Shaving and proper ...
[Closed] Shaving and proper razors
Cougar - Member
Yeah, thanks for the info. I saw someone mention a 'sampler' pack of blades, that's very tempting.
Presumably "adjustable" razors refer to blade depth? Is that hugely desireable, or just something else to get wrong? (-:
Probably something else to get wrong IMO.
If your technique is good then you will be able to shave well with a non-adjustable razor. You have to make little tweaks to your technique to get it good. If you have an adjustable then the temptation will be to continually tweak rather than concentrate on your technique and you will just end up frustrated and with a sore face!
Sampler packs of blades are a greta idea because, as noted earlier in the thread, people rate blades very differently.
Posted : 01/09/2010 1:00 pm
Yes, adjustable razors allow you to expose more (aggressive) or less (mild) of the blade. They certainly have their place but I think a fixed blade is certainly the place to start (removes some variables). Once you're comfortable with the technique (i.e. getting the angle right) then you can think about whether an adjustable is for you.
I bought an adjustable Futur as my first razor and although it was fine (set it on '0' to start with and now up to '2' where it will stay) I soon bought a couple of old Gillettes which are great to use. I now appreciate the Futur more having got a better technique and will keep hold of it as it gives the closest shave but a fairly mild fixed razor is fab for a quick/good shave and is my goto piece of kit.
Expensive doesn't always mean better.
Posted : 01/09/2010 1:21 pm
Exactly what I was worrying about. Cheers guys.
My solution was to just wear stubble
To be honest, that's usually what I do as well. I certainly don't shave as often as I should do.
For me, this was the absolute opposite.
Fair enough. It'd be boring if we were all the same, it's good to know that what works for one doesn't always work for another.
Posted : 01/09/2010 1:45 pm
This may be a stupid question from a convert of a couple of months but.....
I'm using a Parker 90r (double sided) with 7 o'clock blades which I am happy with at the moment. Question is can you, or should you, turn the blade over as and when it feels as though the sharpness has dulled slightly, or even flip it over on a regular basis? Does it make any difference?
Posted : 01/09/2010 1:51 pm
 sv
Had my first ever DE shave this morning - still alive! Worked ok still need to work on technique as some of the more 'angular' parts aren't as good as they could be. The easier areas feel smoother so I plan to stick at it. Used a cheapo Wilkinson razor/blades, also ordered that selection pack and an Alum block and got a free set of Gillette blades thrown in (shaving shack orders over £10).
Merkur from Santa 😉
Posted : 01/09/2010 1:52 pm
Life is just to short to fanny about with blades on your skin.
Posted : 01/09/2010 1:58 pm
Amen molgrips.
*buzzzzzzz*
*swish*
Job done.
Posted : 01/09/2010 2:18 pm
 jond
Or even
"Life is just to short to fanny about debating the ins and outs of scraping the hair of yer face."
I've got a pretty sensitive skin - shaving every day in my teens/20s would leave my face like a piece of raw meat after a week, but *probably* because I was shaving against the grain.
Only shave once or twice a week but don't get any of the irritation I used to with, guess what?
Razor (40-60s era no idea what)
Blades (whatever's in the supermarket, which typically isn't as fancy as Gillette of Wilksinson Sword)
Bog standard washing soap (or whatever's available)
No faffing around agonising over brushes, foam etc.
If you lot are this bad over shaving, gawd knows what you're like about bikes 🙂
Posted : 01/09/2010 3:11 pm
"It's different for me, therefore you're wrong."
No.
Posted : 01/09/2010 3:13 pm
I did used to go against the grain. The reason being that going with it had little effect, leaving loads of stubble that jsut got really irritated when rubbing on anything.
Free your chin.
Posted : 01/09/2010 3:17 pm
If you mean take the blade out and turn it over.... no it will make no difference.
Jond:
Those will probably be Persona blades - not that your bothered 😉
Molgrips:
Posted : 01/09/2010 3:30 pm
Doh! now look what's happened after reading this thread...... bought another old Gillette. This time a late '40s Aristocrat Junior for less than £12.00 - certainly worth a lot more than that 🙂
Posted : 01/09/2010 3:46 pm
sharkbait - Member
Where did you buy it from?
