For starters 8)
Girls Aloud are f-ing awesome, by the way ๐
[color=blue]slainte 8) rob[/color]
aphrodan - strut (aphrodub mix)
Played so loud it just becomes noise - my fave ๐
This weekend I discovered Clann An Drumma. Don't bother unless the amps on 11.
Hell, if you play any track from this album and your speakers still work afterwards then you've played it wrong...
Everything is best played loud through a weighty system ๐
๐
and
๐
Queens of the stone age - first it giveth
Tricky to follow DezB on these threads! That's awesome. The video probably helps ๐
Psalm69 [b]needs[/b] to be turned up loud. You really can't listen to that at a sensible volume!
Good to see a bit of Senser too!
This is still giving me goose bumps after quite a lot of play:
and here's one for teh lolz:
Off every movie trailer ever - I always imagine playing in the back ground when I do a totally sick and gnarly 1ft drop off into mince.
Mogwai reward patience
balls,how do i embed videos?
sausagefingers, you need to use the full url - the one without the . in youtu be
Stranglehold--Ted Nugent
Pretty much anything by the Wedding Present would get my vote in the best played loud category. Put on Bizarro and turn it up to 11 ๐
Good call on Senser!
Lutes! Flutes! Hurdy Gurdys! METAL!
VIKINGS!
the originators of folk metal, although the those johnny come lately up there with mrs toast are good as well ๐
Blimey, Bug Powder Dust (awesome!) and [i]Rush[/i] (ahem!) in the same post? How'd that happen? ๐
oooh, that's reminded me about this (skip to 00:35):
The mighty Du
The Cult - She Sells Sanctuary
If you have a sub, turn it up to 11..... then let Dillinja loose on your soundsystem.
Breaks at 1.50..
And now some filthy bass in the form of dubstep...
Play loud and when the drum kicks in at about 1 minute th hairs on the back of my neck stand up, every time.
really liking this at the minute
raging speedhorn - thumper
heh I was in a band with the growlier of the two "singers" for a while. Not really my thing but playing with someone sounding that beastly was awesome ๐
Any album from this lot
While I've got my golden oldie head on
that's enough of that
Great thread but no Motorhead
[url=
[url=
OK, since the thread's going in a classical directio
This is a slightly iffy recording but somehow it works better than the clean version i found. BOOOOM.
And speaking of BOOOOM let's try something a little different. Britrock + heroin =
high on fire
Massive Attack - Angel
