Scratches on rippin...
[Closed] Scratches on ripping CDs
6 Users
I'm ripping some of my old (rare!) Cds and some (one in particular) was unplayable on a CD player. I read that putting furniture polish on it can fill the scratches and make it better. It is better but not fully playable on a CD without skipping etc,
Now when I try to rip it, there are major crackles and noise on some sections of the audio. Any idea how to get iit out?
C
Posted : 30/10/2009 8:01 pm
Silicone based spray works , back to black car interior stuff n that.
Make sure you wipe the excess off tho as a disc spinning at speeds approaching a zillion miles an hour [b]WILL[/b] chuck the stuff everywhere inside yer cdp.
My mate used the stuff for his latex fetishwear and it worked a treat. 😛
da funk
Posted : 30/10/2009 8:12 pm
OT ChrisE: Depending on how a beginner gets on, I could be passing your place tomorrow Chris. Although I might introduce them to cake at Feizor first 😀
Posted : 30/10/2009 8:19 pm
EAC will either get a good copy (with several passes if necessary) or at least tell you it can't be done:
http://www.exactaudiocopy.de/
Brasso can recover an unreadable disk. Very carefully polish to the outside, rinse, and dry thoroughly.
Would strongly recommend against using silicone. It's an excellent insulator and migrates around components. Ribbon connectors etc are a friction fit and you don't really want a layer of silicone over the conductive surfaces.
Posted : 30/10/2009 8:57 pm
THIS
EAC will be able to attempt different error-correction methods and even ignore the hardware error-correction to try and give you something playable, if it can't be perfect. It can take a while to learn and can take a long while to rip, but is the business.
Then try it in a different CD-drive.
Do this before attempting anything with the physical CD surface.
Posted : 30/10/2009 9:07 pm
Thanks I'll try the software.
Pennine we'll probably be in, doing up the lounge......
Should get out m'self on Sunday. Recovering slowly from injury
C
Posted : 30/10/2009 10:09 pm