Posted : 01/09/2010 3:59 pm
Haven't got time to read through all the other posts, so my apologies if this is a re-post.
Have you tried [url= http://www.winkelplein.nu/barbershopsuply/default.asp?sid=fqEwu5Tz76SngqBIYlVUxeq2tIiJXe ]THE DUTCH SHAVING SHOP[/url].
I got one called Lord Metal Double Edge Safety Razor -Krabbertje.
Been very happy with it so far. I'm still in the process of finding the best blade, oh and the nicest soap.
Here is a little more detail.
Lord Metal Double Edge Safety Razor ,,Premium,, Lp.1822.
Lord Sterling 3 pieces Razor is made according to the high standards to give you a premium shave ever get.It,s durable metal parts hold the blade at the perfect angle to the face .This critical angle along with Lord blades makes your shaving smoth and close all days long.
Lord has be owned by Schick-Wilkinson for a long period of time.
3 pieces metal quality razor for a nice price.
Comes with 1 lord double edge Razor Blade.
Best Tested by the shaving forums.
Lord The Art Of Shaving-Made in Egypt.
I bought a selection pack of blades and so far the best have been the Lord ones. Funny that! Still only another 53 blades to use.
Posted : 01/09/2010 4:09 pm
HoHum: the Bay of Thieves. Not entirely sure the seller knew what it was 😉
Posted : 01/09/2010 4:27 pm
LOL That was a nice one. I've been beaten on a few over the past couple of days. I'm wondering how many have been bought by people from STW?
Come on, own up 😉
I 'won' a black Wardonia in a 'Service' box but the pic was so bad it was hard to tell which model. Worth a punt for £1.99!
Posted : 01/09/2010 5:08 pm
Not me.... I've been intent on not looking at razors until the other day. I'll stay away for a while now (maybe).
That said looking at the prices of the razors on SafetyRazors.co.uk there's obviously some money to be made - there's a Gillette Ball End Tech on there for £30 and I bought mine for £3.00!
I suspect a good Aristocrat Junior would go for about £65.00, so even if I had mine replated I'd still be £40.00 better off. People are now realising that the vintage razors are sometimes better than the new ones and the prices are rising accordingly.
Posted : 01/09/2010 6:24 pm
sharkbait - Member
Thanks.
Just been having a look and there are a lot of interesting things for sale on there.
Hmmm, I think that I will have a more detailed browse later on 🙂
Posted : 01/09/2010 6:32 pm
How often do you change a blade on a DE razor? Every shave or can you use them several times? I'm looking for a cheap razor on ebay now, anything in particular to look out for?
Posted : 01/09/2010 7:24 pm
sharkbait - Member
Bloody hell ... that's a steal 😯 . I have been trying to get hold of one but the bid always ended higher than I thought.
Bought 5 razors (2 double and 3 single edge) for £3 at local antique market because one of them was a Gillette Fatboy. One aluminium safety razor and 3 single edge razor which I don't use but simply look at as I bought it only because I spotted a Fatboy.
Posted : 02/09/2010 12:18 am
motivforz - Member
Changing blade depends on individual. Yes, you can use them several times. I change blade once a week which is ok for me but not for some especially if you have wire beard.
There are some good ones on ebay at the moment such as:
1) Item number: 330464016471
2) Item number: 300461283757
3) Item number: 120614400290
4) Item number: 220660636341
5) Item number: 280555839135 (doubt you need all of them but ...)
6) Item number: 220660636341
7) Item number: 290469425549
8) Item number: 130426461040
9) Item number: 150487010105 (could be expensive i.e. > £60)
10)Item number: 260658307042 [b](you might want to start with this one)[/b]
11)Item number: 260658309070 (will be expensive i.e. > £65)
12)Item number: 260658309585 (will be expensive i.e. > £50)
13)Item number: 260658728407
14)Item number: 260658731529
15)Item number: 260658732239 (nice but not for you as it's open comb)
16)Item number: 220662974316 [b](60s Gillette Super Speed ... go for it)[/b]
17)Item number: 250689583112 (fatboy & barber pole ... good)
18)Item number: 290467287669 (this one but price is sky rocketing ...)
