The electric car *c...
The electric car *charging* thread
Posted by: convert
At the end of that 5745kwh at standard rate of course you would have spent £1149 more on electricity than you would have done if you have been charging it at the 7p kw tariff.
Indeed, but without the £1149 spend on a charger [that may not actually charge any quicker on some occasions.
However.......what's the story with domestic household insurance and granny charging as a long-term solution? I've no idea as I've never researched it.
Me neither so I've no idea - but it's no different to plugging in an oil filled rad.
Posted : 08/12/2025 5:53 pm
its quite different . an oil filled rad doesnt draw a constant 13amps.  - but then neither do granny plug chargers - its capped at about 10amp but constant.... melted the plug inside my outdoor socket due to lack of airflow when the hatch is closed.
having been using a granny charger with mums car till i got a 7kw installed - i wont be bothering messing around with the granny charger - infact i dont think the car ill be buying even has one ..... might go to a 32kw commando or might go with a charge point but either way itll be charging a full power once or twice a week rather than a pittiful amount every night.
Posted : 08/12/2025 7:03 pm
Does anyone use Ionity for public charging?
Posted : 09/12/2025 12:22 am
Posted by: IvanDobski
Having been on the wrong end of a burning Project EV charger and their utterly shit technical support (across several issues) I strongly suggest you look at a different make.
They're beyond useless.
Very interesting, thanks for the heads up.
Posted by: convert
Try ChargedEV - one of the national chains doing EV charger installs but on the EST approved list.
Cheers for this, I've got on to them and started the quote process with photos, online survey etc. I can charge at work so not in a mega rush, happy to wait a few months if necessary for one of the national firms.
Posted : 09/12/2025 9:59 am
 mert
Posted by: trail_rat
I guess it depends how cold/draughty/crap your house is.
Do you have the option for "constant draw/load" sockets? I know i've seen them for schuko in 13A and 16A flavours. Rated for up to 4000W continuous. I was looking before i realised i could get my 3 phase up and running for almost zero effort.
Posted : 09/12/2025 10:27 am
There's a new British Standard for EV sockets which are basically higher continuous load.  The socket standard was BS 1363 but the new one is BS 1363-2, imaginatively.
Posted : 09/12/2025 1:57 pm
Interesting to read the above
For us I looked at getting a dedicated charger installed at the house but in the end it was going to cost in excess of £1400 for the most basic of chargers.
We don't use the EV that much, charging it on average once a week (52kWh battery), so I did a quick working out and we are better to just use the 13A granny charger. Overnight charging is absolutely fine, we are not in a hurry for it to charge and it may even be better for the battery health in the long run to charge slowly.
To recover the £1400 would take 4 years, by which time I'll have got rid of this EV, so it'll actually cost me more! And with all the uncertainty's at the moment over how the government will tax EV's, and the continued trend for public charging getting more expensive per kWh (Capitalism doing what capitalism does) I'm not yet convinced this is the way forward for us.
Whilst I do very much enjoy the EV itself, personally the numbers don't add up. If I was having to constantly be charging it up then I'd likely get something installed. But then again, I'd probably not as for the high miles we use the good old Diesel Volvo...
On a side note that new BS for EV sockets is handy. At the moment I have a dedicated outside socket anyway and I use an RCD with it for the granny charger. I might change it out to one of the new dedicated EV ones if there is any benefit...
Posted : 09/12/2025 2:51 pm
Posted by: doomanic
I use them when going on Holiday in UK as they are handy on the route we use. I take out a monthly subscription to get the cheaper rates then cancel it after each holiday as I charge at home 99% of the time.
Posted : 09/12/2025 3:02 pm
doomanic reacted
Is it possible to connect a 13amp 3-pin plug into a home wall charger using some kind of adapter? I have a charger at home and need to (ironically) charge the battery on my other, petrol, car. I don't have an outdoor socket so I can either run a long extension to the car or take the battery out and charge it indoors. However, the charger is right next to the other car so it would be convenient to use it, if poss.
Thoughts?
Posted : 15/12/2025 2:55 pm
Posted by: oomidamon
Or does your EV have a V2L function you can use, so you can plug the battery charger directly into the EV ?
Posted : 15/12/2025 3:08 pm
Good point, it might.
