Searching for value...
[Closed] Searching for value in .xlsx cell
 benz
Simple way to explain.
I have a list with 'Tom', 'Dick', 'Harry'.
In another list I have long text which may have "On Tuesday 27th May, Tom caught a bus with Dick and Harry".
If I wanted .xlsx to identify any cell where 'Tom' was included, how could I do this.
In the real world I have a list with manufacturer part number and trying to figure out whether it exists within our inventory system...where the manufacturer part number may be embedded within long description.
Thanks!
Posted : 31/07/2017 12:24 pm
Could you use VLOOKUP with the range lookup set to True?
Posted : 31/07/2017 12:28 pm
going to do this more than once? Sort out the data properly
Posted : 31/07/2017 12:30 pm
You can use the FIND function.
For example =IF(FIND("Tom",A1,1)>0,"Tom","Not Tom")
Posted : 31/07/2017 12:37 pm
It'll be format conditioned to "white" ๐Ÿ˜†
Posted : 31/07/2017 12:39 pm
=ISNUMBER(SEARCH([search text],[full text]))
So, have your long text in column 1, then Tom in column 2, Dick in 3, etc.
Once these columns are filled, in the next columns use the above formula as such:
=ISNUMBER(SEARCH(B1,A1))
=ISNUMBER(SEARCH(C1,A1))
=ISNUMBER(SEARCH(D1,A1))
Edit: use FIND instead of SEARCH if you need to be case-specific
Posted : 31/07/2017 12:41 pm
Wouldn't a database be a better solution for stock control?
Posted : 31/07/2017 1:52 pm
