Scan all my externa...
[Closed] Scan all my external drives and get a single copy of each file software
So I have a bunch of external drives plus my home PC which all have various combinations of mostly the same files all kept in a slightly different file structure. plus a bunch of other files that are unique to that drive.
Like for music I have 95% of the files duplicated in several different places but each place has a few extra / fewer albums and some albums might be in Various in one place and soundtrack in the other
I want to make sure that I have one copy of each and every file, but not three or four of everything in slightly different places. Just using windows copy/paste will not work as if the folder structure is slightly different it will just copy it accross
So I am not really looking for pure back-up software either, I guess I want something that will scan the files I have, recognize a new unique file and copy it across to a new master location.
I tried searching for file aggregation , but was not having any luck
Suggestions?
Posted : 21/06/2018 10:46 am
robocopy into a fresh location?
edit: good luck with the syntax though:  https://docs.microsoft.com/en-us/windows-server/administration/windows-commands/robocopy
Posted : 21/06/2018 10:51 am
The commands look scary indeed
<table>
<tbody>
<tr>
<td>/xx</td>
<td class="">Excludes extra files and directories.</td>
</tr>
<tr>
<td>/xl</td>
<td class="">Excludes "lonely" files and directories.</td>
</tr>
</tbody>
</table>
is it a lonely file??
Posted : 21/06/2018 11:35 am
Easy on linux, run md5sum on every file, then pipe the list through sort and uniq and from that rebuild a list of one copy of each unique file, which you then find and copy to the clean drive.
Posted : 21/06/2018 11:37 am
footflaps
I'm a Linux programmer by trade and TBH that doesn't sound that easy.
Well not compared to copying the lot to a single drive in windows, and running dupeguru. 🙂
Most likely there will be issues with escaping any weird characters (speech marks for example) in filenames with that approach too.
Posted : 21/06/2018 11:52 am
I’m a Linux programmer by trade and TBH that doesn’t sound that easy.
Under 50 lines of bash.....
Pretty trivial for bash programming.
Posted : 21/06/2018 12:24 pm
