...with minimum modification to the fireplace itself as it's stone and we want to leave it in place.
Looking at the Salamander Hobbit, anything else we should consider?
If you're looking at an inset stove, the Clearview vision inset is very good and fits a standard 16" fireplace. Got ours on eBay and cleaned/re sprayed and new seals and it looks like new.
Not inset, should have mentioned ๐
Don't go for a multi-fuel for such a small burner - we did and rarely use coal, shouldn't have bothered.
[b]Do[/b] go for a multi-fuel. You can start with smokeless and build up a good bed of embers, on which to burn your logs. Logs alone don't burn too well, especially big ones.
we have a yeoman CL3 which would be a tight fit. good stove.
Yeah, I was thinking multi fuel, any other suggestions?
Dunsley Highlander 3, but I haven't looked at its size...
http://www.dunsleyheat.co.uk/highlander3multifuelstove.html
clearview stoves all the way for me - well worth the extra expense
Doesn't look like Clearview do anything small enough
We've got a Dean Forge Croft. It's excellent. Wood or multifuel, can be changed over (easy-ish job - remove multifuel grate, plug a hole with fire cement). Does the swirly secondary burn thing on logs very well.
Dartmoor 5 is small, should fit a standard opening.
[url= http://www.deanforge.co.uk/content/doc/lib/2829/new-brochure-2103-2.pdf ]pdf wotsit[/url]
Previously, we've had a Villager Puffin in that size opening but I wouldn't recommend it TBH (overpriced and really a coal only stove).
You have two choices, inset or knockout the fireplace, a freestanding stove in an opening that size would not conform to regs and in my opinion would be dangerous.
could always stick it out in the room forward of the opening to give clearance?
Interesting - twinw4ll can you direct me to these regs?
Hmmm.
Regs seem to suggest no minimum clearance as the fireplace is stone (Diagram 26 Page 38), or am I missing something?
[url= https://farm6.staticflickr.com/5208/5227213560_ef61fb2923.jp g" target="_blank">https://farm6.staticflickr.com/5208/5227213560_ef61fb2923.jp g"/> [/img][/url]
[url= https://flic.kr/p/8XUQtJ ]Woodburner[/url] by [url= https://www.flickr.com/people/28828204@N04/ ]Mrs NBT[/url], on Flickr
That our Stovax Stockton 4 in the opening left by a "normal" open grate fire, fitted by an approved installer and resulting in a certificate and so on.
To elaborate on the multifuel thing - if you're only lighting the fire for the evening, we find that wood is enough. We have tried various types of solid fuel but there isn't the critical mass in the fire to keep it burning overnight (I grew up with a coal fire so am quite used to keeping a fire in all week) without ripping through vast quantities of coal. A bigger fire would be better but at 4kW, I would go for a simple woodburner next time
I have a Firefox 5, the cleanburn version.
It's very nice and works well with either coal or wood.
I like having the option to burn either fuel as in winter, I tend to keep it ticking over with coal. The rest of the year, burn a log or two if it gets chilly, for the cosy effect, apparently.
If it's to shoehorn in like this, don't! This one was a real danger, as well as putting out very little heat.
[img][url= https://farm3.staticflickr.com/2879/9775927832_9f5bd0ca03_o.jp g" target="_blank">https://farm3.staticflickr.com/2879/9775927832_9f5bd0ca03_o.jp g"/> [/img][/url]
[url= https://www.flickr.com/photos/60407271@N04/9775927832/ ]Stove fitted by a bad, bad man[/url] by [/img]
As twinwall says, go inset or dig out the fireback. An inset fitted right works really well.
Aarrow I400 works well if you want to keep the existing surround with minimum fuss.
[img][url= https://farm6.staticflickr.com/5533/12091412035_50a3f58853_o.jp g" target="_blank">https://farm6.staticflickr.com/5533/12091412035_50a3f58853_o.jp g"/> [/img][/url]
[/img]
And I don't know why my pics have been flipped! They're the right way up on flickr ๐
We've got a Town and Country Rosedale inset (as recommended by Fireglow in Bolton who fitted it) which is excellent.
Charnwood C4 is a cracking little stove.
