Suspended floor ins...
Suspended floor insulation
Hi , I live in a 60s bungalow and need to replace the chipboard floor in the lounge, obviously it’s a good chance to insulate, the joist are probably 6x2 with another foot or so of void below, what thickness insulation should I use? What type? Celotex, normal loft insulation? Wall slabs? Do I need a gap between the chipboard and insulation? Thanks all
Posted : 08/02/2023 9:10 am
 colp
I used a breathable wool type held up with a breathable fabric stapled to the joists. Made a massive difference. No problems with damp 10 years later
Posted : 08/02/2023 9:17 am
 Olly
10 or 150mm Cellotex is normal i think. Youll need to put some form of support to hold it up under the floor boards, be that battens along the lengths of the joists, or across like noggins, i dont think it matters.
Ours is tight to the underside of the floor.
I might look at finding some form of simple cheap L bracket that you can fit with a staple gun, that would be nice and easy.
Or a 6mm batten on each side, with a staplegun that will do 15mm
or just cut it tight enough that it wont budge on its own?
Posted : 08/02/2023 9:56 am
Given that the amount of heat lost through the floor is significantly less than the ceiling/walls I'd be fitting normal loft insulation.
[if you're doing this from above - which you should if you value your sanity] Staple plastic mesh to the sides of the joists to create a cradle and then put the insulation on top.
Way cheaper and quicker than celotex.
Posted : 08/02/2023 11:12 am