Posted : 15/12/2025 3:46 pm
There's this sort of thing on Amazon but I'd make sure your charger isn't whacking 32A through it before walking away for any length of time.
www.amazon.co.uk/TKSE-Charging-Adapter-IEC-62196-Black/dp/B0DCZJZNT3
Posted : 15/12/2025 4:37 pm
oomidamon reacted
 rone
Posted by: andy4d
Posted by: doomanic
Yep. Not many on the M1 but reasonably well spaced. (Leicester is good) The stations are always tidy and clear and away from congestion.
More on the A1.
Never get close to that big 400kW though 😉
Max I've had is 80kW when on bigger trips. They have a partner too with similar technology. Can't remember the name.
I make myself a member of big trips.
What's the most power anyone has had?
I despise all these down London where you have to pay top dollar and a parking fee etc.
Posted : 15/12/2025 5:51 pm
Electricity doesn't work like that.  The load draws current based on the voltage supplied.  32A is the maximum available.
Posted : 16/12/2025 9:09 am
oomidamon reacted
I was watching the video of the Octopus guy explaining their changes and noticed the bit about them really wanting customers to plug in whenever they are at home (so they can load balance). I can understand the advantages of this but in practice I only ever plug in just before I go to bed and wondered what others do.
Octopus can't talk to my car (just the charger). So, I have to tell it how much I want it to add each time I plug it in*. It then designs a schedule (which it then often changes multiple times). My "issue" is, what happens if I then decide I want to pop out again?
I'm not entirely sure how I stop it charging once it's started. I had this issue a few weeks back when I initiated cabin warming before the time I had told Octopus I wanted the car ready. It then started drawing power from the charger, which sounds like a good idea but it took me ages (and lots of random presses of buttons on various apps and in the car) to get it to stop and release the charge cable. Still not sure exactly what button did the trick. That's obviously just user error, but still puts me off plugging it in until I'm sure I'm not going to want to go out again.
*Actually the amount it adds seems to bear little relation to what I ask for and varies so much that I usually just ask for a fair bit more than I need then set the level I want in the car and let it stop the charge at that level, which I'm sure isn't what Octopus want either.
Posted : 16/12/2025 11:57 am
On our ID7 and Zoe you just press the unlock button (car for ID and dedicated for Zoe) and pull the cable out. It relocks after a short period. No need to stop the charge first.
Posted : 16/12/2025 12:33 pm
Thanks @nixie
I think my problem was that I've got used to using the digital key (i.e. just using my phone to unlock and drive the car). A bit of googling suggests (as you said) that the simplest way to unlock the cable is just to press the unlock button on the key fob. Maybe I'll just go back to carrying a key. It's hardly a big deal.
Posted : 16/12/2025 12:54 pm
I turned KESSY off before we had even finished handover so always use the key.
Posted : 16/12/2025 12:59 pm
My new EV (i picked it up yesterday) is currently sat outside my work being charged whilst I wait for home charger to be installed, hopefully next week.
I'm currently with Fuse energy and my ChatGPT calculations suggest that I'm better off staying with Fuse rather than moving to Octopus. This was based on daytime household usage (7000 KwH per annum) and EV charging expectations (8k miles per year, nearly all charged at home). Fuse is has less extreme range between peak / off peak costs so whilst charging overnight will be more expensive, this is more than offset by lower daytime rate for everything else burning though power in the house.
When I was doing my calculations I estimated shifting 20% of current load over to off peak usage, mainly tumble drying and dishwasher. Am I missing something in my calculations, does this shift and outcome sound about right?
Posted : 16/12/2025 1:24 pm
Yes, that's probably safest. I just find it seductively cool to use my phone. To the point where I now use it for pretty much everything. It seems amazing to me that I can walk out of the house with just a front door key and my phone. The phone will unlock and start the car (as well as warm it up for me in advance), I can use it to pay for pretty much anything I buy, it stores my train/plane tickets and my railcard, allows me to access my bank to move money between accounts, navigates me to anywhere I want to go, sends messages (text, whatsapp, email etc) to anybody I want to contact. I can even phone people if I really want to. All from a device that fits in my pocket. It really is amazing when you think about it. But I do remember my granny saying something about eggs and baskets 😀
Posted : 16/12/2025 1:32 pm
Same on my e-niro. It has keyless unlocking but you need to have the fob in your pocket so I always have it with me.
Posted : 16/12/2025 1:36 pm
Does the phrase 'single point of failure' mean anything to you? I hope you don't work in IT.