19)Item number: 330467547185
Any of those listed above should be a good start except item 15 and 17 open comb which may be a bit risky for you.
I have highlighted item 10 & 16 (both 60s SuperSpeed) which I think are very good in terms of the condition. I have one myself.
Most are Gillette Tech that I think you could start with but should not pay more than £10 to £12 including delivery but some are sold by charity so it is up to you.
There are few items that highly sort after and I can see the price sky rocketing at the last minute so I shall just sit and watch. 😆
Just clean it or wash it then boil with hot water and you are good to go.
:mrgreen:
Posted : 02/09/2010 1:37 am
Funny you should list a Gillette Super Speed chewkw as I bought one of those last night after reading the reviews on Badger and Blade 🙂
Posted : 02/09/2010 9:33 am
Nice research chewkw ..... you've got too much time on your hands! I wish you hadn't posted that though as I'm now looking at them 😥
In reality I think there's only one more Gilltte I would like now but its so closely related to th Aristocrat Junior i got yesterday I may not bother.
Not sure I'd boil a shaver as some coatings can be damaged by water that is too hot. A good soak and scrub with Mr Muscle should also do the job.
Prices are certainly rising aren't they!
How much did you pay for the SS Ho Hum? Think I paid £15 delivered for my '53 model including a small [modern] leather case.
Oh one other little bit of info: if you buy a razor that has worn plating Dave at Safetyrazors.co.uk will strip, replate and polish it for £15.00.
Posted : 02/09/2010 10:22 am
Christ, you really can sell any old sht can't you? :P)
Posted : 02/09/2010 10:34 am
Yes..... yes you can 🙂
Posted : 02/09/2010 10:39 am
sharkbait - Member
I think it was about £15 in the end delivered from the USA. I should really go and check. No case though.
The reviews I read on Badger and Blade were really positive and that was what swayed me in the end.
I can't wait until it arrives now!
Edit - just checked and I paid £16.27. It also said it was a Super Speed Flare Tip. Off to google to find out what Flare Tip means....
Posted : 02/09/2010 11:15 am
Nice one. Flare tip is the one with the conical door opener on the bottom. Great razors - nice small head that makes doing the tricky bits much easier.
Posted : 02/09/2010 11:40 am
I've got a Merkur futur which I've been very happy with for around 5 years.
But just recently I've been finding it difficult to get a nice shave from it (I've been cutting my face more and getting uneven shaving across the blade). I put it down to a faulty batch of blades for a while, but examining it last night I found some significant patches of corrosion on the parts which hold the blade in place - to the extent that I think they are deforming the shape of the cutting edge.
I find this a bit disappointing to be honest - has anyone else's suffered from this or is it just mine?
BOAS
Posted : 02/09/2010 12:42 pm
Just a note to say thanks guys. I came across an old (1917 date stamp) brass Gillette travel razor that I've had kicking about for years. Motivated by this tread, off I went to Boots to pick up blades, soap and styptic pencil. Wow, I'd forgotten just how good a shave it is. Quick, easy, close and remarkably bloodless - no need for the pencil.
And if any one's interested, [url= http://cgi.ebay.co.uk/Lot-26-Vintage-GILLETTE-Safety-Razors-/280555839135?pt=LH_DefaultDomain_2&hash=item41526e5e9f ]these are on fleabay just now[/url]
Posted : 04/09/2010 9:00 am
I've been clearing out my late Uncle's house recently and this thread prompted me to find his old razor, which I'd seen but previously ignored.
It's a Rolls Razor Viscount, just like this. I think it's early '50s. Everything like in the picture except the instruction leaflet.
I've honed it and stropped it and tried a shave myself but it's not really my thing.
I'm going to go back to my Gillette Sensor Excel with Tesco Gel and put this feller on eBay.
Unless anybody has any other ideas...
Posted : 09/09/2010 10:25 am
Ebay would seem to be the place to sell vintage razors mate.
I was amazed by how many were for sale.
Fingers crossed that it is very collectable and you get a decent price for it 🙂
I was experimenting with my shaving set up this week and tried out a Merkur blade I had kicking about and although it was nice and sharp it did scrape my skin places and left it feeling quite raw so I went back to the yellow Gillette blades this morning and had a much better shave.
