Solar panels on she...
[Closed] Solar panels on shed
Considering fitting solar panels on shed roof to power a light and have a battery for a socket.
Anyone done this and got any advice.
Thinking it would be easier and cheaper than getting power from the house.
Posted : 16/08/2011 10:30 am
How big a panel? How good a battery? How much will this all cost vs an Electrician to wire this [socket/light/supply/board]?
Posted : 16/08/2011 11:07 am
What would the 'socket' be used for? Portable radio or 3kw heater?
I would have though solar would be quite an expensive solution.
How about a leisure battery running some LED lighting that you recharge perhaps once/month?
Posted : 16/08/2011 11:35 am
Errr... assuming your shed is "average" size you're not going to fit many [url= http://www.spiritsolar.co.uk/solar-photovoltaic-feed-in-tariffs.php ]solar panels[/url] on top, therefore limiting the amount of energy produced (not to mention we don't get much sun over here) and the whole idea of getting solar panels doesn't seem so cost-effective any more. Or am I wrong?
Posted : 16/08/2011 3:10 pm
put an extension cable to it.. much cheaper and cheaper to run..
Posted : 16/08/2011 3:52 pm
Please don't listen to all of this practical advice. You're about to install a solar panel on a shed - and for that I applaud you.
Pamper your shed. Pimp it up. Make it your pine 'ho, bro. That's what us British males do.
Posted : 16/08/2011 3:55 pm
akira
I can only presume you are trying to make plans for a modest supply of electricity from a solar panel on the shed.
I have read stuff on the net about home brew systems using a panel to charge a 12V or multiple 12V car batteries (in some cases free ones from the scrappy or your local motor faactors) that then go on to power 12v LED lights and a small stereo. Unfortunaely i do not have the links on my work PC.
I would really think you would struggle to set up a system to power any high drain electrical items.
I have preiously though of doing this but have never had the time or money to do it properly - not that it is necisserily going to cost alot but i am still in the process of decorating my flat and my man cave has been put on the back burner till i get the living room sorted.
Posted : 16/08/2011 4:00 pm
 trb
Sounds like my shed.
12V trickle charger from maplins, old car battery. Couple of 12v lights from Go outdoors, old car radio, job's a good 'un.
If you need instructions & links to do that I'd question your ability to tie your own shoes ๐Ÿ˜‰
I only have to go indoors for more tea & a wee
Posted : 16/08/2011 4:07 pm
trb
you need to invest in a camping stove and a tree ๐Ÿ™‚
Posted : 16/08/2011 4:09 pm
Not really needing much power, lights for a bit of bike fettling when it gets dark and maybe running a radio every now and again.
All seems simple enough after doing a teeny bit of research, cheers for the positive replies and shame on you to the negative people, you shall not be receiving an invite to my midnight shed parties! ๐Ÿ˜‰
trb, how much light time do you get on average?
Posted : 18/08/2011 2:13 pm
200w power pack from maplin - 35 quid
http://www.maplin.co.uk/200w-portable-power-pack-225153
Q)
Can I charge this unit using a solar briefcase?
A)
Yes the product does support that.
Solar briefcase - 10 quid
http://www.maplin.co.uk/12w-2w-solar-briefcase-348075
i've no idea if this will work nor if it will provide enough power. I guess you could always carry the power pack in a charge it up if the solar panel doesn't work too well in winter when you need the power more and there is less sunlight.
Posted : 18/08/2011 2:23 pm
TRB - you go indoors for a wee? what's wrong with the rest of the garden?
OP - I wouldn't bother with solar stuff, just run an extension lead to the house. My shed has been running like that for 11 years!
Posted : 27/09/2011 10:25 am
I wonder how many of those solar arrays + leisure batteries you'd need to run an electric heater for 1 hour a day!
Posted : 27/09/2011 12:39 pm
