Got a Golf with the RCD300 stereo in it. Looking for something that will integrate an iPod nicely with this. By nicely I mean that track lists come up on the head unit display and it's all friarly straight forward to use (otherwise mrs blobby will complain endlessly.)
I was thinking of just getting one of the parrot hands free kits that allow you to plug in an iPod, but don't know how well integrated these solutions are (not that clear on their web site.)
Anyone got any other alternatives/advice...?
i changed the head unit for an Alpine on my old Octavia, and the new Polo just works from new.
Both work fine and are easy to use.
You could look at the Dension ICElink - dead easy to fit but it doesn't show up on the head unit.
However you can get them with cradles for most cars (I assume the Golf will be available) so you just simply use the iPod controls so it is pretty foolproof.
EDIT: Linky http://www.ipodcarkitdirect.co.uk/VW_iPod_Ice_Link_Plus_Adapter
And when you change car you can whip it out in minutes and sell it on Ebay.
Kenwood head unit over here - plugs straight into the iPod via a nice long cable. All wires + iPod are hidden out of view 🙂
iPod is controlled via the head unit too.
We have the same head unit. It's unable to display text so you will not be able to show tacks/playlists on it regardless of what system you use to connect the iPod - to get this feature you'll need to fit a text capable head unit (not difficult).
I fitted a [url= http://www.dension.com/product/ipod-car-adapter/ipod-iphone-auxin-id3/gateway-100 ]Dension Gateway 100[/url] to our Golf and it's great. Dont really miss the track listings as I ran the connector cable to the little pocket in front of the gear stick so you can easily pick the ipod up and select artist/almub/playlists etc.
Pretty easy to fit too.
I wouldn't bother with BT connection as sound quality isn't quite as good (mate has one).
Thanks chaps. May well go for the Denison gateway 100 if it's nice and easy to fit. Does it charge the iPod too?
Yup - [i]Charge your iPod/iPhone while driving[/i]
You buy two bits, the gateway itself and then the correct wiring loom for your car/stereo.
[*]Installation process is as follows:
Remove the 'tray' on top of the dashboard
Remove the stereo surround
Undo a couple of screws and pull the stereo out a bit
Remove the esisting wiring loom from the back of the stereo and plug into one end of the new supplied loom from Dension
Plug the other end of the new loom into the stereo
Push the stereo back into the dashboard
Refit surround and dashboard tray[/*]
Realistically takes 10 mins. There are loads of howto's for removing the stereo on t'interweb.
Gateway will charge the iPod and you can control it from the head unit/steering wheel or the ipod itself.
You can also connect a USB drive and a BT connector for your phone as well if you want.
Sounds pretty good. Does it work ok with an iPhone 4? (i.e. will it charge it properly?)
Not sure, ours doesn't charge a 3gs properly. But we've had ours for nearly two years so they may well have changed the gateway to reflect the 'new' charging voltage.
Edit: Just checked and we must have a v1 of the gateway, subsequent versions should charge fine. There is an [url= http://www.dension.com/iphone-ipod-car-accessory/12v-5v-converter ]adapter available[/url] for the v1 to allow it to charge the 3g, 3gs, 4 (most likely).
Just done a bit of googling and it looks like you need a different cable and some power booster for iPhone 4. Not a big deal as I was going to just play stuff from an old iPod. Shall give this a go.
Thanks all for the help.
You sure? I'd check with Dension. I thought the charging voltage was the same for the iPhone 3 and 4 in check case the v2 or newer of the gateway will be fine.
you're googling may be giving results for people who have a v1 gateway and need the adapter (link above) to change the voltage.
Thanks sharkbait. Checked the comparability thing on the Dension site and it still wasn't clear about the iPhone 4 charging. Brought the xcarlink one in the end as it claims to be ok with iPhone 4 and seems to be pretty much the same thing.
sharkbait you for got the bit where the heater vents drop out and fall apart and your wife spends the next 2 years moaning at you to go but new ones from vw
or maybe that was just me, gateway works well though!
the page has gone all weird!
SSS.... I think that's just you 😉
aparently not!
http://www.golfmkv.com/forums/showthread.php?t=98827
part number here if you too have made a mess of your dash!
