Shed ridge beam siz...
[Closed] Shed ridge beam size help
[#9709349]
Hi
Im about to start building Shed-1 (5m x 2m). Its gonna be built from 3x2 or 4x2 mostly. I want the pitched roof to be held up with one beefy ridge beam thats supported at both ends with the rafters off of that. The roof will consist of 11mm OSB and metal corrugated sheet on top of that.
SO my question is what size ridge beam will I need for 5m span? Was thinking 8x2? What do you all think??
[img] ?raw=1[/img]
Posted : 07/12/2017 9:44 pm
Minimal load on that beam really. 8x2 or 9x2 will be reet.
Posted : 07/12/2017 10:33 pm
Hi, as above, no load on the ridge beam, just something for the rafter ends to push against, very often sawn inch timber deep enough to cover the cut rafter ends. You will need ceiling joists to stop your walls pushing out though.
Posted : 07/12/2017 10:38 pm
If the joists in that shed are well connected to a 9x2 acting as a ridge beam they'll be no need for triangulation/ceiling joists. I have a much bigger shed with a tiled roof using this arrangement. I used joist hangers at the connection but that would be overkill on a shed this narrow.
Posted : 07/12/2017 10:42 pm
Yes as the others have said. 6x2 would be a sensible choice with a few horizontal timbers from rafter to rafter to hold them together to prevent spread. And stick a few noggins in to stiffen it all up.
Sorry, yes it's a shed with osb / tin roof so no real load or need for joists, still in house roofing mode!
Posted : 07/12/2017 11:30 pm
Brill thanks 8x2 it is.
I'm hoping as ridge is well supported on wall at both ends, the rafters won't need any trusses? I want to keep roof open like so:
Posted : 08/12/2017 12:01 am
 pk13
nobody asking what pitch it is? I know it never snows anymore but keep in mind the downward force of extra weight. oh and c16 8×2 is fine. maybe use bigger sized rafters and stick 25mm kingspan in between to keep it cool in the summer.
Posted : 08/12/2017 12:39 am
Thanks PK, standard shed pitch I guess 🙂
Posted : 08/12/2017 10:26 am
My victorian farmhouse must have had a new roof at some point since then as they used a few lengths of molded skirting board. That seems happy enough with several tonnes of slate. 🙂
Posted : 08/12/2017 10:53 am
