Syringes, needles, ...
[Closed] Syringes, needles, tubes and end caps
[#1912823]
I want to demo micro gas experiments at school. Having previously been on a course learning how to safely do them I know I need the following, but not sure of the technical terms
Syringe - easy enough
needles - easy enough but need to be of a larger bore
tubing - IV tubing? would that be right?
y splitter/joiner - to join two iv lines/tubes together.
end caps to block of the syringes.
Anybody know what the technical words are that I am looking for?
Example of experiment would be to collect chlorine in one syringe and ethybe in the other, using two tubes connected to a final y section place them in water push to get a nice reaction.
Posted : 19/08/2010 11:09 pm
check SP services, probably find everything you need there.
Posted : 19/08/2010 11:13 pm
js holdings will have all the tubing "y" connectors and syringes etc.. I use them for bits of kit for work
http://www.jsholdings.co.uk/products.asp?owner=9
Posted : 19/08/2010 11:15 pm
Cheers,
It's a sod trying to search for something when you know what it is, but not knowing the correct term limits the searches.
Posted : 19/08/2010 11:20 pm
