Topping up power st...
[Closed] Topping up power steering fluid - anything to be cautious of?
9 Users
My steering has been making a whirring noise for a week or two. When stationary, if I turn the wheel either way, there is a vrrrrrrrrrrrr sound. I've checked the fluid reservoir and it is low. I've bought some fluid - automatic transmission fluid - which I was told is the same stuff. Are there any dos and don'ts to be aware of?
Ta
*feels a tad ashamed as at 42 years of age I've never topped up power steering fluid*
Posted : 12/05/2011 1:42 pm
No, just sling it in.
Just pour it in to the max indicator. Can be done when engine hot or cold, no matter.
My wife had a Ka that had exactly that problem and pouring in the stuff always fixed it.
Beware though - not all cars can use auto fluid in the power steering (such as Hondas apparently).
Posted : 12/05/2011 1:44 pm
As long as its the right stuff. Read the manual.
There's at least two different types of ATF!
Posted : 12/05/2011 1:45 pm
Be careful not to drink or intravenously inject any. Unless you yourself are a power steering system, in which case you may take a little turn.
Have your wheels straight.
There is more than one type of PS fluid... Make double sure it's the right stuff.
Posted : 12/05/2011 1:53 pm
What car is it by the way?
Posted : 12/05/2011 1:54 pm
Don't mistake it for eyewash.
Probably not too good for colonic irrigation either.
Posted : 12/05/2011 1:55 pm
Assuming it's the correct fluid (RTFM),
Top it up, start the engine, put full lock on in both directions a couple of times, then stop the engine and check the level again.
Posted : 12/05/2011 1:56 pm
It's a Hyundai Tucson.
I've just put ATF in without checking the manual.
What else can cause whirring noises when the wheel us turned?
Nothing expensive I hope.
Posted : 12/05/2011 1:59 pm
+1 for read the manual. My passat is mineral only for example (green stuff I think)
or maybe its the opposite,. there are different types though
My Sis-in-law's Focus made a lot of whirring noises very shortly before emptying all its Power steering fluid on my Block paving - bearing on the Power steering pump failed
HTH
Posted : 12/05/2011 6:50 pm