Either my wife plugs it in when she gets home or she just opens the flap on leaving the car then I plug it in when I lock up.
Posted : 16/12/2025 4:27 pm
Posted by: molgrips
Must resist sounding like Jay from Inbetweeners......
Posted : 16/12/2025 5:04 pm
Are you seeing many public chargers with their cables missing? Seen it a couple of times in the Birmingham area. Big bank of chargers this morning near Ikea and half have had the cables cut off despite having the anti theft sleeves on them.
Posted : 21/12/2025 5:24 pm
Has anyone else noticed their car not charging since Octopus announced their changes? I don’t know if it’s to do with that or the latest ID software update on the car that went on around the same time but I frequently plug in and come out in the morning with little or no charge added. This morning i woke up, the schedule says it should be charging but it clearly isn’t. I’ve got octopus integrated to the Zappi charger which should have been sat in boost mode but wasn’t. Wondering if I should go back to integration direct to the car or if it’s an octopus problem or…
Posted : 23/12/2025 8:15 am
A few people on various ID7 forums have trouble with the car "going to sleep" if there's a break in the charging schedule and then not waking up when it resumes, resulting in not getting the requested charge. It seems like they're linking the charger to Octopus rather than the car - I've always had IOG configured to control the car and not had any issues (Hypervolt charger rather than Zappi though).
Edit - their issues predate the last SW update so it's not new behaviour for them
Posted : 23/12/2025 8:29 am
Posted by: bassmandan
Yes, it started after the ID software update for me. I've got the car connected to octopus. It feels like the car is going to sleep and Comms are lost. When it happens if I check the VW app the last sync time is the previous evening around when I plugged in. The car does not sync till I unlock it, presumably that wakes it up. After reading some threads that suggested each system had a energy bucket to use and that a system might be exceeding that I changed the setting in the app called "Optimised battery use" to on. This allows the traction battery energy to be used when the car is off. Since changing that charging had been more reliable. I can't remember if this was on it off before the ID update, off I think.
Posted : 23/12/2025 9:02 am
Posted by: nixie
I'd always had that on as it allegedly prevents issues with the 12v battery draining if the car is left unused for while
Posted : 23/12/2025 9:08 am
It's a stupid setting IMO. No clear explanation of what it does and what explanation there is makes me think it's not something the user should control.
Posted : 23/12/2025 9:11 am
No issues with my Kia EV6, Octopus linked to Ohme charger, car is not linked to the charger. Sounds like a VW issue. Have had the 12V battery go flat though, Kia blame their own App. Apparently if it keeps pinging the car it can flatten the 12V battery. Have to remember to close the app after use.
Posted : 23/12/2025 12:03 pm
Saw some new chargers at the garden centre. Just checked and there are now 37 DC chargers within 2 miles of my house! When I got my first EV there were 2.
Posted : 23/12/2025 12:09 pm
Posted by: franksinatra
Has anyone got any thoughts on this?
Posted : 23/12/2025 12:15 pm
It really depends on the practicalities/realitiy of of shifting that 20% load to off peak.Do you really want tumble driers and washing machines running during the night? Will the noise, keep you awake?
When I remember, I use the delay function for the dishwasher to run off peak, but I've been woken by it on occasion.
A spinning washing machine would definitely wake me up as our bedroom is over the kitchen and utility room.
We have 2 EVs covering about 20k miles per year so we are on Octopus Go and the numbers do stack up - or at least I think they did last time I could be bothered to do the analysis.
Posted : 23/12/2025 12:26 pm
Thanks all. Interestingly yesterday for the first time I had a message in the app saying I couldn’t use it to unlock the car as the internal battery was low and suggests I turn on the optimised battery usage. I’ll give that a go and see if it makes any difference. I could integrate the car with octopus but that means any other vehicle on my charger won’t take the overnight rate, and worse, if the car is plugged in after my wife has been driving on her profile, it doesn’t do the intelligent charge.
Posted : 23/12/2025 10:20 pm
Really? Not seen that behaviour.