Posted : 09/09/2010 10:32 am
Well the Sensor Excel/gel idea is completely pants, but the idea about eBaying the old razor is a good'un. I bet you could get good money for that (which you 'could' put into a normal doubled edged razor).
Posted : 09/09/2010 10:33 am
If anyones in Gairloch, theres a bric a brac shop which had something looking very similar to that thing Bigjohn posted, I think it was 2 quidoud need to rummage tho, I think it was to the right of the door.
Posted : 09/09/2010 10:56 am
There's a shaving shop opened in our town, so i went to get myself a new razor. ended up with one of those Merkur Futur things. £50 for a razor? I must be mental. More money than sense, etc, etc. Then I tried it. second shave, up to 2 on the adjustor. 24 hours later, still smooth. what an utterly awesome shave. I've always reckoned the razor is just a carrier for the blade, but this is just soo different. So, £50 - steep, but very very good.
Posted : 09/09/2010 1:43 pm
Folks,
If you need a good shaving brush at reasonable price then you might want to consider animal friendly [b]Boar brush[/b] like this one I just ordered today.
This one: Semogue 620 - £13.08(including tax) + £2.21 delivery from [url= http://www.shaving.ie/categories/Shaving-Brushes/Boar/ ]www.shaving.ie (Ireland)[/url]
They are also having sale on 200 bulk pack Gillette Yellow 7 O'Clock Sharp Edge for £24.56 (including tax) + £3.31 delivery.
[url= http://www.shaving.ie/products/200-Gillette-7-O-Clock-Sharp-Edge.html ]Gillette Yelow 7 O'Clock Sharp Edge (www.shaving.ie)[/url]
The Gillette Yellow 7 O'Clock Sharp Edge and Iridium Super Blades are both brilliant blades with the latter out of stock. I am waiting for them to stock up Iridium again (250 bulk pack) before I order and am considering ordering Gillette Yellow tomorrow. So with all these blades I am going to have I will just have to wait for the nuclear war to start and still enjoy my shave every morning.
p/s:
BigButSlimmerBloke - Member
You should look at really desirable classic Gillette safety razor and your £50 will not even go near in buying one.
As for Merkur adjustable I prefer the classic look of Merkur Progress Long Handle 510001 or Merkur Progress short handle.
[url= http://www.shaving.ie/categories/Safety-Razors/Adjustable-Safety-Razors/ ]Here from Shaving.ie again ... [/url]
Posted : 09/09/2010 6:28 pm
My Gillette Super Speed arrived on Saturday and I tried my first shave with it yesterday and I was very pleased with the results.
The finish of the plating is a little bit tarnished in places, but not bad considering how old it is.
I may have to look into having it replated to bring it back to its former glory!
Posted : 13/09/2010 11:30 am
Posted : 13/09/2010 11:33 am
Thank you sharkbait.
I will have a look into that and will probably go ahead and get it done soon.
Posted : 13/09/2010 11:38 am
This razor thing is becoming as bad as my mtb addiction. I have now picked up 4 different razors + a load of different blades which came with them, a badger brush and some nice shaving soap at a total cost of around £70. Apart from the soap, I think I have enough to remain clean shaven for at least 10 years!
FWIW I've found the best/closest shave is with the Parker/feather combo as the handle is longer than the others and the weight feels 'just right'. The Merkur HD/Seven o'clock is also very nice but I've only used that a couple of times so far. The others also give a good shave and TBH there is nothing wrong with the £3.99 Boots one. It does exactly the same job!
Posted : 15/09/2010 2:10 pm
A friend of my wife directed this
http://www.imdb.com/title/tt0371208
Posted : 15/09/2010 4:14 pm
I found a bowl of erasmic soap in a chemist the other day. Awesome lather and great shave. Just thought I'd share.
althiugh I did like this image I found when googling for erasmic images
Posted : 15/09/2010 4:28 pm
Reading this reminded me that in about 1963 my dad got a single razor blade as part of a "consumer survey" i.e. try it, and we'll be in touch to find out what you think.
It was unbranded and he recalls that it not only gave him the best shave he'd ever had but it lasted about 10 times longer than usual.
