suggest an am2+ com...
[Closed] suggest an am2+ compatable MITX motherboard
hello all,
I am looking for a MITX (mini itx) mother board that is compatable with an AMD AM2+ processor.
I have looked and can't seem to find many about (as I appreciate AM2 is rather long in the tooth now)...
trying to built a small compact pc for my brother with left over parts from my builds (hence the AM2 processor)
help appreciated
liam
Posted : 11/05/2015 10:07 am
I don't think there are any, there are some decent FM2+ ITX boards available and an Athlon X4 CPU's are relatively cheap.
Your other option is to see if there are any MATX boards available that will support the CPU you have.
Posted : 11/05/2015 10:38 am
I built a PC up around this one:
http://www.amazon.co.uk/dp/B00B5LI1G8/ref=cm_cr_ryp_prd_ttl_sol_0
if you can find any stock of it. Very happy with it still two years later.
Posted : 11/05/2015 12:52 pm
As i suspected.changed the intial wording.
now looking for an AM2+ Matx
reason for AM2 is i have a tasty ableit old processor.
Posted : 11/05/2015 2:16 pm
If you think you have a tasty processor then the chances ae it is one of the hex core Phenoms II X6 series released in 2010.
If that's the case it is actually an AM3 CPU which means you are in luck;
http://www.dabs.com/products/asrock-970m-pro3-am3--970-ddr3-matx-B78M.html?utm_source=awin&utm_medium=affiliates&utm_content=AW00&awc=3044_1431356277_e09024205cab63f49a01ba26355bc219&utm_source=awin&utm_medium=affiliates&utm_content=AW00
If you don't have an AM3 CPU then I think you should look at modern CPU' s ๐Ÿ™‚
Posted : 11/05/2015 3:58 pm
