I was at work at the time, so if anyone can post any good links to the best observations, photos and stories that would be ace.
Is that a squadron of imperial tie-fighters?
Not quite. It's a multiple exposure showing the International Space Station traversing the eclipse.
likely story!GrahamS - Member
GrahamS - Member
You sounds like a propaganda officer for the empire!
ISS transit is cool.
I hope that's a proper biscuit, like a ginger snap.
Lots of shots filtered / unfiltered pointing directly at the eclipse which to me doesn't go close to showing what the viewers might've experienced. One bit I did see was on here in Nebraska with the NASA coverage and an actual unfiltered pan up to the eclipse at 2:35:50.
That 82nd airborne thing's a big fat composite/fake fo-sho. Where do I start...?
Megalike for Cougar's friend-friend.
Having had a look, you're right. Hadn't seen the later corrections!
Definitely requires a time/place/flightradar mash up to identify the plane.
I took this shot from Clemson, South Carolina, just as totality ended.
I've stitched together a series of shots into a very short timelapse video:
I've been planning this in my head for 18 years since I went to France in 99 and it was clouded out. This was my first experience of a total eclipse without cloud cover and it was absolutely amazing, I now understand why eclipse chasers do what they do.
Yeah, I have to admit I went on a long planned cornwall trip for '99 and was clouded out too. It's still on my to-do list!
more here:
https://fstoppers.com/originals/top-10-solar-eclipse-photos-found-around-web-193043
there are a few images of the same scene from slightly different angles.
Actually from last year but they all look the same!
Destin captures it brilliantly including the ISS transit:
Friend of a friend took this, combination of skill and luck AFAIK.
Im going to call BS on that one.
[quote=trailwagger ]Friend of a friend took this, combination of skill and luck AFAIK.
Taken by Kirsten Jorgensen
Shot of a lifetime. This print is available for purchase in multiple formats to those who asked at https://fineartamerica.com/products/solar-eclipse-with-plane-kirsten-jorgensen-art-print.html #nikon #nikonusa #nikonphotography #eclipse #eclipse2017 #photography #photograph #picoftheday #photooftheday #d5200 #dslr #instagood
First pic in the link I posted
https://fstoppers.com/originals/top-10-solar-eclipse-photos-found-around-web-193043 <
trailwagger » Friend of a friend took this, combination of skill and luck AFAIK.
Taken by Kirsten JorgensenShot of a lifetime. This print is available for purchase in multiple formats to those who asked at https://fineartamerica.com/products/solar-eclipse-with-plane-kirsten-jorgensen-art-print.html #nikon #nikonusa #nikonphotography #eclipse #eclipse2017 #photography #photograph #picoftheday #photooftheday #d5200 #dslr #instagood
First pic in the link I postedhttps://fstoppers.com/originals/top-10-solar-eclipse-photos-found-around-web-193043
Doesnt mean its real. Can you explain why the underside of the plane appears to be lit? Surely it would be a silhoutte?
It also reminds me alot of this
http://www.bbc.co.uk/news/world-asia-35457135
Wouldn't it be lit a bit by the light reflected off the Earth?
During a total eclipse? I doubt there would be enough light bouncing back up to light the undercarriage of a plane that must of been flying pretty. In a shot that has such contrast between the remaining sun and the total blackness surrounding it, i would expect the plane be a shadow. Certainly the nose of it, which is outside of the sun and entering the blackest part.
It's light reflecting off the conveyor belt.
The shadow of the eclipse is only 114km across. That leaves a lot of lit up Earth.
But isn't that how we [i]usually[/i] see the underside of a plane?
But isn't that how we usually see the underside of a plane?
Yes but not how a camera would see it when exposing for the extreme light part of an otherwise 95% black frame.
Hmm.. maybe.. I don't think anyone looking for the perfect eclipse shot was shooting on auto-exposure.. but you [i]could[/i] be right about the dynamic range required.