Oddly, the market research people never got back in touch. This led to all sort of conspiracy theories, like Gillette had sabotaged the research etc. etc.
Posted : 15/09/2010 4:37 pm
Yesterday I bought one bottle each of this from my local barber shop (well about 2 miles away). They are also selling them on Ebay so just search for the name of the product or Maguires Barbershop and you will see their products. The Italian aftershave is a bit difficult to find so I was surprised to find someone selling them in the Toon.
Proraso 400ml
Floid Blue 400ml (Italian version not Spanish as the latter contain high alcohol)
Both have nice scent that I like as they are not overpowering like cologne. The scent can last for 1 to 2 hour which I prefer so everything is good. Got both of them with barber style aftershave atomisers like this one.
[url= http://www.shaving.ie/products/Barber-Style-Atomiser-for-Floid-Aftershave-Bottles.html# ]Barber style aftershave automiser[/url]
I also briefly tried Floid Amber at the barber shop like this one and I like the scent too but most people prefer the Blue. (will buy this later)
I haven't managed to buy Erasmic shaving soap locally but I am not bothered as I can find Palmolive shave soap stick (49p - 69p), Palmolive shave (lather) cream in toothpaste type tube (£1.58) and Ingram shave (lather) cream in toothpaste type tube (£1.68 - £1.75) easily. IMO Palmolive shave stick is by far the best and far cheaper too. I bought eight ... 😆
Price might be a more but with 400ml that will last you a long time ... :mrgreen:
Time to see how the chicks react to all this manly scent 😆
Posted : 15/09/2010 7:59 pm
Just picked up a 48p palmolive stick and a £3.48 shaving brush and got this as the "you'll probably want this too" voucher
Can only assume tesco monitor STW and assume I'm going to attack myself with a 60's razor!
Soap and brush gave a brilliant shave with a modern razor so I'll not be buying expensive foam again!
Posted : 16/09/2010 8:45 pm
no, no, this what you want, about £1.50 from Tesco or Boots. dab, sting, sorted
Stops bleeding faster and cleaner
Posted : 16/09/2010 8:52 pm
Right then.
I've just taken delivery of my new (old) Gillette safety razor - [url= http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=350393567467&ssPageName=STRK:MEWNX:IT#ht_760wt_1049 ]this one[/url], I think it's a Tech.
Do I call the ambulance before I start or get MrsG ready to call halfway through? I live in a rural area.
Posted : 23/09/2010 10:19 am
Nice razor freddyg and an excellent price as well!
From what I have read the Tech is supposed to be quite a mild shave in terms of aggressiveness.
Have fun anyway.
Posted : 23/09/2010 10:48 am
I'll try.
I must admit I'm a little nervous. I've had loads of cut-throat shaves, but they've always been performed by someone who knows what they're doing. My 25 years of shaving has always been with multi-blade jobbies.
There was a single unused blade in with it, but I'm going to hang on until the new Derby Extra blades turn up.
Posted : 23/09/2010 11:31 am
just take your time, shower first, plenty of lather (soap and brush, not foam), cheeks first, very unlikely to cut yourself so get some confidence and do the tricky bits, under lip and under nose last. don't press against the skin, just hold the razor against the skin, it'll work. maybe try it without the blades in just to get the feel, remember run the blade across the skin, don't press against or into it.
Posted : 23/09/2010 11:43 am
Inspired by this thread, I picked up an el cheapo WS razor at the weekend, fiver from Boots. Not tried it yet.
If this turns out to be my last post on here for a while, it's because I'm in A&E.
Posted : 23/09/2010 12:42 pm
Well I'm not dead and I'm not posting this from a pool of blood on the bathroom floor. I'm actually quite impressed and, more importantly, so is MrsG.
BBSB - thanks for the tips. Worked really well.
My verdict, so far, is that I'm going to stick with it. I think my technique needs some work as there parts that still feel like they could do with another going over. I gave it two passes over two days worth of stubble, trying to go in the direction of growth (but below the jaw line, the growth is in different directions - odd). The result is slightly better than my trusty old mach 3 and I do feel a little razor burn; however, as my technique improves, so will the quality of the shave.
