Sparkies - remote s...
[Closed] Sparkies - remote switches?
Does this exist? I want a light switch that can operate an existing light but also wirelessly operate a second hidden socket somewhere else. I fancy under-cabinet lights in the kitchen operated from the main light switch.
Posted : 22/08/2015 10:25 am
Yes. There are a few home automation brands. You get slave plugs and inline controlers (for lights) and/or replacement switch units. You can then add a wall switch to control them. The posh ones have multiple buttons that you can set up as different 'moods'.
Posted : 22/08/2015 10:28 am
For cheaper solution (because home auto is silly expensive) you can get remote switching relays on eBay. They use a car key fob kind of remote. Mine lives on the shelf in the kitchen near the under cabinet lights it controls.
It's not perfect but it works and cost v little
Posted : 22/08/2015 10:32 am
Needs to be activated via the same switch as the light, or one next to it. Otherwise I'll put a switch in by the worktop.
Posted : 22/08/2015 10:53 am
Have a look at lightwaverf on ebay. £50 or less for all the bits I'd guess.
Edit:
I'd do it with...
Lightwaverf master
Lightwaverf slave
Lightwaverf 2 gang socket
Which is how my living room is set up (all the wall sockets are lightwaverf)
Posted : 22/08/2015 11:05 am
Hmm.. the dimmer stuff is too "smart" I just want a basic on-off switch, but they do relays which might work.. hmm..
Posted : 22/08/2015 1:05 pm
Yeah, you could put a blanking plate over the switch and wire it to on then stick a relay in. The master switch is only a few mm thick, you could stick on the top of the blanking plate.
Posted : 22/08/2015 1:38 pm
Hmmm.. Actually.. A normal hidden socket and a motion sensor under the cabinets would be easiest and possibly best...
Posted : 23/08/2015 1:40 pm
