Towel rail summer h...
[Closed] Towel rail summer heater - What control?
[#7161675]
I'm having summer heating elements installed in the towel rails as they are fitted in the bathrooms as part of a renovation. Yay, no damp towels in the "summer"!
What method do others have to control theirs?
The standard thing seems to be to just have a switch outside the bathroom to flick the heating element on or off. This seems a bit basic to me as you have to remember to put it on before your shower/bath etc. Also it will just be heating by the time you are finished rather than having a dry towel waiting for you.
To me a timer seems the obvious thing but they don't seem to be commonly available. Is there some reason for this? any recomendations for timers?
ta
Posted : 29/06/2015 3:15 pm
Same as you but it has a built in rotary thermostat that you can lower the temperature so it doesn't remove the skin of your fingers if you accidently touch it.
[url= http://www.earthbathrooms.co.uk/products/hudson-reed-thermostatic-heating-element?variant=997209151&gclid=COmBx-iNtcYCFWbItAodO2gJUg#fo_c=879&fo_k=1be92982cae2b5face365343e12d8b41&fo_s=gplauk&utm_medium=cpc&network=google&adgroup=15739570087&campaign=220996087&search_keyword=&matchtype=&adposition=1o1 ]Like this[/url]
Posted : 29/06/2015 3:26 pm
Beware - some heater elemnts don't automatically switch off if the hot water comes on. We overheated and ruined an element by leaving it on with the CH on.
Posted : 29/06/2015 4:06 pm
Got the same issue here. The switch for our is outside the bathroom on the outside of a duct that I can access, so I'm thinking of putting a 13A socket onto the cable from the backside of the switch and then put a plug on the feed to the towel rail. I can then use a raspberry pi (already in the house and controls the electric heating) to wirelessly switch the rail on and off on a schedule.
Posted : 29/06/2015 4:36 pm
Don't think you'd have too many issues using a basic central heating timer.
I wonder if I can run one of these from the ligting circuit - there's no other power near our bathroom 🙁
Posted : 29/06/2015 4:52 pm
I don't think so. Our electrician said something I didn't understand which seemed to imply they needed some special attention due to being in a bathroom and needing a decent amount of juice. might be wrong though.
Posted : 29/06/2015 5:34 pm
A heated towel rail? In summer? What's up with you people?
Posted : 29/06/2015 5:49 pm