I've 'invested' in a few different types of blade to try - at a couple of pounds a pop (for 10 blades) it'd be silly not to; also sourced some samples of shave cream from Taylor of Bond Street and Geo. F. Trumper - they smell great.
Posted : 24/09/2010 10:54 am
A good aftershave balm will help to calm down any razor burn.
I bought some Body Shop Razor Relief yesterday and used it this morning and it certainly does what it says on the tin.
Posted : 24/09/2010 11:20 am
freddy - first pass with the growth, second against it. third across it if yiou can be ar5ed, don't usually bother with the third myself.
if it's your first go, well done, you'll get better and faster with practice.
I use that erasmic soap i mentioned at the top of this page - >£2, nice smell and once the brush is loaded I can lather so i look like santa claus twice. found it in an independant chemists. never used post shave other than after-shave (high alcohol contebt, nippynippynippy)or witch hazel (no smell). Might try some of that body shop stuff hohum mentioned.
Cougar, are you still with us? hello? cougar? anyone know his blood type?
Posted : 24/09/2010 12:25 pm
Yep, first go. I might have another go this evening as even though it's only 6 hours since the last one, I can feel some growth already. I'll try a different blade (I used the unused 7 o'clock blade that came with the razor - it was donkeys years old).
You mention that the second pass should be against the growth - is that right? I thought that was a guaranteed way of getting burn/ingrowing hairs etc.
As for Cougar - he's still around, hopefully there hasn't been too much blood-loss. 8)
Posted : 24/09/2010 1:29 pm
 sv
Very lightly in both directions works well for me. I await my new/old Tech to arrive and have a feather ready to go when it does! Thanks to STW I have been DE shaving for about two weeks now, razor burn has disappeared! Technique just about sorted 😉
Posted : 24/09/2010 1:51 pm
shaving's an up to you thing. some places say first pass with, second against, third across, others say second across, third against. i do with then against and that's it. i think as long as the first pass is done properly you should be free from ingrown hairs. i've only ever had razor burn from being too enthusiastic about the settings on an adjustable razor and setting too aggresively for my skin.
the important thing is get comfortable with handling the razor and making sure you don't erupt (blood/spots/rash) then, when you know what works for you, start taking other people's advice. when that turns out to be crap, because it will, it's your skin, you'll know how to revert to something that works for you.
😳 <shiny red face>
EDIT - and as pointed out above [b]VERY LIGHTLY[/b] is the way to go
Posted : 24/09/2010 2:03 pm
left side below the jaw = left to right, right side = back to front
I thought it was just me
Posted : 24/09/2010 2:05 pm
That's a great combo. The Tech is a very mild razor and works well with a very sharp blade.
I'm currently using the Aristocrat Junior I got a few weeks ago with a Feather blade and it's really good but will also try with a Derby blade as I seem to get on very well with them.
can't decide whether to sell either the AJ or the SuperSpeed - I like them both but they are very similar.
The Tech is nice to keep as I only paid about £4.00 for it and the Merkur Futur is just a beast for when I need an extrea special shave - just love the noise as well!
Glad you guys are enjoying the experience - isn't it great to have a real choice of what to shave with? 🙂
Posted : 24/09/2010 2:38 pm
freddyg: the Tech is a great starter razor but I can guarantee you'll love something a little more agressive in a couple of weeks.
Posted : 24/09/2010 2:40 pm
"Red".
Still here, aye. Not had a go with the new razor yet, for various reasons. Might have a punt at the weekend.
Posted : 24/09/2010 2:46 pm
In related news, I was looking at these 'sampler' packs of blades the other day. Fifty quid looks like it'll keep me in blades until my kids die, and I don't have kids.
Posted : 24/09/2010 2:48 pm
[i]the important thing is get comfortable with handling the razor[/i]
+1. first few shaves resulted in pink water until I realised got the balance right.
merkur hd
derby blades
virgilio valobra soap
muhle alum block
i do need a new brush though. any recommendations?
Posted : 24/09/2010 6:18 pm
sharkbait -
Member
I've seen the term 'aggressive' used a few times but, as a newbie, I'm not sure of its exact meaning; can you enlighten me?
Posted : 24/09/2010 7:20 pm
freddyg - Member
sharkbait -
Member
It's to do with how much of the blade is showing.