Posted : 23/12/2025 11:31 pm
I always say this and always people rip the piss, but fire service advice is to not run equipment unattended or overnight. To save a few pence isn't worth the risk IMHO. Yes, it's rare, but i have a mate who left dishwasher on overnight, awoke to a smoke alarm, couldn't get down the stairs because of the smoke, and got to safety through a window and a neighbour's ladder. Another mate is a fireman and reckons two breaths of smoke and you're already incapacitated, a few more and you're done for so gambling a smoke alarm has time to wake you in time to come to, to orientate yourself and then get out isn't a safe bet.
Posted : 24/12/2025 12:32 pm
I bet they hate the utility companies then for promoting exactly this.
Posted : 24/12/2025 12:54 pm
Posted by: nixie
Maybe it’s changed, I switched from car to charger integration months ago. But we had a couple of occasions where she came home and plugged in, and I guess because the API integration was with my credentials Octopus didn’t have the visibility of the charge status so we did a ‘full’ charge at the normal peak rate.
Posted : 24/12/2025 1:03 pm
My Kia Niro is struggling charging with the cold - or at least not being very efficient. It's not gone above -5 in the day and down to -8 at night for the last couple of days. IOG gave it 25% last night as requested but the battery only went up by 13%. Similar pattern the last few nights.
My pet theory is that with the IOG plan breaking up the planned charging into small 30min or 1hr windows throughout 12hrs it was always charging a cold battery.
I might go against the Octopus recommendation and not plug in every day and let the car drop to a low level of charge, forcing IOG to plan a longer continuous charge cycle.......or just tell it that has 60% charge to do when it only has 20% so it plans a good long blast.
Posted : 29/12/2025 9:57 am
Posted by: rone
That said I can see the benefits eroding over time with cheap rate windows getting smaller/price increasing as more move to using EVs and charging during cheap periods
Exactly this.
It's the usual bait and switch model.
We're all being encouraged to do something and as more of us change to EVs etc it will flip the other way.
Yes we could all use less energy but it's on the government to invest and find a solution to make life better not worse. We as consumers don't really have much of a choice.
The competition for EV type tariffs is riseable. They're all roughly the same with ever so slight complications.
A total mess as usual.
TBH I think one the greatest benefits of an ev is if you can generate your own electricity,  I think  you’re just on the same track as petrol/diesel if you’re buying it in.
Although It’s tricksy sums as too how much you need for your daily driving and the cost of something like solar.(it’s to easy to get on the bragging rights of how cheap you can charge whilst neglecting the fact that your initial outlay is crazy high).
Posted : 29/12/2025 10:46 am
Switch to normal scheduled charging (by just deleting charger from IOG Octopus app) and see how it goes. Schedule 11:30pm to 5:30am for cheap electrons. You can reconnect IOG and charger by adding it again to Octopus app later, I think you only have to schedule one charge a month via IOG to stay on the tariff.
Posted : 29/12/2025 11:14 am
convert reacted
I’m just about to pull the trigger on octopus intel go and one of their fitted ohme chargers to charge my Skoda kodiaq hybrid. The Skoda cannot work directly with octopus so I need a charger that can. Seems to make sense to me to go with one that octopus supply in case of any compatibility issues later on?
Posted : 29/12/2025 11:46 am
Not sure about that - home solar barely touches the sides of the average car use.
Posted : 29/12/2025 11:49 am
Tbh, whilst I've not done the maths, I'm struggling to make this make sense.
EVs can take advantage of cheap overnight leccy by default (unless you work nights and your car is not at home overnight). So your home solar system is competing with 7p kWh power. And unless you do hardly any miles or have a roof the size of a football pitch it's not going to generate enough to cover all your miles, just some. That's a pretty sizable investment in solar and a battery for not a lot of financial gain.
There are a couple of folk near me with their own wind turbines - now that would maybe make more sense...but I can't believe they are cheap, even if you have the land in a suitable location.
Surely a solar and battery setup that completely irradiated the need to buy expensive daytime leccy for your domestic use is a better and more achievable objective.
On a good clear day I can drive 10mins to coast and see the tips of the turbines of my nearest offshore wind farm. Whilst I know that those elections specifically are not what ends up in my car it 'feels' like a sensible setup. We just need electricity prices properly decoupling from the price of oil and gas.
Posted : 29/12/2025 12:02 pm
Posted by: burko73
Definitely go for a compatible charger, but do some research first as you have a few options, especially if you do not want to get locked in with one provider or want to integrate with battery etc. I can recommend the Hypervolt.
Posted : 29/12/2025 12:19 pm
Page 16 / 27
