toothache remedies
[Closed] toothache remedies
11 Users
I'll take any sensible suggestions
So far I've tried clove oil, painkillers, smearing bonjela on the affected area, cotton balls soaked in whisky clamped on my tooth (which is no good as I'll be driving tomorrow) and I've soaked the tooth in salt water, which nearly made me sick
Any thing else?
Incidentally, clove oils a bit mental, first time I've used it and I thought my face was going to peel off
Posted : 18/12/2012 11:23 pm
Dentist??
Although my own recent experience shows this to be pretty bloody tough to sort out
Imagine what would happen if the doctors all opted out of the NHS like my local dentists seemed to have done
Posted : 18/12/2012 11:25 pm
antiinflammatories instead of painkillers.
Posted : 18/12/2012 11:26 pm
Drink the bottle of whisky!
Posted : 18/12/2012 11:27 pm
Been to the dentist today, need root canal, but don't have an appointment for that till January 8th
Posted : 18/12/2012 11:28 pm
apparently clove oil slowly kills the nerves, but guess that's not gonna be a problem....8th Jan? - I think you need to find another dentist to do the marathon man on you.
Posted : 18/12/2012 11:37 pm
length of string, a tin of paint and a 2nd floor window is what you need. It'll sort the pain right out
Posted : 18/12/2012 11:52 pm
Pliars will do the job quickly and easily.
Oh no, he's busy, get Chaka Demus to do it instead.
Posted : 19/12/2012 12:49 am
Crush up ice in a freezer bag and lie down with it under the affected area, won't be much fun for the first couple of mins but after that you should notice a big difference.
Posted : 19/12/2012 1:00 am
Smooth peanut butter has worked for me in the past. I don't know how it works but it cured my pain instantly. I told my Dentist and he looked at me like I was 'nuts' 🙂
http://www.recoveryourlife.com/forum/showthread.php?t=114231
Posted : 19/12/2012 6:49 am
corsadyl will kill the bacteria causing the pain as should TCP, but try corsadyl first. get the original rather than the daily which is watered down. its recommended by most dentists - its only a tempoary fix though
Posted : 19/12/2012 7:10 am
If you ring nhs direct or go on their website you will be able to find an emergency dentist centre who will be able to sort you out within 24 hours. You should not have to suffer until the 8th Jan. When I had really bad toothache I used a combo of paracetamol & ibuprofen which can be taken at the same time. Also used bonjela and clove oil although I was told to only put clove oil on the tooth not the gums. Clove oil helped with the pain more than anything else.
Posted : 19/12/2012 7:57 am