A very aggressive razor shows lots of blade and you need to be very careful with it or it will bite you. However, with a very good technique you will obtain a very close shave.
A mild razor does not show so much blade and is more forgiving. However, you will never get a really close shave.
It's swings and roundabouts as with everything in life.
Posted : 24/09/2010 7:31 pm
 sv
Which Merkurs are aggressive then? Liked the look of the long handled 34C maybe a progress or futur as I have the tech on it's way. Take it the 34 and the tech are similarly mild?
Posted : 24/09/2010 7:37 pm
futur's adjustable.
a more aggressive setup is more likely to give a bit of burn, so if you're going to use an adjustable, start mild (1) and work up.
Posted : 24/09/2010 8:33 pm
The progress is adjustable as well.
I am seriously considering ordering one tonight as I am beginning to suffer from the DE shaver's disease Rapid Acquisition Disorder.
Hmmm, just one more razor can't hurt and it will be adjustable as well so I can tweak it to suit me and there's room in my bathroom cabinet and...
Posted : 24/09/2010 8:45 pm
razor bling?
i like the futur because it has a touch of "the day the earth stood still" about it, so it will always look a bit special no matter how many superspeeds, techmatics, calvacade of sports you find competing with your bike bling for your attention
it has to be the matt model, not the chrome one - too gangsta bling
Posted : 24/09/2010 10:55 pm
Been trying to bid for some safety razor on the bloody ebay only to be out bid every time ... damn!
Oh the above 3 bottles of aftershave are brilliant! I love them all but the Amber Floid might come out top for me.
Should I buy the Progress and a few other things?
It's Friday night and I am pished and they will do wonders for my shaving ability...
Posted : 24/09/2010 11:05 pm
1) Merkur Progress to start with as it's a good razor.
2) Blades like Iridium, Gillette Yellow Sharp Edge, Astra or Personna to start with as any of them will be good. 78p to £1.60 per pack of 5 blades. (get one pack of each to start)
3) Cheap alum stick from Superdrug for £1.75 (5g).
4) Semogue 620 Boar less than £15.
5) One Palmolive shave stick 48p to 69p.
6) One small bowl to lather up.
7) Aftershave ... any of the above but perhaps 100ml to start with.
8 ) Boot's witch hazel ... 200ml for £2.59. (does not smell good by the way but very effective as aftershave. You apply it immediately after finishing your shave and wash it out with cold water after 1 or 2 minutes time before apply proper aftershave like those above).
So apart from the initial set up cost you will be good for a long time.
oh ya ... Do Not apply pressure when you shave as you will get razor burn after that. Only apply very light pressure so that the razor head can do all the work for you. Do 3 passes ... with the grain, across the grain then against the grain for final shave. Do not shave the same spot over and over again because that will give you razor burn as well.
Posted : 24/09/2010 11:15 pm
LycraLout - Member
chewy - buy it now
Do you know what model it is? If it is a Big Fellow / Big Fellow Deluxe I would go for it.
It's in France ... hmmm ... a bit far?
Posted : 24/09/2010 11:31 pm
no idea, did a quick look for bin's. picked up a late model superspeed for £15 posted that way. i'd go with £25 for an old gilette can't be bad
Posted : 24/09/2010 11:39 pm
I don't have to get any more but somehow I just want to keep buying ... LOL! I want to try something more heavy like Fatboy.
Posted : 24/09/2010 11:45 pm
if you want heavy, try and get your hands on a futur - seriously weighty, but looks not to everyone's taste
Posted : 25/09/2010 12:09 am
ooooooohhhh
Posted : 25/09/2010 12:12 am
I prefer the traditional looking ones like Progress or HD so not that keen on Futur so the only way is to go stainless steel which I am saving up for one at the moment. In the meantime I do like the look of Gillette Big Fellow but it's one that is so damn hard to get.
Posted : 25/09/2010 12:13 am
Ohhhh ... 😯
Those cut throat razors look rather dangerous there.
Posted : 25/09/2010 12:22 am
that's a '57 superspeed that is, and an '82 on the right
Posted : 25/09/2010 12:32 am
Page 2 / 3
