorted now.
Posted : 06/01/2015 8:49 am
The ski chalet we were in last week in Villeneuve had lovely wooden double glazed windows just sat in the brickwork with no mastic or mortar to fill in the gaps between the brick and wooden frame, you could see daylight around the frame. Must be a French thing.......
Posted : 06/01/2015 9:14 am
Utterly wrong. Modern units will have a completely air tight seal around the edge and will, if a reasonable unit, be filled with either Argon (good) or Krypton (better) gas to prevent thermal bridging. This seal can, over time decay, but almost all units a guaranteed for 5 years with the better ones being 10 years. If you can keep water and UV light away from the butyl seal, they last longer.
That is incorrect.
Agree with this. It is possible to make a very thermally efficient window in timber using laminates including air pockets and effectively celotex, however this isn't the norm. Often modern PVC will outperform. It'll look crap though!
We absolutely get this as a 'complaint' from customers every winter. That's with a relatively standard low E argon filled unit, in a wooden frame. It happens all the time.
That brings me onto relative 2g vs 3g performance. It is possible, with the correct layup (low E coating, potentially on both pieces of glass, Krypton gas infill and other better coatings (all brad specific names currently) get a 2g to outperform a lower spec 3g unit. But you're not comparing apples with apples. Put the same coatings on 3g, fill with the same gas, it'll outperform without any question. It will however, be more expensive, and not just because of the glass, but the sash / frame needing to accommodate a circa 45mm unit as opposed to a circa 32mm one.
If you're looking to get quotes, make sure you look really closely what exact layup of glass you're being offered, an what the u value of the finished window is. There's a massive difference, and that's before we get onto solar control, self cleaning, uv protection, laminated glass!
Trickle vents are required for new builds, or any replacement windows on older properties that already have them fitted. It's the equivalent of leaving your window open a crack so that you get a bit of air in. If you tend to keep all your door and windows shut all the time, it's a good thing as it prevents damp. I've got kids and dog who leave doors open all the time so we get plenty of fresh air in the house so when it's closed u and the heatings on, we want to heat the place and not get cool air in. Don't want them, don't like the look but have to have them. I have put them on for a new window in a garage conversion I've just finished, but as soon as it's signed off, I'll be replacing the sash with one that's not got a trickle vent in it!
Posted : 06/01/2015 11:41 am
Edukator, I'm not lying, I've seen it with my own eyes several times since having them installed a few months ago. At first I though I had duff units and it was moisture between the panes, but it's not, it's definately condensation on the outside pane. Underfloor heating stat set to19 degrees, -4 Degs outside.
Posted : 06/01/2015 1:05 pm
wobbliscott, it's quite common with thermally efficient windows. Glass has come on a long way in recent years.
Posted : 06/01/2015 1:42 pm
After a conversation with a lady who does Energy Performance Certificate testing for Your Move,said that DG and TG/3G are rated the same in their assesesments. With this in mind we chose DG for our house,went with local family firm,it's a corner house so 6 windows and a front door £3.5k all in, very pleased. Fitters were a great bunch of lads,worked fast and cleaned up when finished. I kept the brews and biccies coming so all went like clockwork. 😀
Posted : 06/01/2015 2:13 pm
wobbliscott - Member
Yeah, our new (almost 1yr old) double glazing gets the fog on the outside thing on occasion. First time I saw it I thought the panels had packed up.
Posted : 06/01/2015 2:21 pm
On the workshop patio doors, there is often condensation on the outside of the DG unit......
Posted : 06/01/2015 3:15 pm
I tried to stop just short of accusing you of doing so, and now I've got a whole posse after me with condensation on the outside glass. For condensation to form the glass has to be colder than the air which must also have a very high relative humidity, if the water is not from fog then as with UFOs, I'll remain skeptical till I see it with my own eyes.
Posted : 06/01/2015 5:03 pm
Edukator, Last year I produced 11073 sashes. Every single one of those is installed in a house somewhere (UK, Italy, France, Spain, Japan, USA) This happens. Really, we have it as part of our normal 'product information' pack. I don't have any reports from Japan (in an admitidly non airtight building as it has trees growing through the roof) or Italy, but I do in Spain and a lot in the UK and US. You don't have to believe me, but you're wrong.
Posted : 06/01/2015 5:20 pm
Posted : 06/01/2015 5:23 pm
Don't think that's right - it doesn't need to be colder, it just needs to be in contact with air that's near saturated and to provide a surface for the water to condense on.
FWIW, I also get condensation outside the double glazing on some cold days.
EDIT - I reckon Pilkington know a thing or two about glass
http://www.pilkington.com/en-gb/uk/householders/faqs/external-condensation
Posted : 06/01/2015 5:24 pm
Saint-Gobain are pretty good with the clear stuff as well.
[url= http://uk.saint-gobain-glass.com/trade-customers/condensation-double-glazing ]http://uk.saint-gobain-glass.com/trade-customers/condensation-double-glazing[/url]
Posted : 06/01/2015 5:29 pm
Ok, I'm wrong. I'll have to leave the shutters open on a cold damp night and try to prove it to myself.
Posted : 06/01/2015 5:32 pm
