Thule roof bar fitt...
Thule roof bar fittings
[#13535897]
I have old Thule roof bars for my now dead Mondeo and I want to get some new fittings to re-use the bars on my wife's Fiesta. I think all I need is new roof fittings.
Are there any Thule gurus out there with recommendations of a website with the details I need. I thin I just need new bar clamps and roof fitting kit
Posted : 12/06/2026 10:35 am
Halfords (shudder will give the you the kit numbers you need. Just don't buy them from there out of principle, my recent experience of their customer service doing this was horrendous.
Just check you existing bars are still compatabile with the newer clamps, although compared to the clamp / feet pack rpices the bars are the cheap bit.
Posted : 12/06/2026 11:44 am
If you have bars with slots in the underside the the latest footpacks and fitting kits will fit. Thule bars are several different lengths - 118cm and 127cm being the most common. You may be able to to use a longer bar on a car designed for a shorter one i.e a 127 instead of a 118 but generally not the other way round. Also going up two sizes is normally not possible as the underside slots are not long enough.
As someone said the footpack is the most expensive, then the bars then the fitting kit. New fitting kits don't fit older footpacks.
The three main footpacks are flushrail, fixed points and under door clamp - there is also a raised rail but not many cars have those any more (unfortunately).
Every flush rail has a different profile so requires a dedicated fitting kit.
Posted : 12/06/2026 1:05 pm
You will need: bars, footpack, adapter kit.  You have the bars, the footpack might fit your new vehicle but probably won't, the adapter kit is very model-specific.
Posted by: ElShalimo
https://www.roofbox.co.uk/
Posted : 12/06/2026 2:09 pm
Thule website has a thing that lets you see what parts you need
Roof racks & roof bars for cars, SUVs & vans | Thule | United Kingdom
Posted : 12/06/2026 2:10 pm
 TedC
Courtesy of roofbox, as linked above, only had to get new adaptors (£45) to move bars from Jaguar I-Pace to Ford Fiesta. Officially the bars are longer than spec’d for the Fiesta, but all fits with no issues other than not blindly following the “number settings” for the width of the foot packs on the Fiesta.
Posted : 12/06/2026 5:45 pm
Thanks
How did I forget Roof box company 🤦. I've emailed them
@cougar - They're your old bars and are still perfectly functional
Posted : 13/06/2026 5:34 pm
Just beware - I have an old set of square bars for my Mazda 6 (no roof rails) that do not fit my ID.7 (roof rails). Similar sized cars but I couldn’t slide the new feet close enough together on the bars as the channel they sit in doesn’t go all the way end to end. I presume if you were going rails to rails or no rails to no rails this wouldn’t be an issue.
Posted : 14/06/2026 7:50 am
Thanks
My god! 😂  I'd forgotten all about that.  For the benefit of other readers, they're the old Aerobars with T-track fittings.  They started out their life atop a Mondeo.
There is - was? - a configurator on Roofbox's website.  I'm sure customer services will sort you out though, I've had nothing but good experiences with them.
Posted : 14/06/2026 10:35 am
ElShalimo reacted
Just a heads up that there is an era of Fiesta that has no roof rack homologation so you won't find a compatible set of feet.
Save yourself some grief and go on somewhere like the Roof box Company and put in the registration.  If it doesn't bring up any products there's a good chance it's not roof rack friendly and you can stop there.  You might also be able to work out and order the various kits while you're there.
Edit. Sorry skipped past all the people suggesting them.
Posted : 14/06/2026 11:45 am
